Page 36 of 38 FirstFirst ... 263435363738 LastLast
Results 351 to 360 of 380
Thread: Appendix Thread. ( Codes for other Threads, etc.) Event Coding Drpdown Data validation
  1. #351
    In support of this Thread answer
    List table supplied by OP in uploade file
    _____ Workbook: Book1.xlsx ( Using Excel 2007 32 bit )
    Row\Col AM AN AO AP AQ AR AS AT AU AV AW AX AY AZ BA BB
    15 (Select Here)
    16 Nuclear Family (Remark if any)
    17 Joint Family (Remark if any)
    18 Single-Parent Family (Select Reason)
    19 Expired
    20 Divorced
    21 Break-Up
    22 Abandonment
    23 Enter Reason Manually
    24 Joint Family (Please Specify the Case)
    Worksheet: Sheet1
    I am not sure why get those strange black areas , so I did a find on [td=bgcolor:#000000] replacing withnothing
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    Worksheet: Sheet1
    So I did a find on [td=bgcolor:#000000] replacing with [td]
    _....see next post
    _... from last post
    15 (Select Here)
    19 Expired
    20 Divorced
    21 Break-Up
    22 Abandonment
    Worksheet: Sheet1
    Some Immediate window results
    ? Range("AM15").font.ThemeColor
    ? Range("AM15").font.TintAndShade
    ? Range("AM15").font.Color
    10855845
    ? Range("AM15").font.Colorindex
    48
    ? Range("AM16").font.tintandshade
    ? Range("AM16").font.Bold
    Falsch
    ? Range("AM16").font.Color
    6751362
    ? Range("AM16").font.Colorindex
    13
    Falsch
    ? Range("AT19").Font.Tintandshade
    ? Range("AT19").Font.Color
    ? Range("AT19").Font.colorindex
    -4105
    ? Range("AT19").Font.Bold
    Falsch
    Just testing in this post.....
    16 (Select Here)
    19 Expired
    20 Divorced
    21 Break-Up
    22 Abandonment
    Worksheet: Sheet1
    Solution for ( part A) ) of this Thread
    https://excelfox.com/forum/showthrea...ll=1#post14870
        If Target.Address = "$J$19" Then
            If Target.Value = "" Then
             Let Application.EnableEvents = False
             Let Target.Value = "(Select)"
             Let Application.EnableEvents = True
                With Target.Font
                .Color = 10855845
                '.ColorIndex = 48
            ElseIf Target.Value = "Nuclear Family" Or Target.Value = "Joint Family" Then
             Let Range("R19").Value = "(Remark if any)"
                With Range("R19").Font
                .Color = 10855845
                '.ColorIndex = 48
            ElseIf Target.Value = "Single-Parent Family" Then
             Let Range("R19").Value = "(Select Reason)"
                .Color = 10855845
                '.ColorIndex = 48
            ElseIf Target.Value = "Uncategorised" Then
             Let Range("R19").Value = "(Please Specify the Case)"
                .Color = 10855845
                '.ColorIndex = 48
        ' Target is Not a cell to be acted on
    'Row\Col     AM  AN  AO  AP  AQ  AR  AS  AT  AU  AV  AW  AX  AY  AZ  BA  BB
    '16                                          (Select Here)
    '16  Nuclear Family                          (Remark if any)
    '17  Joint Family                            (Remark if any)
    '18  Single-Parent Family                    (Select Reason)
    '19                                      Expired
    '20                                      Divorced
    '21                                      Break -Up
    '22                                      Abandonment
    '23                              Enter Reason Manually
    '24  Joint Family                            (Please Specify the Case)
    'Print Range("AM15").Font.ThemeColor
    '7
    'Print Range("AM15").Font.TintAndShade
    '0
    'Print Range("AM15").Font.Color
    '10855845
