Page 23 of 30 FirstFirst ... 132122232425 ... LastLast
Results 221 to 230 of 294
Thread: Appendix Thread. ( Codes for other Threads, ( Avinash ).)
  1. #221
    Text File
    ( This post is https://excelfox.com/forum/showthrea...ll=1#post13693 )
    Some notes related to these posts
    https://excelfox.com/forum/showthrea...rt-Csv-To-Xlsx https://excelfox.com/forum/showthrea...ll=1#post13318
    http://www.eileenslounge.com/viewtopic.php?f=30&t=34610
    http://www.eileenslounge.com/viewtop...267706#p267706
    http://www.eileenslounge.com/viewtop...269104#p269104
    http://www.eileenslounge.com/viewtopic.php?f=30&t=34638
    https://chandoo.org/forum/threads/fe...2/#post-264364
    Text Files
    USA
    101010
    12783
    GTT
    LineSeprator
    USA
    22
    12783
    GTT
    LineSeprator
    USA
    17388
    12783
    GTT
    LineSeprator
    USA
    100
    12783
    GTT
    LineSeprator
    USA
    25
    12783
    GTT
    LineSeprator
    Note: With Text files we must concern ourselves with the Record/Line(row) separator and the Field(column) Separator: They may vary. We must know about these.
    Excel File
    ( This post is https://excelfox.com/forum/showthrea...ll=1#post13694 )
    In Excel we do not have to concern ourselves with the row separator used internally by Excel ( vbCr & vbLf ), or the column Separator used internally by Excel ( vbTab ) : Excel does this for us. We do not need to add these when working with Excel Files. Internally, Excel uses those separators to make the cells that we see and work with.
    _____ Workbook: Alert..xls ( Using Excel 2007 32 bit )
    Excel Files A B C D E F G H I J K
    1 USA vbTab 101010 vbTab 6 vbTab < vbTab 12783 vbTab A vbTab vbTab vbTab vbTab vbTab GTT
    vbCr & vbLf
    2 USA vbTab 22 vbTab 6 vbTab < vbTab 12783 vbTab A vbTab vbTab vbTab vbTab vbTab GTT
    vbCr & vbLf
    3 USA vbTab 17388 vbTab 6 vbTab < vbTab 12783 vbTab A vbTab vbTab vbTab vbTab vbTab GTT
    vbCr & vbLf
    4 USA vbTab 100 vbTab 6 vbTab < vbTab 12783 vbTab A vbTab vbTab vbTab vbTab vbTab GTT
    vbCr & vbLf
    5 USA vbTab 25 vbTab 6 vbTab < vbTab 12783 vbTab A vbTab vbTab vbTab vbTab vbTab GTT
    vbCr & vbLf
    Worksheet: Sheet1
    Note: In Excel we do not have to concern ourselves with the row seperator, vbCr & vbLf or the column Seperator, vbTab: Excel does this for us. We do not need to add these when working with Excel Files
    We will only see this:
    Excel Files A B C D E F G H I J K L
    1 USA 101010 6 < 12783 A GTT
    2 USA 22 6 < 12783 A GTT
    3 USA 17388 6 < 12783 A GTT
    4 USA 100 6 < 12783 A GTT
    5 USA 25 6 < 12783 A GTT
    Worksheet: Sheet1
    Data File
    ( This post is https://excelfox.com/forum/showthrea...ll=1#post13695 )
    Field1
    Field2
    Field3
    Field4
    Field5
    Field6
    Field7
    Field8
    Field9
    Field10
    Field11
    Data Files
    F1
    F2
    F3
    F4
    F5
    F6
    F7
    F8
    F9
    F10
    F11
    Row1
    Line1
    Record1
    USA
    101010
    12783
    GTT
    Row2
    Line2
    Record2
    USA
    22
    12783
    GTT
    Row3
    Line3
    Record3
    USA
    17388
    12783
    GTT
    Row4
    Line4
    Record4
    USA
    100
    12783
    GTT
    Row5
    Line5
    Record5
    USA
    25
    12783
    GTT
    Data files are held in computer memory in different forms and retrieved in different ways. Any particular value may be referrenced in many different ways.
