Page 15 of 38 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 380
Thread: Appendix Thread. ( Codes for other Threads, etc.) Event Coding Drpdown Data validation
  1. #141
    Sub TestieSimpleArraySort7() ( and Global variables and a required Function )
    Global variables should go at top of code module
    Dim Cms() As Variant, Rs() As Variant      ' "HorizointalColumn" Indicies  , "Virtical row" Indicies
    Dim RngToSort As Range                     ' Test data range
    Dim arrIndx() As Variant                   ' For modified array at end of each sort of a set of rows
    Dim arrOrig() As Variant                   ' This    arrIndx() = Application.Index(arrOrig(), Rs(), Cms())  applies the modified Rs() to the original unsorted data range. So we need an array to use constantly containing the original data range
    A required function
    Function CL(ByVal lclm As Long) As String 'Using chr function and Do while loop      For example http://www.excelforum.com/excel-programming-vba-macros/796472-how-to-go-from-column-number-to-column-letter.html
        Do
         Let CL = Chr(65 + (((lclm - 1) Mod 26))) & CL
         Let lclm = (lclm - (1)) \ 26
        Loop While lclm > 0
    Function FukOutChrWithDoWhile(ByVal lclm As Long) As String 'Using chr function and Do while loop      For example http://www.excelforum.com/excel-programming-vba-macros/796472-how-to-go-from-column-number-to-column-letter.html
    Dim rest As Long 'Variable for what is "left over" after subtracting as many full 26's as possible
        Do
        '    Let rest = ((lclm - 1) Mod 26) 'Gives 0 to 25 for Column Number "Left over" 1 to 26. Better than ( lclm Mod 26 ) which gives 1 to 25 for clm 1 to 25 then 0 for 26
        '    Let FukOutChrWithDoWhile = Chr(65 + rest) & FukOutChrWithDoWhile 'Convert rest to Chr Number, initially with full number so the "units" (0-25), then number of 26's left over (if the number was so big to give any amount of 26's in it, then number of 26's in the 26's left over (if the number was so big to give any amount of 26 x 26's in it, Enit ?
        '    'OR
        Let FukOutChrWithDoWhile = Chr(65 + (((lclm - 1) Mod 26))) & FukOutChrWithDoWhile
        Let lclm = (lclm - (1)) \ 26 'This gives the number of 26's ( if any ), but just the excact part, in the next number down , - so applying the rest formula to this new number will again leave a difference "left over" rest.
        'lclm = (lclm - (rest + 1)) \ 26 ' As the number is effectively truncated here, any number from 1 to (rest +1)  will do in the formula
        Loop While lclm > 0 'Only loop further if number was big enough to still have 0-25's in it
    '   https://www.excelforum.com/development-testing-forum/1101544-thread-post-appendix-no-reply-needed-please-do-not-delete-thanks-4.html#post4213887
    '   https://www.excelforum.com/tips-and-tutorials/1213798-all-sub-folder-and-file-list-from-vba-recursion-routine-explanation-and-method-comparison.html
    Test routine to Call main recursion routine ( given in next post )
    Rem 0 test data, worksheets info
    Dim WsS As Worksheet: Set WsS = ThisWorkbook.Worksheets("Sorting")
    ' Dim RngToSort As Range
     Set RngToSort = WsS.Range("R23:W37")
    ' Set RngToSort = Selection '                          ' Selection.JPG : https://imgur.com/HnCdBt8
    Dim arrTS() As Variant: Let arrTS() = RngToSort.Value ' We would have to use  .Value  for a range capture of this sort because  .Value  returns a field of Variant types.  But also at this stage we want to preserve string and number types
    ' Let arrIndx() = arrTS()
     Let arrOrig() = arrTS() ' This   Application.Index(arrOrig(), Rs(), Cms())  applies the modified Rs() to the original unsorted data range. So we need an array to use constantly containing the original data range