    'Print Range("AM15").Font.ColorIndex
    '48
    'Print Range("AM16").Font.TintAndShade
    '0
    'Print Range("AM16").Font.Bold
    'Falsch
    'Print Range("AM16").Font.Color
    '6751362
    'Print Range("AM16").Font.ColorIndex
    '13
    'Falsch
    'Print Range("AT19").Font.TintAndShade
    '0
    'Print Range("AT19").Font.Color
    '0
    'Print Range("AT19").Font.ColorIndex
    '-4105
    'Print Range("AT19").Font.Bold
    'Falsch
    Answer to this Thread post:
    https://excelfox.com/forum/showthrea...ll=1#post14873
    Private Sub Worksheet_Change(ByVal Target As Range) '   https://excelfox.com/forum/showthread.php/2624-Drop-Down-Menu-with-Multiple-Conditions?p=14873&viewfull=1#post14873
        If Target.Address = "$J$19" Or Target.Address = "$J$19:$P$19" Then  '  we need  "$J$19:$P$19"  to make macro work on  Delete  probably because of merged cells
        Dim RngTgt As Range: Set RngTgt = Target
            If Target.Address = "$J$19:$P$19" Then Set RngTgt = Range("J19")
            If RngTgt.Value = "" Then
             Let RngTgt.Value = "(Select Here)"
             Let RngTgt.Font.Color = 10855845
            ElseIf RngTgt.Value = "Nuclear Family" Or RngTgt.Value = "Joint Family" Then
             Let Range("R19").Font.Color = 10855845
             Let RngTgt.Font.Color = 6751362
            ElseIf RngTgt.Value = "Single-Parent Family" Then
            ElseIf RngTgt.Value = "Uncategorised" Then
        If Target.Address = "$R$19" Then Let Target.Font.ColorIndex = xlAutomatic
    In support of this püost:
    https://excelfox.com/forum/showthrea...ll=1#post14877
             Let Range("R19").Value = ""
    '    Range("R19:Z19").Select
    '      With Selection
    '        .HorizontalAlignment = xlCenter
    '        .VerticalAlignment = xlCenter
    '        .WrapText = False
    '        .Orientation = 0
    '        .AddIndent = False
    '        .IndentLevel = 0
    '        .ShrinkToFit = False
    '        .ReadingOrder = xlContext
    '        .MergeCells = True
    '      End With
    '       The drop down validation list in cell R19  is produced when the value "Single-Parent Family" is selected in cell J19
                                     '    Range("R19").Select
                With Range("R19").Validation                 'With Selection.Validation
                  .Delete
                  .Add Type:=xlValidateList, AlertStyle:=xlValidAlertStop, Operator:= _
                  xlBetween, Formula1:="Expired,Divorced,Break-Up,Abandonment,Enter Reason Manually"
                  .IgnoreBlank = True
                  .InCellDropdown = True
                  .InputTitle = ""
                  .ErrorTitle = "Error!"
                  .InputMessage = ""
                  .ErrorMessage = "To enter the reason manually, please select the option 'Enter Reason Manually'"
                  .ShowInput = True
                  .ShowError = True
            End If ' end of all values of J19 to  result in actions
        ' Target is not cell J19  ( or  J19:P19 )
    '    If Target.Address = "$R$19" Then Let Target.Font.ColorIndex = xlAutomatic
    '    If Target.Address = "$J$19" Then
    '        If Target.Value = "Single-Parent Family" Then
    '         Let Application.EnableEvents = False
    '         Let Range("R19").Value = "Select Reason..."
    '         Let Application.EnableEvents = True
    '       With Range("R19").Font
    '        .Color = -10477568
    '        .TintAndShade = 0
    '       End With
    ''         Target.Font.Size = 11.5
    '     End If
    '    If drop down list is present in cell R19 , and "Enter Reason Manually" is selected from that drop down list in R19, then the drop down validation list in cell R19  is removed.
