Thread: Can not copy data with VBA code
    Mar 2021
    With the help of the below code I am not able to copy the text in text files in excel cell if the text in file starts with "="
    How can I modify the code?
    Sub santa()
        Dim r As Range, txt As String, msg As String
        With Sheets("input")
            For Each r In .Range("a2", .Range("a" & Rows.Count).End(xlUp))
                If r <> "" Then
                    If Dir(r.Text) <> "" Then
                        txt = CreateObject("Scripting.FileSystemObject").OpenTextFile(r.Text).ReadAll
                        r(, 2) = txt
                        r(, 3) = Join(Filter(Split(txt, vbNewLine), "VBA-2", True, 1), vbLf)
                        msg = msg & vbLf & r.Text
        If Len(msg) Then MsgBox "File not fouond" & msg
    Last edited by DocAElstein; 03-31-2021 at 05:46 PM. Reason: Code tags : [CODE] ..Your code here ... [/CODE]
    Hello Susan1234
    Welcome to ExcelFox
    The problem is possibly that Excel is interpreting the = to mean you are pasting in a formula. Assuming the text after the = is not a valid formula, then Excel will then error.
    A couple of ways to overcome that:
    One way: You could test each txt entry for an = at the start, and then if there is a =, then change the format of the cell you will be writing into, to be text format:
    Sub santaClaws() '  https://excelfox.com/forum/showthread.php/2741-Can-not-copy-data-with-VBA-code
                If r <> "" Then
                     Let txt = CreateObject("Scripting.FileSystemObject").OpenTextFile(r.Text).ReadAll
                        If Left$(txt, 1) = "=" Then Let r.Offset(0, 1).NumberFormat = "@"
                     Let r(, 2) = txt
                        If Left$(Join(Filter(Split(txt, vbNewLine), "VBA-2", True, 1), vbLf), 1) = "=" Then Let r.Offset(0, 2).NumberFormat = "@"
                     Let r(, 3) = Join(Filter(Split(txt, vbNewLine), "VBA-2", True, 1), vbLf)
                     Let msg = msg & vbLf & r.Text
    Alternatively you could just change all your writing-in range to text format
    Sub Roodolf() '  https://excelfox.com/forum/showthread.php/2741-Can-not-copy-data-with-VBA-code
         Let .Range("B2:C" & .Range("a" & .Rows.Count).End(xlUp).Row & "").NumberFormat = "@"
                If r <> "" Then
                     Let r(, 2) = txt
    If you don’t mind having an extra space at the beginning of some text, then you could simply add a space in front of any =
    ( That is the method I often use to prevent Excel seeing an = as the first character )
    Sub Vixen() '
            For Each r In .Range("a2", .Range("a" & .Rows.Count).End(xlUp))
                If r <> "" Then
                        If Left$(txt, 1) = "=" Then Let txt = " " & txt
                     Let r(, 2) = txt
                     Dim r3 As String: Let r3 = Join(Filter(Split(txt, vbNewLine), "VBA-2", True, 1), vbLf)
                        If Left$(r3, 1) = "=" Then Let r3 = " " & r3
                     Let r(, 3) = r3
    Another option could be to simply remove any first character = in the text strings
    Sub Blitzen() '
                If r <> "" Then
                        If Left$(txt, 1) = "=" Then Let txt = Replace(txt, "=", "", 1, -1, vbBinaryCompare)
                     Let r(, 2) = txt
                        If Left$(r3, 1) = "=" Then Let r3 = Replace(r3, "=", "", 1, -1, vbBinaryCompare)
                     Let r(, 3) = r3
    I tested on the uploaded files… ( you will need to change the full path in cell A1 to suit where you have the text file)
    @ susan santa 12345 et al
    You continue to post short badly explained questions, and either ignore or don’t understand the various things I have said to you.
    My best guess is that you are either
    _ a Bot,
    _ a total idiot,
    _ just trying your luck at getting Homework questions answered quickly
    _ just trying your luck at answering someone else’s questions and have no idea or interest in them yourself
    _ deliberately trying to be a pain in the arse.
    I will probably delete, close , ban you, or some combination in a few days to tidy the place up a bit
    Maybe try posting at excelforum.com or mrexcel.com, (again)
  1. Replies: 1
    Last Post: 01-30-2019, 04:23 PM
  2. Replies: 1
    Last Post: 03-11-2014, 06:03 PM
  3. Replies: 1
    Last Post: 10-16-2013, 05:06 PM
  4. VBA Code to Open Workbook and copy data
    Last Post: 08-15-2012, 06:58 PM
  5. VBA code to copy data from source workbook
    Last Post: 07-30-2012, 09:28 AM