    ' Call SimpleArraySort7(1, arrTS(), " 1 2 3 4 5 ", " 1 Asc 2 Asc 3 Asc")
    ' Column Indicies
     Let Cms() = Evaluate("=Column(" & CL(1) & ":" & CL(RngToSort.Columns.Count) & ")")
     Let Cms() = Evaluate("=Column(A:F)")
    ' Initial row indicies
     Let Rs() = Evaluate("=Row(1:" & RngToSort.Rows.Count & ")")
    ' test index
     RngToSort.Offset(-1, 0).Resize(1, UBound(Cms())).Value = Cms()
     RngToSort.Offset(0, -1).Resize(UBound(Rs(), 1), UBound(Rs(), 2)).Value = Rs()
     RngToSort.Offset(RngToSort.Rows.Count, 0).Clear
     Let RngToSort.Offset(RngToSort.Rows.Count, 0).Value = Application.Index(arrTS(), Rs(), Cms())
    ' Let RngToSort.Offset(RngToSort.Rows.Count, 0).Value = Application.Index(arrIndx(), Rs(), Cms())
     RngToSort.Offset(RngToSort.Rows.Count, -1).Resize(UBound(Rs(), 1), UBound(Rs(), 2)).Value = Rs()
    Dim cnt As Long, strIndcs As String: Let strIndcs = " "
        For cnt = 1 To RngToSort.Rows.Count
         Let strIndcs = strIndcs & cnt & " "
        Next cnt
    Debug.Print strIndcs ' For 5 rows , for example we will have  " 1 2 3 4 5 " , for 15 rows  " 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 "
     Call SimpleArraySort7(1, arrTS(), strIndcs, " 1 Desc 3 Asc 5 Asc")
    Rem 2 Output for easy of demo
    ' 2a
     RngToSort.Offset(0, RngToSort.Columns.Count).Clear
     Let RngToSort.Offset(0, RngToSort.Columns.Count).Value = arrTS()
     Let RngToSort.Offset(0, RngToSort.Columns.Count).Interior.Color = vbYellow
    ' 2b VBA Range.Sort Method equivalent
    Dim TestRngSrt As Range: Set TestRngSrt = RngToSort.Offset(0, RngToSort.Columns.Count * 2)
     TestRngSrt.Clear
     Let TestRngSrt.Value = RngToSort.Value
     TestRngSrt.Sort Key1:=TestRngSrt.Columns("A:A"), order1:=xlDescending, Key2:=TestRngSrt.Columns("C:C"), order2:=xlAscending, Key3:=TestRngSrt.Columns("E:E"), order3:=xlAscending, MatchCase:=False
     TestRngSrt.Interior.Color = vbGreen
    Main recursion routine Sub SimpleArraySort7(
    Sub SimpleArraySort7(ByVal CpyNo As Long, ByRef arsRef() As Variant, ByVal strRws As String, ByVal strKeys As String)
    Dim CopyNo As Long: Let CopyNo = CpyNo ' On every recurssion run this will be increased by the Rec Call. This will be a local variable indicating the level down in recursion - I increase it by 1 at every Rec Call, that is to say each Rec Call gets given CopyNo+1  -  during a long tunnel down, the number at this pint will keep increasing to reflect how far down we are
        If CopyNo = 1 Then Debug.Print "First procedure Call"
    Rem -1 from the supplied  arguments, get all data needed in current bubble sort
    ' Column for this level sort , and Ascending or Descending - both determined from the supplied forth arguments and the column/ copy number
    Dim Keys() As String: Let Keys() = Split(Replace(Trim(strKeys), "  ", " ", 1, -1, vbBinaryCompare), " ", -1, vbBinaryCompare) ''      The extra replace allows for me seperating with one or two spaces  - the following would do if I only used one space always    Split(Trim(strKeys), " ", -1, vbBinaryCompare) ' this will be an array twice as big as the number of keys that we have
        If (2 * CopyNo) > UBound(Keys()) + 1 Then MsgBox Prompt:="You need more than " & (UBound(Keys()) + 1) / 2 & " keys to complete sort": Exit Sub ' case we have less keys then we need to sort, are array has twice as many elements as we have supplied keys since we have a key and whether it needs to get bigger or smaller , and array is from  0   so must add 1 to ubound then half it get the key number we gave.  We come here if the last column we gave as a Key had duplicates in it
