Results 1 to 10 of 29
Thread: copy and paste by VBA based on criteria
    Jul 2019
    Copy and paste the data if condition met
    All files are located in different path
    vba will be placed in a macro.xlsm
    i have a file name 1.xls & 2.xls
    match column I of 1.xls with column B of 2.xls
    If column I of 1.xls matches with column B of 2.xls then do nothing &
    if column I of 1.xls doesnt matches with column B of 2.xls then copy and paste the column B & Column I of 1.xls to column A & column B of sheet2 of 2.xls
    sheet name can be anything
    plz see the sample pic & help me in solving this problem by vba
    the bigger pic is 1.xls
    the smallest pic is sheet2 of 2.xls (result)
    Moderator notice...
    Yet again another cross post
    https://www.excelguru.ca/forums/show...-condition-met
    I think you have not explained correctly what you want.
    Your question explanation does not match you sample data.
    Once again you have incorrectly explained what you want.
    This is wrong!!!
    It is rubbish. It does not explain your test data.
    Once again I must try to guess what you want!
    This is my guess:
    Consider the value in each row of column I of 1.xls, starting from row 2
    If the value from that row of column I of 1.xls is also in any row of column B of the first worksheet in 2.xls , then
    do nothing.
    Else If the value from that row of column I of 1.xls is not to be found in any row of column B of the first worksheet in 2.xls, then do the following:
    Copy the value from columns B and I for that row of 1.xls and paste them to columns A and B of the second worksheet of 2.xls
    Before:
    _____ Workbook: 2.xls ( Using Excel 2007 32 bit )
    Exchange
    NSE 25
    NSE 10583
    NSE 17388
    NSE 100
    Worksheet: Sheet1 (2)
    Worksheet: Sheet2
    NSE ADANIENT EQ
    1087
    1030
    955.5
    998.45
    1079.9
    25
    NSE ACC EQ
    148.05
    27.75
    25.65
    25.65
    146.5
    22
    NSE DLF EQ
    265
    419.7
    350.05
    387.25
    267.15
    10583
    NSE AMBUJACEM EQ
    30.4
    155.8
    142.55
    145.85
    29.95
    17388
    NSE AMARAJABAT EQ
    502
    514.85
    502
    499.05
    507.45
    100
    Worksheet: 1-Sheet1
    After results
    ACC
    22
    Worksheet: Sheet2
    Macro:
    Sub Step11() '    http://www.excelfox.com/forum/showthread.php/2421-copy-and-paste-by-VBA-based-on-criteria?p=13110&viewfull=1#post13110      http://www.excelfox.com/forum/showthread.php/2458-Copy-and-paste-the-data-if-condition-met
    Rem 1 Worksheets info
    Dim Wb1 As Workbook, Wb2 As Workbook   '                           If the workbook is already open , then we can refer to it using the workbooks collection object of open workbooks,  Workbooks(" ")
     Set Wb1 = Workbooks("1.xls")         ' Workbooks("1.xlsx")         '          Workbooks("sample1.xlsx")   '                                                 Set Wb1 = Workbooks.Open(ThisWorkbook.Path & "\1.xls")                ' w1 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\1.xls")           ' change the file path   If the workbook is already open , then we can refer to it using the workbooks collection object of open workbooks,  Workbooks(" ")
     Set Wb2 = Workbooks("2.xls")         ' Workbooks("2.xlsx")         '          Workbooks("sample2.xlsx")   '                                                 Set Wb2 = Workbooks.Open(ThisWorkbook.Path & "\FundsCheck.xlsb")      ' w2 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\FundsCheck.xlsb") ' change the file path      If the workbook is already open , then we can refer to it using the workbooks collection object of open workbooks,  Workbooks(" ")
    Dim Ws1 As Worksheet, Ws2 As Worksheet, Ws22 As Worksheet
     Set Ws1 = Wb1.Worksheets.Item(1)      '        Set Ws1 = Wb1.Worksheets("anything")  '     sheet name can be anything
     Set Ws2 = Wb2.Worksheets.Item(1)      '        ' Set Ws2 = Wb2.Worksheets("anything")
     Set Ws22 = Wb2.Worksheets.Item(2)
    Dim Lr1 As Long, Lr2 As Long, Lr As Long, Lr22 As Long
     Let Lr1 = Ws1.Range("A" & Ws1.Rows.Count).End(xlUp).Row      '   http://www.excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=11466&viewfull=1#post11466      Making Lr dynamic ( using rng.End(XlUp) for a single column. )
     Let Lr2 = Ws2.Range("A" & Ws1.Rows.Count).End(xlUp).Row
    ' Let Lr = IIf(Lr2 > Lr1, Lr2, Lr1)
    Rem 2 do it
    Dim cnt
        For cnt = 2 To Lr2
        Dim VarMtch As Variant
         Let VarMtch = Application.Match(CStr(Ws1.Range("I" & cnt & "").Value), Ws2.Range("B2:B" & Lr2 & ""), 0) ' We look for the string value from each row in column I of Ws1 in the range of column B in Ws2
            If Not IsError(VarMtch) Then ' If we have a match, then  Application.Match  will return an integer of the position along(down) where the match is found
            ' do nothing
            Else '  Application.Match  will return a VB error string if no match could be found
             Ws1.Range("B" & cnt & ",I" & cnt & "").Copy  ' if ranges are "in line" - that is to say have the same "width" ( in this example a single row width ) , then VBA lets us copy this to the clipboard
             Let Lr22 = Lr22 + 1 ' next free row in second worksheet of 2.xls
             Ws22.Range("A" & Lr22 & "").PasteSpecial Paste:=xlPasteValues ' Pasting of copied values which were "in line" allows us to paste out, but the missing in between bits ( columns in this example ) are missed out - the ranges are put together. Co incidentally we want this output in this example
        Next cnt
  1. Replies: 48
    Last Post: 09-23-2020, 02:03 AM
  2. Replies: 85
  3. Copy paste data based on criteria
  4. Replies: 8
    Last Post: 09-18-2013, 12:30 AM
