Results 1 to 5 of 5
Thread: Nth Largest Unique Value in an Array (UDF)
    Lightbulb Nth Largest Unique Value in an Array (UDF)
    Hi All,
    Here is an UDF to find the nth Largest unique value from an array.
    Function NTHLARGESTUNIQUE(ByRef InpData, Optional ByVal Nth As Long = 1)
        Dim i   As Long, UB1 As Long, UB2 As Long
        NTHLARGESTUNIQUE = CVErr(xlErrNum)
        If TypeOf InpData Is Range Then
            If InpData.Rows.Count > 1 And InpData.Columns.Count = 1 Then
                InpData = Application.Transpose(InpData.Value2)
            ElseIf InpData.Rows.Count = 1 And InpData.Columns.Count > 1 Then
                InpData = Application.Transpose(Application.Transpose(InpData.Value2))
                Exit Function
        UB1 = UBound(InpData, 1)
        UB2 = UBound(InpData, 2)
        If UB1 > 0 And UB2 > 0 Then Exit Function
        With CreateObject("system.collections.sortedlist")
            For i = LBound(InpData) To UBound(InpData)
                .Item(InpData(i)) = Empty
            If .Count Then
                NTHLARGESTUNIQUE = .getkey(.Count - Nth)
    Use like
    =NTHLARGESTUNIQUE(A1:A15,2)
    =NTHLARGESTUNIQUE(A1:G1,2)
    MsgBox NTHLARGESTUNIQUE([{1,2,5,8,4}], 3)
    BTW, for those who want to know about system.collections.sortedlist, find this MSDN link:
    SortedList Class https://www.youtube.com/channel/UCnxwq2aGJRbjOo_MO54oaHA
    InpData = Application.Transpose(Application.Transpose(InpDat a.Value2))
    Exit Function
    .... < snip >
    Just wanted to point out that the double call to Application.Transpose (highlighted in bold) can be replaced with a single call to Application.Index (which should also be faster)...
    InpData = Application.Index(InpData.Value2, 1, 0)
    Thanks Rick
    Thanks Rick
    You are welcome, of course. I looked at your function in a little more depth and am not sure why you restricted it to only (contiguous) numerical data in single column ranges or single row ranges. If I am not mistaken, I believe the following will work correctly for (contiguous) numerical data in single column ranges, single row ranges OR rectangular ranges...
    Function NTHLARGESTUNIQUE(InpData As Variant, Optional ByVal Nth As Long = 1) As Variant
      Dim V As Variant, Arry As Variant
      On Error GoTo Whoops
      Arry = InpData
      With CreateObject("System.Collections.SortedList")
        For Each V In Arry
          .Item(V) = Empty
        If .Count Then NTHLARGESTUNIQUE = .getkey(.Count - Nth)
    Whoops:
    And if you wanted to allow the function to ignore errors, blanks and text within the range, then I believe you could do this instead...
      NTHLARGESTUNIQUE = CVErr(xlErrValue)
      Arry = InpData
        For Each V In Arry
          If IsNumeric(V) Then .Item(V) = Empty
    Whoops:
    In general, we look these kind of things in either on a single column or row. In fact I made this UDF for someone who asked this question somewhere on net.
    Thanks for making this UDF more generic
  1. Nth Such-And-Such Day Of The Month
    Last Post: 01-02-2020, 06:48 PM
  2. Fetch Nth last item from a list
    By SDruley in forum Excel Help
    Last Post: 01-01-2013, 09:28 AM
  3. Nth Working Day Including Saturday
    By Excel Fox in forum Download Center
    Last Post: 10-10-2012, 02:41 AM
  4. Replies: 2
    Last Post: 01-07-2012, 12:11 AM
  5. Average Of The X Largest Numbers
    Last Post: 04-16-2011, 04:15 PM