    Dim GlLl As Long: If Keys((CopyNo * 2) - 1) = "Desc" Then Let GlLl = 1 ' (CopyNo * 2) - 1)  gives as we go down levels   1  3  5  7 etc  We're seeing if we had  Desc  for this column
    Dim Clm As Long: Let Clm = CLng(Keys((CopyNo * 2) - 2)) '              ' (CopyNo * 2) - 2)  gives as we go down levels   0  2  4  6 etc  We  are  picking  out  the  supplied   column to sort by for each level
    ' making an array from the " 3 4 5 6 " string is just for convenience later of getting the upper and lower row numbers
    Dim Rws() As String: Let Rws() = Split(Trim(strRws), " ", -1, vbBinaryCompare) ' We take the supplied sequential string   2 3 4 5 6   and make a 1 D array {1, 2, 3....} as it is a bit more conveniant to work with.  Actually we only need the start and top numbers so we could do it with stinr manipulation instead
    Rem 1 Simple Bubble Sort
    Dim rOuter As Long ' ========"Left Hand"=====================Outer Loop=====================================
        For rOuter = Rws(LBound(Rws())) To Rws(UBound(Rws()) - 1) ' For first row indicie to last but one row indicie
        Dim rInner As Long ' -------Inner Loop-------------"Right Hand"--------------------------
            For rInner = rOuter + 1 To Rws(UBound(Rws())) ' from just above left hand through all the rest
                If GlLl = 0 Then ' We want Ascending list
                    If IsNumeric(arsRef(rOuter, Clm)) And IsNumeric(arsRef(rInner, Clm)) Then ' Numeric case
                        If CDbl(arsRef(rOuter, Clm)) > CDbl(arsRef(rInner, Clm)) Then
                        Dim Temp As Variant ' I want to Swap those 2 above - I cant easilly in any coding change two values simulataneosly. So one of them Element values will put in this temporary place. This Element Values will then be given the other. Finally the other Element will be given this temporary value
                        Dim Clms As Long '-------| with the condition met  a loop is done for all columns in the array in which those two values used in the comparison are replaced at each column
                            For Clms = 1 To UBound(arsRef(), 2)
                             Let Temp = arsRef(rOuter, Clms): Let arsRef(rOuter, Clms) = arsRef(rInner, Clms): Let arsRef(rInner, Clms) = Temp
                            Next Clms '----------| for each column in the array at the two rows rOuter and rInner
                        Dim TempRs As Long
                         Let TempRs = Rs(rOuter, 1): Let Rs(rOuter, 1) = Rs(rInner, 1): Let Rs(rInner, 1) = TempRs
                     Else ' Non numeric case
                        If UCase(CStr(arsRef(rOuter, Clm))) > UCase(CStr(arsRef(rInner, Clm))) Then
                        'Dim TempRs As Long
                    End If ' End of numeric or text comparison
                Else ' GlLl is not 0 , so presumably we want Descending list
                        If CDbl(arsRef(rOuter, Clm)) < CDbl(arsRef(rInner, Clm)) Then
                        'Dim TempRs As Long
                    Else ' non numeric case
                        If UCase(CStr(arsRef(rOuter, Clm))) < UCase(CStr(arsRef(rInner, Clm))) Then
                        'Dim TempRs As Long
                End If ' End of Ascending or Descending example
            Next rInner ' ---------------------------------------------------------------------
        Next rOuter ' ===========================================================================================
     Debug.Print "Doing an arrIndx()"
     Let arrIndx() = Application.Index(arrOrig(), Rs(), Cms())
    ' Captains Blog, Start Treck
     RngToSort.Offset((RngToSort.Rows.Count * (CopyNo + 1)), 0).Clear               '   Area for array produced from previous method
     Let RngToSort.Offset((RngToSort.Rows.Count * (CopyNo + 1)), 0).Value = arsRef()
