VBA Solution to above, and answer to this Post
http://www.excelfox.com/forum/showth...ll=1#post13102
VBA answer
Put columns in arrays
| Row\Col |
D |
1 |
Open |
2 |
1087 |
3 |
148.05 |
4 |
265 |
5 |
30.4 |
arrD() =
| Row\Col |
H |
1 |
LTP |
2 |
1079.9 |
3 |
146.5 |
4 |
267.15 |
5 |
29.95 |
arrH() =
1079.9 |
146.5 |
267.15 |
29.95 |
| Row\Col |
K |
1 |
2 |
1090.69 |
3 |
147.95 |
4 |
264.47 |
5 |
30 |
arrK() ( initial ) =
The macro below manipulates the contents of arrK() as per the question requirement, then pastes the modified array over the initial values
Sub ChangeSecondNumberAfterDecimalConditionally() ' http://www.excelfox.com/forum/showthread.php/2457-change-the-second-number-after-decimal-conditionally
Rem 1 Worksheets info
Dim Wb1 As Workbook
Set Wb1 = Workbooks("SAMPLE1 18Apr2020.xlsx") ' Workbooks("1.xls") ' CHANGE TO SUIT
Dim Ws1 As Worksheet
Set Ws1 = Wb1.Worksheets.Item(1)
Dim Lrow As Long
Let Lrow = Ws1.Range("A" & Ws1.Rows.Count).End(xlUp).Row ' http://www.excelfox.com/forum/showthread.php/2345-Appendix-Thread-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=11466&viewfull=1#post11466 Making Lr dynamic ( using rng.End(XlUp) for a single column. )
Rem 2 ranges of interest, D H and K , are placed in 1 column arrays, rows from 2 to Lrow
Dim arrD() As Variant, arrH() As Variant, ArrK() As Variant ' The .Value property used below returns its values in a field of variant type elements, so to avoiud a type mismatch we must Dim here appropriately
Let arrD() = Ws1.Range("D2:D" & Lrow & "").Value: Let arrH() = Ws1.Range("H2:H" & Lrow & "").Value: Let ArrK() = Ws1.Range("K2:K" & Lrow & "").Value
Rem 3 Manipulate arrK() as per requiremnt For all data rows, we compare column H to column D. If column H is greater than column D , then we adjust the value in column K up to the nearest multiple of .05. If column H is less than column D , then we adjust the value in column K down to the nearest multiple of .05. ( If the value in column K is an exact multiple of .05, then no action is to be taken ) http://www.excelfox.com/forum/showthread.php/2457-change-the-second-number-after-decimal-conditionally?p=13099&viewfull=1#post13099
Dim Cnt
For Cnt = 1 To Lrow - 1 ' range is row 2 to Lrow-1, array will be 1 to Lrow-1
If Int(Round((ArrK(Cnt, 1) / 0.05), 2)) - Round((ArrK(Cnt, 1) / 0.05), 2) = 0 Then
' do nothing because we have exact mulktiple of .05
Else ' case K is not an exact multiple of .05
If arrH(Cnt, 1) < arrD(Cnt, 1) Then
Let ArrK(Cnt, 1) = Int(ArrK(Cnt, 1) * 100 / 5) * 5 / 100 ' =INT(K2*100/5)*5/100 =K2*100/5 =INT(L2) =M2*5/100 =INT(L2)*5/100 =INT(K2*100/5)*5/100 http://www.excelfox.com/forum/showthread.php/2457-change-the-second-number-after-decimal-conditionally?p=13100&viewfull=1#post13100
ElseIf arrH(Cnt, 1) > arrD(Cnt, 1) Then
Let ArrK(Cnt, 1) = (Int(ArrK(Cnt, 1) * 100 / 5) * 5 / 100) + 0.05
Else ' case H = D
Let ArrK(Cnt, 1) = "H is equal to D"
Rem 4 Paste out modified array over original values
Let Ws1.Range("K2:K" & Lrow & "").Value = ArrK()
After running that macro the arrK() contents change to
And that is then pasted out into the range
| Row\Col |
K |
1 |
2 |
1090.65 |
3 |
147.95 |
4 |
264.5 |
5 |
30 |
