Results 1 to 10 of 12
Thread: Concatenate with style
    Dec 2020
    Hello Excel Experts,
    Below VBA was posted by Mr Rick Rothstein
    I want some change in this below VB. If any cell from A to Z contains a formula like =Sheet1!A5&" "&Sheet1!C7 or =Sheet1!A5*3 etc it shows Runtime error '1004. How to solve this error.
    Sub ConcatWithStyles()
      Dim X As Long, Cell As Range, Text As String, Position As Long
      Range("A3").Value = Space(Evaluate("SUM(LEN(A1:Z1))+COLUMNS(A1:Z1)-1"))
      Position = 1
      For Each Cell In Range("A1:Z1")
        With Range("A3")
          .Characters(Position, Len(Cell.Value)).Text = Cell.Characters(1, Len(Cell.Value)).Text
          For X = 1 To Len(Cell.Value)
            With .Characters(Position + X - 1, 1).Font
              .Name = Cell.Characters(X, 1).Font.Name
              .Size = Cell.Characters(X, 1).Font.Size
              .Bold = Cell.Characters(X, 1).Font.Bold
              .Italic = Cell.Characters(X, 1).Font.Italic
              .Underline = Cell.Characters(X, 1).Font.Underline
              .Color = Cell.Characters(X, 1).Font.Color
              .Strikethrough = Cell.Characters(X, 1).Font.Strikethrough
              .Subscript = Cell.Characters(X, 1).Font.Subscript
              .Superscript = Cell.Characters(X, 1).Font.Superscript
              .TintAndShade = Cell.Characters(X, 1).Font.TintAndShade
              .FontStyle = Cell.Characters(X, 1).Font.FontStyle
        Position = Position + Len(Cell.Value) + 1
    Thanks in advance
    Hello Abdul
    Welcome to ExcelFox
    I am not familiar with the macro you posted : I am not sure what it is supposed to do.
    Can you please:
    _ Tell us where you got it from ( give us the URL link )
    _ Explain in as much detail as you can what it is you want to do. Possibly it would be helpful to also upload a sample file to help explain
    If no one else can help, then I will take another look , possibly tomorrow
    Dec 2020
    Hello Abdul
    Welcome to ExcelFox
    Can you please:
    Thanks for reply sir.
    here is link
    https://www.mrexcel.com/board/thread.../#post-3954687
    Here is a simple quick solution idea.
    It stores the formulas, then replaces all formulas with their values, then runs Ricks coding, then replaces the formulas
    I am using, as an example, a similar example to that at the referenced link ( https://www.mrexcel.com/board/thread.../#post-3953353 )
    I have this worksheet example, where I have a formula in the first cell:
    RicksConcatWithStylesBefore.JPG : http://i.imgur.com/PlcxFab.jpg
    _____ Workbook: RicksConcatWithStyles.xls ( Using Excel 2007 32 bit )
    Row\Col A B C D E F
    1 excel fox The thinking man's MrEXCEL Tips & Solutions
    4 excel
    7 fox
    Worksheet: Sheet1
    Row\Col A B C D E F
    1 =Sheet1!A4 & " " & Sheet1!C7 The thinking man's MrEXCEL Tips & Solutions
    4 excel
    7 fox
    Worksheet: Sheet1
    After running the macro you will get this:
    RicksConcatWithStylesAfter.JPG : http://i.imgur.com/3pvfB7n.jpg
    P.S:
    Note: This solution is not perfect. If you have different styles or formatting for characters within a cell then some of the formatting is lost
    Example:
    Before: http://i.imgur.com/iv5yI4t.jpg
    After: http://i.imgur.com/IKxx7nj.jpg
    Macro here: https://excelfox.com/forum/showthrea...ll=1#post15166
    Also macro is in uploaded file, RicksConcatWithStyles.xls : https://app.box.com/s/n3rfg981htv37p5xjfz9y4v17ycoybqe
    This slightly modified version will help get over the issue of different character formats within a cell.
    In this version, only cells with formulas are subject to having that formula stored, replaced with values , and then replaced after Rick's coding
    Sub ConcatWithStyles2() '  https://www.mrexcel.com/board/threads/the-hardest-question-in-excel-history-a-very-smart-vba-macro-to-combine-cell-with-their-styles.808781/#post-3954687
    Rem 0a save any formulas, and replace with values
    Dim arrFormulas(1 To 5) As Variant
    Dim cnt
        For cnt = 1 To 5
            If Left(Cells.Item(1, cnt).Formula, 1) = "=" Then ' case a formula in cell
             Let arrFormulas(cnt) = Cells.Item(1, cnt).Formula
             Let Cells.Item(1, cnt).Value = Cells.Item(1, cnt).Value
            ' we don't have a formula , so we do nothing to the cell
        Next cnt
      Range("A3").Value = Space(Evaluate("SUM(LEN(A1:F1))+COLUMNS(A1:F1)-1"))
      Position = 1
    '  Application.ScreenUpdating = False
      For Each Cell In Range("A1:F1")
        With Range("A3")
    Rem 0b Put the formulas back
        For cnt = 1 To 5
            If arrFormulas(cnt) <> "" Then ' case a formula was in cell
             Let Cells.Item(1, cnt).Formula = arrFormulas(cnt)
            ' we didnt have a formula , so we do nothing to the cell
        Next cnt
    Before:
    http://i.imgur.com/gqW322Y.jpg
    After running above macro:
    http://i.imgur.com/792PzQY.jpg
    Dec 2020
    Wow nice, Thanks once again for your quick response,
    one little problem is there, if any cell contain a number (value) it shows run time error 1004, and if given range contains more than 230 characters VBA not works the destination cell (A3) will become blank.