     RngToSort.Offset((RngToSort.Rows.Count * (CopyNo + 1)), RngToSort.Columns.Count).Clear    ' Area for array produced by Index method idea
     Let RngToSort.Offset((RngToSort.Rows.Count * (CopyNo + 1)), RngToSort.Columns.Count).Value = arrIndx()
     RngToSort.Offset((RngToSort.Rows.Count * (CopyNo + 1)), -1).Resize(UBound(Rs(), 1), UBound(Rs(), 2)).Clear
     Let RngToSort.Offset((RngToSort.Rows.Count * (CopyNo + 1)), -1).Resize(UBound(Rs(), 1), UBound(Rs(), 2)).Value = Rs() ' Current indicies order to apply to original range
     Debug.Print " Running Copy " & CopyNo & " of routine." & vbCr & vbLf & "  Sorted rows " & strRws & " based on values in column " & Clm & vbCr & vbLf & "   Checking now for Dups in that last sorted list" & vbCr & vbLf
    ' Rem 3 Determine any duplicates in sort column values , and re run the routine to sort them by another column
     Let rOuter = Rws(LBound(Rws())) - 1 ' we look for duplicates in the current list, in the loop below we add 1 each time so _ it  is necersarry to start 1 before,  so that +1 the first time is the start row
     Let strRws = "" ' ready for use in duplicate search
        Do ' Loop down the last set of sorted rows ****************************************************|
         Let rOuter = rOuter + 1 ' next row number        _ it was necersarry to start 1 before,  so that +1 the first time is the start row
            If strRws = "" Or Trim(strRws) = rOuter - 1 Then Let strRws = " " & rOuter & " " ' case starting again to get duplicates
            If Trim(UCase(CStr(arsRef(rOuter, Clm)))) = Trim(UCase(CStr(arsRef(rOuter + 1, Clm)))) Then ' case in duplicate rows
             Let strRws = strRws & rOuter + 1 & " " ' we building a list like   " 4 5 6 "  based on if the next is a duplicate value, which is determined by the last line
            Else ' when we did not have a next duplicate, we may have a few already grouped
                If Not InStr(1, Trim(strRws), " ", vbBinaryCompare) = 0 Then ' case we have at least 2 duplicates but have hit end of that list
                 Debug.Print "Found dups in last list column " & Clm & ", " & strRws & " , so now Rec Call 1" '     This is done for every duplicated value section, except if we have duplicates at the last lines
                 Call SimpleArraySort7(CopyNo + 1, arsRef(), strRws, strKeys) ' Rec Call 1  I need to sort the last duplicates
                 Let strRws = "" ' ready to try for another set of duplicates
            End If ' this is the end of the stuff in most situations...
            ' ...below section catches rows at the end that might need to be sorted. ......|
            If rOuter = UBound(arsRef(), 1) - 1 And Not InStr(1, Trim(strRws), " ", vbBinaryCompare) = 0 Then ' case of duplicates in last row
             Debug.Print "Found dups in last list, so now Rec Call 2 (Dups at list end case)"  ' Rec Call 2 - only done for duplicates at end of list
            End If  '...   ................................................................|
        Loop While rOuter <> Rws(UBound(Rws()) - 1) ' keep looking for Duplicates in next row**********|
    Sub TestieSimpleArraySort8() ( and Global variables and a required Function )
    Global variables required. ( Must go at top of code module )
    Dim Cms() As Variant, Rs() As Variant      ' "Horizointal Column" Indicies  , "Virtical row" Indicies
    A required function
        Do
        Loop While lclm > 0
        Do
        '    'OR
    Calling routine ( to call recursion routine in next post )
    ' Call SimpleArraySort8(1, arrTS(), " 1 2 3 4 5 ", " 1 Asc 2 Asc 3 Asc")
    ' Column Indicies
    ' test index
     RngToSort.Offset(RngToSort.Rows.Count, 0).ClearContents
        Next cnt
     Call SimpleArraySort8(1, arrTS(), strIndcs, " 1 Desc 3 Asc 5 Asc")