    In support of this post:
    https://excelfox.com/forum/showthrea...pplied-over-it
    _____ Workbook: address sheet.xlsm ( Using Excel 2007 32 bit )
    Address Door# Direction street name roadtype street name + roadtype City Name
    204 6 AVE NW
    204
    AVE NW
    2510 5 AVE N
    2510
    AVE N
    1 CICADA RD
    CICADA RD
    100 annacis Pkwy
    100
    annacis Pkwy
    100 MAIN ST
    100
    MAIN ST
    10008 107 ST
    10008
    107
    ST
    1001 110 AVE
    1001
    110
    AVE
    10010 102A AVE NW
    10010
    102A AVE NW
    10115 110 AVE
    10115
    110
    AVE
    102 11 AVE S
    102
    S
    AVE
    10205 134 AVE NW
    10205
    134 AVE NW
    13
    10235 101 ST NW
    10235
    101 ST NW
    14
    10365 97 ST NW
    10365
    97 ST NW
    15
    105 MARTIN ST
    105
    MARTIN ST
    16
    10504 100 AVE
    10504
    100
    AVE
    17
    10600 100 ST
    10600
    100
    ST
    Worksheet: Sheet1
    Some notes in support in answering this question: https://excelfox.com/forum/showthrea...ata-if-matches
    If column J has data in actual file.xlsx then match column B of actual file.xlsx with column A of sheet 1 of 2.xlsx and if it matches then copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to sheet 1 of 2.xlsx in the row of the matched value in column A of sheet 1 of 2.xlsx
    i have pasted the result in sheet3 of 2.xlsx but the result should be in sheet1(I have pasted the result in sheet3 only for understanding purpose)
    Before:
    _____ Workbook: Actual File.xlsx ( Using Excel 2007 32 bit )
    J
    K
    NSE ASHOKLEY EQ
    65
    65.35
    60.55
    63.3
    63.3
    NSE BANKBARODA EQ
    62.1
    62.95
    56.15
    56.65
    56.65
    NSE BEL EQ
    66.15
    66.75
    62.4
    65.65
    65.65
    NSE EQUITAS EQ
    82
    82.05
    71
    73.05
    73.05
    NSE FEDERALBNK EQ
    68
    68.45
    62.45
    63.1
    63.1
    NSE GAIL EQ
    85
    88.8
    79.1
    79.95
    79.95
    NSE IDFCFIRSTB EQ
    32.1
    32.35
    27.2
    27.55
    27.55
    Worksheet: Sheet1
    _.................If column J has data in actual file.xlsx then match column B of actual file.xlsx with column A of sheet 1 of 2.xlsx
    _____ Workbook: 2 18May.xlsx ( Using Excel 2007 32 bit )
    Stock Name
    ACC
    ADANIENT
    ADANIPORTS
    ASHOKLEY
    EQUITAS
    L&TFH
    Worksheet: Sheet1
    J
    K
    L
    Worksheet: Sheet2
    _.......copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to sheet 1 of 2.xlsx
    After:
    J
    K
    L
    M
    Stock Name data data data data data data data data data data data data
    ACC
    100
    108
    120
    128
    134
    151
    6534
    30
    90
    97
    103
    ADANIENT
    101
    109
    121
    127
    135
    122
    782
    40
    92
    98
    ADANIPORTS
    102
    110
    122
    16
    137
    177
    93
    99
    104
    ASHOKLEY
    EQUITAS
    AMBUJACEM
    105
    117
    125
    133
    140
    746
    23
    80
    96
    102
    109
    Worksheet: Sheet3
    macro for solution to this Thread:
    ( Remember to include Public Function CL() )
    Sub CopyPaste20()  '   https://excelfox.com/forum/showthread.php/2494-Copy-and-paste-of-data-if-matches
    Rem 1 Worksheets info
    ' 2.xlsx
    Dim Wb2 As Workbook
     Set Wb2 = Workbooks("2.xlsx")
    Dim Ws1 As Worksheet: Set Ws1 = Wb2.Worksheets.Item(1)
    Dim Lr1 As Long
     Let Lr1 = Ws1.Range("A" & Ws1.Rows.Count & "").End(xlUp).Row
    Dim arrA() As Variant: Let arrA() = Ws1.Range("A1:A" & Lr1 & "").Value2          '  2.xlsx sheet1 column A
    Dim Ws2 As Worksheet: Set Ws2 = Wb2.Worksheets.Item(2)
    Dim Rng22 As Range: Set Rng22 = Ws2.Range("A1").CurrentRegion                    ' Row to be copied - (only first row)entire row of data from sheet2 of 2.xlsx
    ' Actual File.xlsx
    Dim Wb As Workbook, Ws As Worksheet
     Set Wb = Workbooks("Actual File.xlsx")
     Set Ws = Wb.Worksheets.Item(1)
