Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: copy and paste by VBA based on criteria
    Jul 2019
    all files are located same place
    vba is placed in a seperate file sample1.xlsm
    copy all the data from column A TO COLUMN H complete data from sample2.xls and paste it to sample3.xlsb in same columns
    save and close the sample2.xls and sample3.xlsb
    i need to do the same by vba so plz help me in slving this problem sir
    To copy all columns is not usually good to do. In whole columns you maybe do not heed all rows
    But this is what you asked for
    vba is placed in a separate file sample1.xlsm
    File is attached : FileAttatchedToPost.jpg : https://imgur.com/xFLyqLQ
    Columns("A:H").Copy
    I recommend using the Range PasteSpecial Method
    http://eileenslounge.com/viewtopic.p...=34112#p264458
    http://www.eileenslounge.com/viewtop...=25002#p193871
    https://docs.microsoft.com/en-us/off...e.pastespecial
    You can chose the way you want to Paste, and formats
    https://docs.microsoft.com/en-us/off...el.xlpastetype
    .PasteSpecial Paste:= xlPasteValuesAndNumberFormats
    .PasteSpecial Paste:= xlPasteFormats
    .PasteSpecial Paste:= xlPasteColumnWidths
    You can
    Save
    Or
    Save As
    I did do macro recording to check syntax:
    http://www.excelfox.com/forum/showth...ll=1#post12531
    You can just Save That is enough in your case.
    ( You can also SaveAs )
    Sub CopyAllColumns()
    ' copy all the data from column A TO COLUMN H complete data from sample2.xls
     Workbooks("sample2.xls").Worksheets.Item(1).Columns("A:H").Copy '
    ' paste it to sample3.xlsb in same columns
     Workbooks("sample3.xlsb").Worksheets.Item(1).Columns("A:H").PasteSpecial Paste:=xlPasteValuesAndNumberFormats
        'Workbooks("sample3.xlsb").Worksheets.Item(1).Range("A1:H65536").PasteSpecial Paste:=xlPasteValuesAndNumberFormats
     Workbooks("sample3.xlsb").Worksheets.Item(1).Columns("A:H").PasteSpecial Paste:=xlPasteFormats
     Workbooks("sample3.xlsb").Worksheets.Item(1).Columns("A:H").PasteSpecial Paste:=xlPasteColumnWidths
    ' save and close the sample2.xls and sample3.xlsb   '   http://www.excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=12531&viewfull=1#post12531
     Workbooks("sample2.xls").Save
    ' or
     Workbooks("sample2.xls").SaveAs Filename:=ThisWorkbook.Path & "\sample2.xls", FileFormat:=xlExcel8
     Workbooks("sample3.xlsb").Save
    ' or
     Workbooks("sample3.xlsb").SaveAs Filename:=ThisWorkbook.Path & "\sample3.xlsb", FileFormat:=xlExcel12
     Workbooks("sample2.xls").Close: Workbooks("sample3.xlsb").Close
    Jul 2019
    Sub STEP4()
     Dim w1 As Workbook, w2 As Workbook
     Set w1 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\1.xls") ' change the file path
     Set w2 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\FundsCheck.xlsb") ' change the file path
    w1.Worksheets.Item(1).Columns("A:H").Copy
    w2.Worksheets.Item(1).Columns("A:H").PasteSpecial Paste:=xlPasteValuesAndNumberFormats
    w2.Save
    w2.Close
    w1.Close
    I made this code correct doc sir if there is an error sir
    https://www.eileenslounge.com/viewtopic.php?f=44&t=40455&p=313035#p313035
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312889#p312889
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312886#p312886
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312752#p312752
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312734#p312734
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312727#p312727
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312724#p312724
    https://www.eileenslounge.com/viewtopic.php?f=44&t=40374&p=312535#p312535
    https://www.eileenslounge.com/viewtopic.php?p=312533#p312533
    https://www.eileenslounge.com/viewtopic.php?f=44&t=40373&p=312499#p312499
    https://www.youtube.com/watch?v=jTmVtPHtiTg&lc=UgzlC5LBazG6SMDP4nl4AaABAg
    https://www.youtube.com/watch?v=jTmVtPHtiTg&lc=UgzlC5LBazG6SMDP4nl4AaABAg. 9zYoeePv8sZ9zYqog9KZ5B
    https://www.youtube.com/watch?v=jTmVtPHtiTg&lc=Ugy_RiNN_kAqUvZ8W994AaABAg. 9xhyRrsUUOM9zYlZPKdOpm
    Your macro is good
    Your macro is working
    There are no errors in it.
