Results 1 to 10 of 12
Thread: VBA intersect function for rows and column
    Jun 2020
    i am writing code to update spreadsheet cell value with intersect function. i have below code that search UserForm3.txtchangenumber in range I1 to AZA1 (worksheet "Cost") and search userform1.txtselectedpart in range E4 to E250(worksheet "Cost"). i would like to populate cell in (worksheet "Cost") when both search intersect by using intersect function.
    below is code what i have right now. but it gives me run time erroe 1004 method range of object _global failed.
    can you pl help me to understand what is error by correcting below code.
    [CODE=vba]Private Sub txtdelta_AfterUpdate()
    Dim vrech As Range
    Dim lColumn As Range
    Dim sh As Worksheet
    Set sh = ThisWorkbook.Sheets("Cost")
    'Dim colonne As Long
            'colonne = Me.ComboBox1.Value
    Set lColumn = sh.Range("i2:AZa2").Find(UserForm3.txtchangenumber, , xlValues, xlWhole) 'LookIn:=xlValues)
    Set vrech = sh.Range("E4:E250").Find(UserForm1.txtselectedpart, , xlValues, xlWhole) 'LookIn:=xlValues)
         Intersect(Range("vrech"), Range("col")) = UserForm1.txtdelta.Value
    What line errors?
    ( When it errors, select Debug, and the line that errors should be highlighted in yellow)
    https://www.youtube.com/watch?v=bs-urI_o8jo&lc=UgyBACXgNY4j_cHgH5J4AaABAg.9oTkVdzfqfm 9wlhQrYJP3M
    https://www.youtube.com/watch?v=0ltJS7uHfK4&lc=UgxoHAw8RwR7VmyVBUt4AaABAg. 9C-br0lEl8V9xI0_6pCaR9
    https://www.youtube.com/watch?v=0ltJS7uHfK4&lc=Ugz5DDCMqmHLeEjUU8t4AaABAg. 9bl7m03Onql9xI-ar3Z0ME
    https://www.youtube.com/watch?v=0ltJS7uHfK4&lc=UgxYnpd9leriPmc8rPd4AaABAg. 9gdrYDocLIm9xI-2ZpVF-q
    https://www.youtube.com/watch?v=0ltJS7uHfK4&lc=UgyjoPLjNeIAOMVH_u94AaABAg. 9id_Q3FO8Lp9xHyeYSuv1I
    https://www.youtube.com/watch?v=LP9fz2DCMBE&lc=UgzbPgJUMCztIOQDym14AaABAg. 9wdo_rWgxSH9wdpcYqrvp8
    Jun 2020
    Sounds like there is no range returned by
    can you upload a workbook example or give a link to a workbook example
    ( BTW. it will not explain the problem, but you should be doing
    Intersect(Range("vrech"), Range("col")).Value = UserForm1.txtdelta.Value
    usually VBA "geusses" that you mean that, but to be on the safe side, I personally would not rely on VBA geussing correctly )
    Jun 2020
    please find below link,
    there are 2 forms. 2nd form gets value from userform3 when you select and click cost updates buttons. i am looking for intersect values from userform3. txtchangenumber and userform1.txtselectpart number in cost spreadsheet updates
    https://www.dropbox.com/s/095zbzry2l...est2.xlsm?dl=0
    I can't find your
    where is it?
    ( I dont have much experience with UserForms, so maybe that macro is somewhere that I am not familiar at loooking in )
    Jun 2020
    it is on Form1 under cost lable
    I cant find those named ranges either, and in fact there is no sheet with the name "cost" , so I expect you gave me the wrong file.... or my ignorance in UserForms is showing up, because I still cant see how to get at that macro...
    The file has a worksheet with the name Form, but there are two UserForms, UserForm2 and UserForm3
    I appologise if it is down to my ignorance and lack of experience with such files.
    I know VBA quite well
    I do have some Userforms of my own and I know how to get at all the coding behind them, but I still can't find your
    I cant see anything like your last screenshots anywhere in either the worksheets or in the VB Editor of the file ylou have given.... ( The file I have from you has the name Part tracker test2.xlsm )
    According to my ( limited ) knowledge of VBA if I have a code line like this
    then I must have a worksheet with a tab name of "Cost" or else that code line will error
    I think also, that I must see in the Names manager the named ranges of "vrech and "col" or else
    Range("vrech")
    Range("col")
    will error.
    But once again, maybe in my ignorance, I am missing something obvious....
    Jun 2020
    please find below updated link,
    https://www.dropbox.com/s/58c45t68hh...est1.xlsm?dl=0
    sorry for incorrect file.
    I think I am out of my depth on this one due to my lack of experience with user forms….
    If I try to step through the macro
    then a UserForm springs up and nothing else happens.
    I have never experienced anything ever like that before.
    In my experience I can step through a macro to try to find out what and where any problem is.
    If I try to do that with your macro , it does not let me step through it. Instead a UserForm pops up.
    So I am at a loss on how to go further . Sorry
    I don’t know how to find a problem in a macro that I can’t seem to run.
    Hope someone else can help.
  1. Transpose rows to column and join table
    By Agoyman in forum Excel Help
    Last Post: 04-23-2019, 09:56 AM
  2. Replies: 9
    Last Post: 02-01-2017, 06:04 PM
  3. Function Code for getting Column Letter from Column Number
    By DocAElstein in forum Excel and VBA Tips and Tricks
    Last Post: 08-23-2014, 02:27 AM
  4. VBA To Delete Rows Based On Value Criteria In A Column
    By jffryjsphbyn in forum Excel Help
    Last Post: 08-15-2013, 12:45 PM
  5. Delete unwanted rows & column
    By sanjeevi888 in forum Excel Help
    Last Post: 09-30-2012, 08:52 AM
