thanks for your time and efforts. below codes works as intended.
Code:Private Sub txtdelta_AfterUpdate() Dim vrech As Range Dim lColumn As Range Dim sh As Worksheet Set sh = ThisWorkbook.Sheets("Cost") Set lColumn = sh.Range("i1:AZa1").Find(UserForm1.txtdummy.Value, , xlValues, xlWhole) Set vrech = sh.Range("E4:E250").Find(UserForm1.txtselectedpart.Value, , xlValues, xlWhole) If vrech Is Nothing Then MsgBox "Row not found" ElseIf lColumn Is Nothing Then MsgBox "Column not found" Else Intersect(vrech.EntireRow, lColumn.EntireColumn) = UserForm1.txtdelta.Value End If End Sub
