Page 8 of 8 FirstFirst ... 678
Results 71 to 75 of 75
Thread: vba Copy Paste Conditional to put remark 1 2 3 .. etc
  1. #71
    Using new ( old ) account "Zaeguzah "
    https://www.excelforum.com/excel-pro...-the-data.html
    Hello Guys,
    Looking for a macro
    If column B of 1.xls matches with column A of Book1.xlsb & the difference between Column D of 1.xls & Column E of 1.xls is not greater than 0.50% of column D of 1.xls then put Remarks Else Clear the data from Column B of book1.xlsb
    Note:
    Macro will be placed in a book1.xlsb
    Sheet name can be anything
    Remarks means If condition met then finding the last row of book1.xlsb and add +1 to the data in the last row & put th result in next cell in that row
    clear data means if condition doesnt met then clear all the data in book1.xlsb in that row
    Plz see the output (it is the output of the macro)
    hlkhlhh
    Jul 2019
    Match data between sheet & pasting the output by adding +1
    I am looking for a macro that will do the things mentioned below
    If column E of sheet3 of 3.xlsm matches with sheet4 of Column B of 10.xlsx then match the same with column B of sheet1 of 3.xlsm & if matches then put the numerical data in series by vba in sheet1 of 3.xlsm
    Macro will be placed in 3.xlsm file
    Thnx Alot
    https://www.excelforum.com/excel-pro...dding-1-a.html
    Jul 2019
    Probelm Solved
    Thnx Alot
  5. #75
    Quote Originally Posted by fixer View Post
    Probelm Solved..
    You forgot ( again ) to tell us all how it was solved it and where you got the solution...
  1. Replies: 26
    Last Post: 09-26-2020, 05:56 PM
  2. VBA -- Copy/Paste across sheets
    Last Post: 09-21-2012, 02:07 PM