    ' 2a
     TestRngSrt.Clear
    Sub SimpleArraySort8(
    recursion routine Called by routine ( Sub TestieSimpleArraySort8() ) from last post
    ' Main recursion routine below : Bubble Sorting in Arrays using multi columns values for sort criteria
    Sub SimpleArraySort8(ByVal CpyNo As Long, ByRef arrIndx() As Variant, ByVal strRws As String, ByVal strKeys As String)
                    If IsNumeric(arrIndx(rOuter, Clm)) And IsNumeric(arrIndx(rInner, Clm)) Then ' Numeric case
                        If CDbl(arrIndx(rOuter, Clm)) > CDbl(arrIndx(rInner, Clm)) Then
    '                    Dim Clms As Long '-------| with the condition met  a loop is done for all columns in the array in which those two values used in the comparison are replaced at each column
                             Let Temp = arrIndx(rOuter, Clm): Let arrIndx(rOuter, Clm) = arrIndx(rInner, Clm): Let arrIndx(rInner, Clm) = Temp
                        Dim TempRs As Long
                        If UCase(CStr(arrIndx(rOuter, Clm))) > UCase(CStr(arrIndx(rInner, Clm))) Then
                        'Dim TempRs As Long
                        If CDbl(arrIndx(rOuter, Clm)) < CDbl(arrIndx(rInner, Clm)) Then
                        'Dim TempRs As Long
                        If UCase(CStr(arrIndx(rOuter, Clm))) < UCase(CStr(arrIndx(rInner, Clm))) Then
                        'Dim TempRs As Long
            If Trim(UCase(CStr(arrIndx(rOuter, Clm)))) = Trim(UCase(CStr(arrIndx(rOuter + 1, Clm)))) Then ' case in duplicate rows
                 Call SimpleArraySort8(CopyNo + 1, arrIndx(), strRws, strKeys) ' Rec Call 1  I need to sort the last duplicates
            If rOuter = UBound(arrIndx(), 1) - 1 And Not InStr(1, Trim(strRws), " ", vbBinaryCompare) = 0 Then ' case of duplicates in last row
    Coding for this excelfox Post:
    http://www.excelfox.com/forum/showth...ll=1#post11066
    Sub Call_Sub_Bubbles() ' Partially hard coded for ease of explanation
    ' data range info
    Dim RngToSort As Range: Set RngToSort = WsS.Range("B11:E16")
    Dim arrTS() As Variant ' array to be referred to in all recursion routines, initially the original data range
     Let Rs() = Evaluate("=Row(1:6)") '
    Dim strRows As String, Cnt As Long: Let strRows = " "
        For Cnt = 1 To 6
         Let strRows = strRows & Rs(Cnt, 1) & " "
    ' we should have now strRows = " 1 2 3 4 5 6 "
     Call Bubbles(1, arrTS(), strRows, " 1 Asc 3 Asc 2 Asc ")
    ' Demo output
     Let WsS.Range("B31").Resize(RngToSort.Rows.Count, RngToSort.Columns.Count).Value = arrTS()
    Sub Bubbles(ByVal CpyNo As Long, ByRef arsRef() As Variant, ByVal strRws As String, ByVal strKeys As String)
    Dim CopyNo As Long: Let CopyNo = CpyNo ' On every recurssion run this will be increased by the Rec Call. This will be a local variable indicating the level down in recursion - I increase it by 1 at every Rec Call, that is to say each Rec Call gets given CopyNo+1  -  during a long tunnel down, the number at this pint will keep increasing to reflect how far down we are.  This ensures we then have the correct value place at the start of any newly starting copy of the recursion routine, since the first copy of the recursion routine pauses and starts the second copy of the recursion routine, the second copy of the recursion routine pauses and starts the third copy of the recursion routine ….. etc…
    Dim Keys() As String: Let Keys() = Split(Replace(Trim(strKeys), "  ", " ", 1, -1, vbBinaryCompare), " ", -1, vbBinaryCompare) ''      The extra replace allows for me seperating with one or two spaces  - the following would do if I only used one space always    Split(Trim(strKeys), " ", -1, vbBinaryCompare) ' this will be an array twice as big as the number of keys that we have ...... ' Column for this level sort , and Ascending or Descending - both determined from the supplied forth arguments and the column/ copy number
