Thread: Mystery with Text formatted cell - Help
    Apr 2020
    Hello,
    I have a cell with Text format.
    If I write "- TestTest." (with a dash at the beginning and a dot at the end) and press Enter, no problem.
    If I select another cell, the address of this cell is written after the dot and the selected cell is surrounded by dashes like when you make a formula.
    It's a problem if it starts with "-", "+" or "=".
    I work with Excel 2010 and Excel 2013.
    Do you know if there is a way to avoid this, without having to manually enter a " ' " at the beginning?
    Although I would prefer to avoid the use of " ' ", I have tried to have a " ' " added automatically in Worksheet_Change and Worksheet_SelectionChange instances but it doesn't work
    Thanks! José
    Hello José,
    Welcome to ExcelFox
    I have two ways that I overcome these sorts of problems. I leave the cell as standard format , not text format.
    Then
    Either
    Leave a space, before writing
    Or
    Write what I want as a formula.
    So for your example, in a cell with standard format I would write exactly either of these two texts, ( remember the first one has a space before the - )
     - TestTest.
    ="- TestTest."
    I don’t know if there are any other ways to achieve what you want. I expect there might be, but I don’t know about them. Possibly someone else might have an idea later
    _...KILL A MODERATOR!!
  1. Counting font color of conditionally formatted cells
    By truckdriver in forum Excel Help
    Last Post: 05-22-2016, 03:50 AM
  2. Replies: 9
    Last Post: 01-12-2016, 11:30 AM
  3. VBA How to pass formatted text from Excel to MS Word
    By johnweber in forum Excel Help
    Last Post: 03-01-2015, 08:41 PM
  4. Replies: 5
    Last Post: 03-09-2013, 09:01 AM
  5. FORMATTED Flexible Concatenation Function
    Last Post: 10-14-2012, 03:48 PM