    Hello Abdul
    Quote Originally Posted by Abdul View Post
    ...if any cell contain a number (value) it shows run time error 1004
    This change seems to overcome that problem:
    Change
    to
    .Characters(Position, Len(Cell.Value)).Text = Cell.Value
    ... if given range contains more than 230 characters VBA not works the destination cell (A3) will become blank
    I do not understand this problem.
    Can you provide a sample to demonstrate the problem?
    I will then investigate further
    Dec 2020
    Please check the attached file,
    Excel VBA Character.Text won’t put text in a cell of more than 255 characters. Bug or "feature”?
    Hello Abdul.
    This is an interesting problem. I am both _...
    _ not sure yet of exactly what is causing this problem: It may be a Bug or just a characteristic or a feature to which I can find no documentation.
    _ not sure yet of what would be a full solution.
    I will investigate the problem again when I have more time.
    In the meantime I have a temporary workaround that works on your test data,
    Sub ConcatWithStylesTemporarySolution()
    You may be able to adapt that to other data.
    If you have problems adapting that macro to other data, then , if you can post again some different test data, and then will try to find a solution again for you.
    Temporary Solution
    The macro below , I think , appears to give your desired output. ( In the uploaded workbook, RicksConcatWithStyles.xls , I am using a worksheet with the name of ChrTextLimit. The macro gives your full concatenated string output with styles in cell A30 in worksheet ChrTextLimit
    I will investigate this issue further when I have time. ( I have started a test post, which I will post further in later https://excelfox.com/forum/showthrea...ng-with-styles )
    Sub ConcatWithStylesTemporarySolution() '  https://excelfox.com/forum/showthread.php/2679-Concatenate-with-style?p=15172&viewfull=1#post15172
    Rem 0 Worksheets info
    Dim WsTest As Worksheet: Set WsTest = ThisWorkbook.Worksheets("ChrTextLimit")
    Rem 1 concatenate text strings
    '1a  make a formula  for the concatenated cells text
        For Cnt = 1 To 16 '  16 is for column P
        Dim strCelText As String
         Let strCelText = strCelText & WsTest.Cells(1, Cnt).Address & " & " & """ """ & " & "
     Let strCelText = Left(strCelText, Len(strCelText) - 8) ' take off last  " & "  and  " "  and  " & "
     Let strCelText = "=" & strCelText ' This makes the text string appear to Excel VBA as a formula
    'Debug.Print strCelText
    ' 1b  put the full concatenated text string into a cell
     WsTest.Range("A30").Clear
     Let WsTest.Range("A30").Value = strCelText
     Let WsTest.Range("A30").Value = WsTest.Range("A30").Value ' after this we now have the full text that we want, but it is all in the same  Font  styles
    Rem 2 add the styles
    Dim Position As Long: Let Position = 1 ' This varible holds the start position (within the full concatenated string) of the next text section under consideration , so at the begining it is 1
    Dim ACel As Range
        For Each ACel In Range("A1:P1") ' for each of the cells in the range of text to be concatenated with styles
            With WsTest.Range("A30").Characters(Position, Len(ACel.Value)).Font '  this is the text section within the concatenated string corrsponding to the text from the curren  ACel  cell
              .Name = ACel.Font.Name ' I am giving the text section within the long concatenated string ( LHS ) , the style from the current  ACel  cell
              .Size = ACel.Font.Size
              .Bold = ACel.Font.Bold
              .Italic = ACel.Font.Italic
              .Underline = ACel.Font.Underline
              .Color = ACel.Font.Color
              .Strikethrough = ACel.Font.Strikethrough
              .Subscript = ACel.Font.Subscript
              .Superscript = ACel.Font.Superscript
              .TintAndShade = ACel.Font.TintAndShade
              .FontStyle = ACel.Font.FontStyle
             Let Position = Position + Len(ACel.Value) + 1 ' This takes us to posiion at the end of the current cell text  +1  ( +1 is for the extra space )
        Next ACel
    Last edited by DocAElstein; 12-12-2020 at 04:43 PM. Reason: Excel VBA Character.Text won’t put text in a cell of more than 255 characters. Bug or “feature”?
    Dec 2020
    Hello Abdul.
    Once Again thanks for your reply and patience. I appreciate your work. Thanks once again sir.
  1. Yet Another Number-To-Words Function (Sorry, US Style Only)
    Last Post: 08-06-2020, 02:44 PM
  2. changing arrangement of data to new style
    By saied in forum Excel Help
    Last Post: 02-12-2015, 10:34 PM
  3. New Forum Style
    By Admin in forum Public News
    Last Post: 05-16-2014, 11:34 AM
  4. Replies: 6
    Last Post: 12-23-2013, 04:07 PM
  5. Excel Number Format: Indian Style Comma Separation
    Last Post: 09-18-2013, 11:38 AM
