Thread: Cut & paste between sheets Move Some Data Rows To New Worksheet Based On Conditions
    Jul 2019
    Hi Experts,
    I am looking for a macro that will do the things mentioned below
    macro will be placed in a macro.xlsm
    sample.xls & macro.xlsm both are loacted at different places, So the path should be hardcoded in the macro so that i can change it as per my needs
    sheet name can be anything
    If column D of sample.xls is equal to column E of sample.xls Or column D of sample.xls is equal to column F of sample.xls then do nothing else put that data into new sheet by creating a new sheet in it & remove that data from current sheet(plz see the sample file)
    https://www.excelforum.com/excel-pro...ml#post5368297
    http://www.eileenslounge.com/viewtopic.php?f=30&t=35000
    Here is a solution. ( https://excelfox.com/forum/showthrea...ll=1#post14728 )
    It uses the way of getting the required rows in the original first worksheet before , that are needed in
    _ the first worksheet after,
    And
    _ in the new worksheet
    Here are some notes in support of solution:
    https://excelfox.com/forum/showthrea...ll=1#post14717
    Before:
    J
    K
    NSE ACC EQ
    1265
    1265
    1246.5
    1275.3
    1247
    22
    BUY
    1167.611
    NSE ADANIENT EQ
    151.85
    165.45
    151.4
    151.85
    152.35
    25
    BUY
    141.0465
    NSE HDFC EQ
    1805
    1826
    1805
    1809.3
    1786.05
    1330
    BUY
    1624.03
    NSE HDFCBANK EQ
    985
    988.4
    970
    991.85
    971.85
    1333
    BUY
    854.6115
    NSE HEROMOTOCO EQ
    2316
    2345
    2300
    2292.25
    2311.8
    1348
    SHORT
    2024.154
    NSE HINDALCO EQ
    145.9
    147.45
    142.45
    146.95
    143.6
    1363
    BUY
    119.9375
    Worksheet: 1-Sheet1
    After
    J
    K
    NSE ADANIENT EQ
    151.85
    165.45
    151.4
    151.85
    152.35
    25
    BUY
    141.0465
    NSE HDFCBANK EQ
    985
    988.4
    970
    991.85
    971.85
    1333
    BUY
    854.6115
    NSE HEROMOTOCO EQ
    2316
    2345
    2300
    2292.25
    2311.8
    1348
    SHORT
    2024.154
    NSE HINDALCO EQ
    145.9
    147.45
    142.45
    146.95
    143.6
    1363
    BUY
    119.9375
    Worksheet: New Worksheet
    J
    K
    NSE ACC EQ
    1265
    1265
    1246.5
    1275.3
    1247
    22
    BUY
    1167.611
    NSE HDFC EQ
    1805
    1826
    1805
    1809.3
    1786.05
    1330
    BUY
    1624.03
    Worksheet: 1-Sheet1
    Macro here: https://excelfox.com/forum/showthrea...ll=1#post14728
    Similar Post
    https://www.mrexcel.com/board/thread.../#post-5527494
    A Folk, A Forum, A Fuhrer …. Heil Schicklgruber
  1. Replies: 6
    Last Post: 08-28-2019, 09:42 AM
  2. Replies: 0
    Last Post: 09-26-2018, 02:37 PM
  3. Replies: 15
    Last Post: 01-04-2013, 03:26 PM
  4. VBA -- Copy/Paste across sheets
    Last Post: 09-21-2012, 02:07 PM
  5. Trapping Copy To Range Before Copy/Cut Paste
    Last Post: 04-07-2011, 07:48 PM