            If Target.Value = "Enter Reason Manually" Then
    '            With Target.Validation ' Selection.Validation
    '              .Delete
                 Target.Validation.Delete
    '              .Add Type:=xlValidateInputOnly, AlertStyle:=xlValidAlertStop, Operator _
    '              :=xlBetween
    '              .IgnoreBlank = True
    '              .InCellDropdown = True
    '              .ShowInput = True
    '              .ShowError = True
    '            End With
    '         Selection.ClearContents
    '      With Target.Font
    '        .ThemeColor = xlThemeColorLight1
    '        .TintAndShade = 0
    '       End With
    '    With Selection
    '        .HorizontalAlignment = xlLeft
    '        .WrapText = False
    '        .Orientation = 0
    '        .IndentLevel = 0
    '    End With
      ' Target is not R19
                  .Delete
                  .IgnoreBlank = True
                  .InputTitle = ""
                  .InputMessage = ""
                  .ShowInput = True
                  .ShowError = True
        ' Target is not R19
    First macro for this Post:
    https://excelfox.com/forum/showthrea...4913#post14913
    Sub TestieCalls()
     Call Me.Worksheet_Change(Me.Range("B4"))
    Public Sub Worksheet_Change(ByVal Target As Range)
    Dim Lr As Long, Lc As Long
     Let Lr = Me.Range("B" & Me.Rows.Count & "").End(xlUp).Row
     Let Lc = Me.Cells(4, 2).End(xlToRight).Column             '  I am using a slightly less common way including   xlToRight   because there are some explanation wordings that would be found giving a false number by the more typically used    Columns.Count xlToLeft   way
    Dim RngTbl As Range: Set RngTbl = Me.Range("B4:" & CL(Lc) & Lr & "")
        If Application.Intersect(Target, RngTbl) Is Nothing Then
         Exit Sub ' I did not change anything in the table
         Let Me.Range("A1").Value = "No Remarks"
        Rem Loop
        Dim arrTbl() As Variant: Let arrTbl() = RngTbl.Value2
        Dim Cnt
            For Cnt = 1 To UBound(arrTbl(), 1) ' Loop "down" "rows" in table array
            Dim Clm As Long: Let Clm = 2 ' "column" in table array
            Dim Decs As Long
                'For Clm = 2 To UBound(arrTbl(), 2) - 1 ' loop from second to last but one "column" in table array
                Do
                    If arrTbl(Cnt, Clm + 1) >= arrTbl(Cnt, Clm) Then ' we no longer have a decresing sequence
                     Let Decs = 0 ' Reset the count of sequential decreasing values
                    Else ' we have at least 2 sequential decreses, possibly 3
                     Let Decs = Decs + 1
                'Next Clm
                 Let Clm = Clm + 1
                Loop While Clm < UBound(arrTbl(), 2) And Decs < 2
                'If Clm = UBound(arrTbl(), 2) Then ' this will occur if we did not exit the   For  loop
                If Decs = 2 Then ' If decs = 2 we had three seqeuntial decreses = sequentially 2 x arrTbl(Cnt, Clm + 1) < arrTbl(Cnt, Clm)
                Dim StrRemmark As String
                 Let StrRemmark = StrRemmark & " and " & arrTbl(Cnt, 1)
             Let Decs = 0 ' reset the count of sequential decreasing values so that  Decs  can be used in the next main row loop
    ' add remark
        If StrRemmark <> "" Then
         Let StrRemmark = Mid(StrRemmark, 6) ' this takes off the first  " and "
         Let Me.Range("A1").Value = "Student is decreasing in " & StrRemmark
        ' no remmark
    Final macro for this post
    '  https://excelfox.com/forum/showthread.php/2633-Showing-Custom-Value-Based-on-the-Condition-of-Dynamic-Table?p=14913&viewfull=1#post14913
    'Important:
    '    All of the above conditions are applied only if there are minimum 3 consecutive cells which are in descending order.
    '    For example, cells D5, E5 and F5 have values which are satisfied all the three condition, i.e, they are in descending order, and they are consecutive (side by side), and they are minimum three.
    'Point 1) Missing comma: When all the three rows contains values in descending order, then B4 shows -
    '     Student is decreasing in ENGLISH and HINDI and MATHS
    '        It should be - Student is decreasing in ENGLISH, HINDI and MATHS (as we normally write in English language)
    Sub TestieCalls()
        Rem Loop
        Dim Cnt
            Dim Decs As Long
                Do
                     Let Decs = Decs + 1
                'Next Clm
                 Let Clm = Clm + 1
                 'Let StrRemmark = StrRemmark & " and " & arrTbl(Cnt, 1)
                 'Let StrRemmark = StrRemmark & ", " & arrTbl(Cnt, 1)
                 Let StrRemmark = StrRemmark & ", " & Left(arrTbl(Cnt, 1), 1) & Mid(LCase(arrTbl(Cnt, 1)), 2) '  This effectively changes something like  MATHS   to  M & aths  =  Maths
    ' add remark
         'Let StrRemmark = Mid(StrRemmark, 6) ' this takes off the first  " and "
         Let StrRemmark = Mid(StrRemmark, 3) ' this takes off the first  ", "
        Dim Pos As Long: Let Pos = InStrRev(StrRemmark, ", ", -1, vbBinaryCompare)
            If Pos <> 0 Then ' Pos will be  0  if no  ", "  was found
             Let StrRemmark = Application.WorksheetFunction.Replace(StrRemmark, Pos, 2, " and ") '  _3 WorksheetFunction.Replace Method    https://excelfox.com/forum/showthread.php/2230-Built-in-VBA-methods-and-functions-to-alter-the-contents-of-existing-character-strings
             ' we had no  ", "  in  the final string , so we just have one subject
         Let Me.Range("A1").Value = "Student is decreasing in " & StrRemmark & "."