        If (2 * CopyNo) > UBound(Keys()) + 1 Then Debug.Print "You need more than " & (UBound(Keys()) + 1) / 2 & " keys to complete sort": Exit Sub ' case we have less keys then we need to sort, are array has twice as many elements as we have supplied keys since we have a key and whether it needs to get bigger or smaller , and array is from  0   so must add 1 to ubound then half it get the key number we gave.  We come here if the last column we gave as a Key had duplicates in it
        'Dim GlLl As Long: If Keys((CopyNo * 2) - 1) = "Desc" Then Let GlLl = 1 ' (CopyNo * 2) - 1)  gives as we go down levels   1  3  5  7 etc  We're seeing if we had  Desc  for this column
    Rem 1 Bubble sort
        ' For rOuter = Rs(LBound(Rs(), 1), 1) To Rs(UBound(Rs(), 1), 1) - 1 ' THIS WOULD ONLY WORK FOR Copy No 1      For first row indicie to last but one row indicie - I could do this for copy 1
        For rOuter = Left(Trim(strRws), InStr(1, Trim(strRws), " ", vbBinaryCompare) - 1) To Right(Trim(strRws), Len(Trim(strRws)) - InStrRev(Trim(strRws), " ", -1, vbBinaryCompare)) - 1 '   ImmediteWindowToHelpGetAtStuff.JPG : https://imgur.com/yGqmYSu : http://www.eileenslounge.com/viewtopic.php?f=27&t=16407&p=247121#p247121
        'For rOuter = 1 To 5 ' For first run
            For rInner = rOuter + 1 To Rs(UBound(Rs(), 1), 1) ' from just above left hand through all the rest
            Next rInner ' -----------------------------------------------------------------------
    Rem 3 Preparation for possible recursion Call
    ' Catpains Blog
     Debug.Print " Running Copy No. " & CopyNo & " of routine." & vbCr & vbLf & "  Sorted rows " & strRws & " based on values in column " & Clm & vbCr & vbLf & "   Checking now for Dups in that last sorted list" & vbCr & vbLf
    Dim tempStr As String: Let tempStr = strRws ' Need this bodge because I set strRws="" below
     Let strRws = ""
        'For rOuter = Rs(LBound(Rs(), 1), 1) To Rs(UBound(Rs(), 1), 1) - 1  ' Only valis for first Copy No 1
        For rOuter = Left(Trim(tempStr), InStr(1, Trim(tempStr), " ", vbBinaryCompare) - 1) To Right(Trim(tempStr), Len(Trim(tempStr)) - InStrRev(Trim(tempStr), " ", -1, vbBinaryCompare)) - 1                                   '   ImmediteWindowToHelpGetAtStuff.JPG : https://imgur.com/yGqmYSu : http://www.eileenslounge.com/viewtopic.php?f=27&t=16407&p=247121#p247121
            If strRws = "" Or InStr(1, Trim(strRws), " ", vbBinaryCompare) = 0 Then Let strRws = " " & rOuter & " " ' case starting again to get duplicates
            'If strRws = "" Or Trim(strRws) = rOuter - 1 Then Let strRws = " " & rOuter & " " ' alternative
            Else '  without the last condition met, we might have the end of a group duplicate rows, in which case it would be time to organise a recursion run so ..... we check for this situation needing a recursion run
                If Not InStr(1, Trim(strRws), " ", vbBinaryCompare) = 0 Then ' case we have at least 2 duplicates but have hit end of that list ( we have at least one space between indices, like " 3 4 " , " 6 7 8" etc..  ---- this , " 2 " , on the other hand, would would not have a space after trimming off the end spaces )
                 ' Now its time to organise a recursion run
                 Debug.Print "Found dups in last list column " & Clm & ",  " & strRws & " ,  so now main Rec Call " '     This is done for every duplicated
                 Call Bubbles(CopyNo + 1, arsRef(), strRws, strKeys) ' Rec Call 1  I need to sort the last duplicates
                End If ' we did not have more than one indicie in strRws so usually that's it for this loop