    I did test on files enclosed , with this following macro. ( Macro is in sample1.xlsm )
    Sub STEP4()
    Set w1 = Workbooks.Open(ThisWorkbook.Path & "\1.xls") ' Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\1.xls") ' change the file path
    Set w2 = Workbooks.Open(ThisWorkbook.Path & "\FundsCheck.xlsb") '  Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\FundsCheck.xlsb") ' change the file path
    w2.Save
    w2.Close
    w1.Close
    1.xls : https://app.box.com/s/th2xzmkh7rnfr4qf4dho1kpgudndm073
    Jul 2019
    Thnx Doc Sir for ur great help and for ur great guidance
    Some extra info:
    For Copy and Paste values, is sometimes like this: , Rng1.Value = Rng2.Value better…
    To explain:-
    We already saw Sub Vixer9b() ' demo for rng.Value = rng.Value
    http://www.excelfox.com/forum/showth...ll=1#post11479
    http://www.excelfox.com/forum/showth...ll=1#post11485
    That was Rng.Value = Rng.Value – We did use .Value of Rng in two ways
    We can also do rng2.Value = rng1.Value
    ' Or
    do rng1.Value = rng2.Value
    So we have Alternative for:-
    Rng.Copy
    Rng.PasteSpecial Paste:= xlPasteValues
    It works like this:-
    We can use .Value Property two ways for any range, We can do this for Rng1 , Rng2 , Rngx …. Etc…
    Way 1 Put values in ( for example, Rng2 ) :-
    Rng2.Value = ‘ < -------------------------------- ‘ put values in Rng2
    Way 2 Get values out ( for example for Rng1 ) :-
    < -------------- = Rng1.Value ‘ Get values from Rng1
    So we can take values out of a range and put them in another different range: -
    Rng2.Value = Rng1.Value
    Macro is in
    Process.xlsm
    Sub STEP4b() ' Rng1.Value = Rng2.Value
     Set w1 = Workbooks.Open(ThisWorkbook.Path & "\1.xls")                ' w1 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\1.xls")           ' change the file path
     Set w2 = Workbooks.Open(ThisWorkbook.Path & "\FundsCheck.xlsb") ' w2 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\FundsCheck.xlsb") ' change the file path
    Dim Rng1 As Range, Rng2 As Range
    ' If first column and first row is used , then this will work only
     Set Rng1 = w1.Worksheets.Item(1).UsedRange '  or Set Rng1 = w2.Worksheets.Item(1).Range("A1:H" & Rng1.Rows.Count & "")
     Set Rng2 = w2.Worksheets.Item(1).Range("A1:H" & Rng1.Rows.Count & "")
    'w1.Worksheets.Item(1).Columns("A:H").Copy
    'w2.Worksheets.Item(1).Columns("A:H").PasteSpecial Paste:=xlPasteValuesAndNumberFormats
     Let Rng2.Value = Rng1.Value
    w2.Save
    w2.Close
    w1.Close
    Jul 2019
    Thnx Doc Sir for providing the Great info
    Jul 2019
    Doc Sir i have a similar problem like this
    Sub STEP4()
    w2.Save
    w2.Close
    w1.Close
    this code paste the data to sheet1 what i need is to paste the data in sheet2 so what i should do for the same sir plz help me sir in solving this problem sir
    Hello
    Worksheets.Item(1) is first worksheet
    Worksheets.Item(2) is second worksheet
    Worksheets.Item(3) is Third worksheet
    Workshe
    …….etc.
    First4Worksheets.JPG : https://imgur.com/v0h9CaU
    Attachment 2793
    Try
    w2.Worksheets.Item(2).Columns("A:H").Past…………
    Jul 2019
    Thnx Alot Doc Sir i changed the same in the code but i forgot to create a second sheet
    Done Doc Sir thnx alot Sir
  1. Replies: 48
    Last Post: 09-23-2020, 02:03 AM
  2. Replies: 85
  3. Copy paste data based on criteria
  4. Replies: 8
    Last Post: 09-18-2013, 12:30 AM