        ' no remmark
    macro solution for this post:
    https://excelfox.com/forum/showthrea...ll=1#post14955
    Sub Testie()  ' For testing in pre Office 2016
     Call Me.Worksheet_Change(Me.Range("K74")) ' this simulates a change in cell K74
    Dim Lr As Long, Lc As String                                  '    Lc As Long
     Let Lr = 81                                                  '    Me.Range("B" & Me.Rows.Count & "").End(xlUp).Row
     Let Lc = "S"
    Dim RngTbl As Range ' : Set RngTbl = Me.Range("K74:" & Lc & Lr & "")
    'or simply
     Set RngTbl = Me.Range("K74:S81")                             '        Me.Range("B4:" & CL(Lc) & Lr & "")
         Let Me.Range("H40").Value = "No Remarks"      '           Me.Range("A1").Value = "No Remarks"
        Rem  We now get the array , arrDec()  , directly from  X74:X81
        'Dim arrTbl() As Variant: Let arrTbl() = RngTbl.Value2
        Dim arrDec() As Variant                                  '           As Boolean: ReDim arrDec(1 To Lr - 3)
         Let arrDec() = Me.Range("X74:X81").Value2
        ' We no longer need the data table range, but we do need the  subject  table/ column
        Dim arrSubjs() As Variant
         Let arrSubjs() = Me.Range("F74:F81").Value2
                    Dim Cnt
    '                    For Cnt = 1 To UBound(arrTbl(), 1) ' Loop "down" "rows" in table array
    '                    Dim Clm As Long ' "column" in table array
    '                        For Clm = 2 To UBound(arrTbl(), 2) - 1 ' loop from second to last but one "column" in table array
    '                            If arrTbl(Cnt, Clm + 1) >= arrTbl(Cnt, Clm) Then
    '                             Let arrDec(Cnt) = True: Exit For ' we no longer have a decresing sequence
    '                            Else
    '                            End If
    '                        Next Clm
    '                    Next Cnt
    ' at this point I have in my  arrDec()  1  for a decreasing sequence and  ""  for a non decreasing sequence
        Rem loop to build the output string
            For Cnt = 1 To UBound(arrDec(), 1)
                If arrDec(Cnt, 1) = 1 Then    '                                False Then
                 'Let StrRemmark = StrRemmark & " and " & arrSubjs(Cnt, 1)
                 Let StrRemmark = StrRemmark & ", " & Left(arrSubjs(Cnt, 1), 1) & Mid(LCase(arrSubjs(Cnt, 1)), 2) '
    ' add remark
         'Let Me.Range("A1").Value = "Student is decreasing in " & StrRemmark
          Let Me.Range("H40").Value = "Decline in " & StrRemmark & "."
        ' no remmark
    'Public Function CL(ByVal lclm As Long) As String '         http://www.excelforum.com/development-testing-forum/1101544-thread-post-appendix-no-reply-needed-please-do-not-delete-thanks-4.html#post4213980
    '    Do: Let CL = Chr(65 + (((lclm - 1) Mod 26))) & CL: Let lclm = (lclm - (1)) \ 26: Loop While lclm > 0
    'End Function
    post for later use,
    posting to get URL limk now
  1. Replies: 192
  2. Replies: 293
    Last Post: 09-24-2020, 01:53 AM
  3. Appendix Thread. Diet Protokol Coding Adaptions
  4. Restrict data within the Cell (Data Validation)
    By dritan0478 in forum Excel Help
    Last Post: 07-27-2017, 09:03 PM