            '+++*** this would be end of loop for most cases
             Debug.Print "Found dups in last rows of last list, so now Rec Call at end of loop (Dups at list end case)"  ' loop end rec call - only done for duplicates at end of list
        Next rOuter   '   **************************************************************************
     Debug.Print "Ending a copy, Copy level " & CopyNo & ""
    Sub BubblesIndexIdeaWay As Sub Bubble , just replacing name in three places
    Rem 1 Bubble sort
    ' Catpains Blog
     Let strRws = ""
    This intermadiate routine is simply Sub Bubbles(), with the name changed to Sub BubblesIndexIdeaWay(), and the two recursion Calling code lines changed from
    to
    Call BubblesIndexIdeaWay(CopyNo + 1, arsRef(), strRws, strKeys)
    Sub BubblesIndexIdeaWay(ByVal CpyNo As Long, ByRef arsRef() As Variant, ByVal strRws As String, ByVal strKeys As String)
    Rem 1 Bubble sort
    ' Catpains Blog
     Let strRws = ""
                 Call BubblesIndexIdeaWay(CopyNo + 1, arsRef(), strRws, strKeys) ' Rec Call 1  I need to sort the last duplicates
            '+++*** this would be end of loop for most cases ... but Oh Fuck
    'Oh Fuck' ...below section catches rows at the end that might need to be sorted. ......|
    Original test data range , ( B11:E16 )
    a
    b
    13
    c
    14
    d
    15
    e
    16
    f
    Worksheet: Sorting
    Added initial row and column indicees
    a
    b
    13
    c
    14
    d
    15
    e
    16
    f
    Worksheet: Sorting
  9. #149
    Sub Call_Sub_BubblesIndexIdeaWay()
    Calling routine required for previous Post and following Post
    Sub Call_Sub_BubblesIndexIdeaWay() ' Partially hard coded for ease of explanation
    ' data range info
    Dim arrTS() As Variant ' This is somewhat redundant for this version and could be replaced by arrOrig()
    ' Index idea variables
     Let Cms() = Evaluate("=Column(A:D)") ' Convenient way to get
     Let Rs() = Evaluate("=Row(1:6)") ' Initial row indicies
    ' Add initial indicies
     Let RngToSort.Offset(-1, 0).Resize(1, 4).Value = Cms(): RngToSort.Offset(-1, 0).Resize(1, 4).Font.Color = vbRed
     Let RngToSort.Offset(0, -1).Resize(6, 1).Value = Rs(): RngToSort.Offset(0, -1).Resize(6, 1).Font.Color = vbRed
    ' Initial row indicies from full original range´of rows
        For Cnt = 1 To 6
     Call BubblesIndexIdeaWay(1, arrIndx(), strRows, " 1 Asc 3 Asc 2 Asc ")
    ' Call BubblesIndexIdeaWay(1, arrIndx(), strRows, " 1 Asc ")
    ' Call BubblesIndexIdeaWay(1, arrIndx(), strRows, " 1 Asc 3 Asc ")
    ' Demo output
    Dim RngDemoOutput As Range: Set RngDemoOutput = WsS.Range("B31").Resize(RngToSort.Rows.Count, RngToSort.Columns.Count)
    ' Let WsS.Range("B31").Resize(RngToSort.Rows.Count, RngToSort.Columns.Count).Value = arrIndx()
     Let RngDemoOutput = arrIndx()
     Let RngDemoOutput.Offset(-1, 0).Resize(1, 4).Value = Cms(): RngToSort.Offset(-1, 0).Resize(1, 4).Font.Color = vbRed
     Let RngDemoOutput.Offset(0, -1).Resize(6, 1).Value = Rs(): RngToSort.Offset(0, -1).Resize(6, 1).Font.Color = vbRed
    Recursion routine for this post:
    http://www.excelfox.com/forum/showth...ll=1#post11078
    Rem 1 Bubble sort
                Dim TempRs As Long
        Next rOuter ' ==================End=Rem 1===============================================================
    ' Catpains Blog
     Let strRws = ""
                 Call BubblesIndexIdeaWay(CopyNo + 1, arrIndx(), strRws, strKeys) ' Rec Call 1  I need to sort the last duplicates
  1. Replies: 192
  2. Replies: 293
    Last Post: 09-24-2020, 01:53 AM
  3. Appendix Thread. Diet Protokol Coding Adaptions
  4. Restrict data within the Cell (Data Validation)
    By dritan0478 in forum Excel Help
    Last Post: 07-27-2017, 09:03 PM