    Dim Jmax As Long: Let Jmax = Ws.Range("J" & Ws.Rows.Count & "").End(xlUp).Row
    Dim arrB() As Variant: Let arrB() = Ws.Range("B1:B" & Jmax & "").Value2          ' Actual File.xlsx sheet1 column B
    Rem 2 do it
    Dim Cnt '                                               this is for - going down column A of 2.xlsx sheet1 looking for a match in  Actual File.xlsx sheet1 column B
        For Cnt = 2 To Jmax
        Dim MtchRes As Variant
         Let MtchRes = Application.Match(arrA(Cnt, 1), arrB(), 0)  '    - going down column A of 2.xlsx sheet1 looking for a match in  Actual File.xlsx sheet1 column B
            If IsError(MtchRes) Then
            ' no match  do nothing
            Else ' Cnt is now at the row number of where  2.xlsx sheet1 column A  was found in  Actual File.xlsx sheet1 column B
            Dim Lc1Cnt As Long: Let Lc1Cnt = Ws1.Cells.Item(Cnt, Ws1.Columns.Count).End(xlToLeft).Column
             Ws1.Range("B" & Cnt & ":" & CL(Lc1Cnt) & Cnt & "").ClearContents ' clear row Cnt of all data before pasting
             Rng22.Copy Destination:=Ws1.Range("B" & Cnt & "")                ' copy the (only first row)entire row of data from sheet2 of 2.xlsx and paste it to the row in  sheet 1 of 2.xlsx  at the row number of the matched value of 2.xlsx sheet1
    '     http://www.excelfox.com/forum/showthread.php/1546-TESTING-Column-Letter-test-Sort
    Notes for question 2 here
    https://excelfox.com/forum/showthrea...ll=1#post13379
    https://excelfox.com/forum/showthrea...ll=1#post13387
    Before is as here ,
    https://excelfox.com/forum/showthrea...ll=1#post13382
    , but ignore Sheet2 - no row is to be copied
    J
    K
    NSE ASHOKLEY EQ
    65
    65.35
    60.55
    63.3
    63.3
    NSE BANKBARODA EQ
    62.1
    62.95
    56.15
    56.65
    56.65
    NSE BEL EQ
    66.15
    66.75
    62.4
    65.65
    65.65
    NSE EQUITAS EQ
    82
    82.05
    71
    73.05
    73.05
    NSE FEDERALBNK EQ
    68
    68.45
    62.45
    63.1
    63.1
    NSE GAIL EQ
    85
    88.8
    79.1
    79.95
    79.95
    NSE IDFCFIRSTB EQ
    32.1
    32.35
    27.2
    27.55
    27.55
    NSE IOC EQ
    93
    93.65
    87.25
    87.9
    87.9
    NSE L&TFH EQ
    90
    91.55
    80.5
    81.65
    81.65
    Worksheet: Sheet1 (2)
    _____ Workbook: 2 (2).xlsx ( Using Excel 2007 32 bit )
    J
    K
    L
    M
    N
    O
    Stock Name data data data data data data data data data data data data data data
    ACC
    100
    108
    120
    128
    134
    151
    6534
    30
    90
    97
    103
    ADANIENT
    101
    109
    121
    127
    135
    122
    782
    40
    92
    98
    ADANIPORTS
    102
    110
    122
    16
    137
    177
    93
    99
    104
    ASHOKLEY
    16
    137
    177
    93
    99
    104
    EQUITAS
    93
    99
    102
    110
    122
    L&TFH
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    Worksheet: Sheet1
    If column J has data in actual file.xlsx then match column B of actual file.xlsx with column A of sheet 1 of 2.xlsx and if it matches then double the value of that row of 2.xlsx
    After
    J
    K
    L
    M
    N
    O
    ACC
    100
    108
    120
    128
    134
    151
    6534
    30
    90
    97
    103
    ADANIENT
    101
    109
    121
    127
    135
    122
    782
    40
    92
    98
    ADANIPORTS
    102
    110
    122
    16
    137
    177
    93
    99
    104
    ASHOKLEY
    274
    354
    20
    100
    186
    198
    208
    EQUITAS
    20
    100
    186
    198
    220
    244
    18
    20
    22
    L&TFH
    22
    24
    26
    28
    30
    32
    34
    36
    38
    40
    42
    44
    46
    Worksheet: Sheet2
    Note: I think your supplied After is wrong! - L&TFH should not be considered from Actual File.xlsx, because J of that row is not 1
  1. Replies: 192
  3. Replies: 379
    Last Post: 11-13-2020, 07:44 PM
  4. Appendix Thread. Diet Protokol Coding Adaptions
