Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Align TextBox Within A Range
  1. #11
    May 2020
    Thank you for the Active X textBox! It works, but only for height. The width of the textbox is shrinked automatically. This is a main reason I prefer to use normal TextBox, because width remain static for normal textbox.
  2. #12
    Member p45cal's Avatar
    Oct 2013
    Try something along these lines:
    Private Sub TextBox1_GotFocus()
    With TextBox1
      .AutoSize = True
      .Left = Range("B1").Left
      .Top = Range("A356").Top
      .Width = 590
      .EnterKeyBehavior = True
    Private Sub TextBox1_LostFocus()
    With TextBox1
      .EnterKeyBehavior = False
      .Width = 590
      .AutoSize = False
      ht = .Height
      Debug.Print ht
      .Height = Application.Max(171, ht)
      Range("A356:A375").RowHeight = (.Height / 20)    ' + 0.5
      .Height = Range("A356:A375").Height
      Do While .Height < ht
        Range("A356:A375").RowHeight = Range("A356").RowHeight + 0.25
      Loop
    May 2020
    Thanks a lot for helping me! It is working really well.
    When I close the document after entering something in the active x textbox, a popup comes with the message...
    "parts of your document may include personal information that can't be removed by document inspector"
    It can be disabled in Trust Center > Trust Center Settings > Privacy Options, but my question is - if I share this file to someone, is this pop-up comes every time they make any change to the textbox?? This may be annoying for them.
  4. #14
    Oct 2013
    The file will retain the setting you give it in Trust Centre (as long as you save it), so that message should no longer pop up.
  5. #15
    May 2020
    Okay...thank you so much!!
  1. Align Data In Groups Of Columns
    Last Post: 05-25-2015, 03:07 AM
  2. Replies: 4
    Last Post: 11-15-2013, 03:42 PM
  3. Replies: 9
    Last Post: 08-08-2013, 07:13 PM
  4. Align Shapes (Charts) On ActiveWorksheet
    Last Post: 05-14-2012, 03:25 AM
    Last Post: 02-29-2012, 08:24 PM
