Spare post for later use
if you can do it, Akan. so can I .... a spare post, i think I might need later
Molly
x
Hello, Need help regarding the macro
Code:Sub STEP29() Dim wb1 As Workbook, wb2 As Workbook, Ws1 As Worksheet, Ws2 As Worksheet Set wb1 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\Alert..csv") Set wb2 = ThisWorkbook Set Ws1 = wb1.Worksheets.Item(1): Set Ws2 = wb2.Worksheets.Item(1) Dim arr1() As Variant, arr2() As Variant, arr3() As Variant Let arr1() = Ws1.Range("A1:K" & Ws1.Range("A1").CurrentRegion.Rows.Count & "").Value Let arr2() = Ws2.Range("A1").CurrentRegion.Value ReDim arr3(0 To UBound(arr2(), 1)) Dim Cnt For Cnt = 2 To UBound(arr2(), 1) Dim Lc As Long: Let Lc = Ws2.Cells.Item(Cnt, Ws2.Cells.Columns.Count).End(xlToLeft).Column Let arr3(Cnt - 1) = Ws2.Range("A" & Cnt & ":" & CL(Lc + 1) & Cnt & "").Value Let arr3(Cnt - 1)(1, UBound(arr3(Cnt - 1), 2)) = UBound(arr3(Cnt - 1), 2) - 2 Dim mtchRes As Variant Let mtchRes = Application.Match(arr2(Cnt, 2), Ws1.Range("B1:B" & UBound(arr1(), 1) & ""), 0) If IsError(mtchRes) Then ' a match was not found, so we do not need to remove the 1 2 3 etc... Else ' a match was found, so we need to remove the 1 2 3 etc... Dim Empt As Long For Empt = 3 To UBound(arr3(Cnt - 1), 2) Let arr3(Cnt - 1)(1, Empt) = "" Next Empt End If '3c) Paste out row Let Ws2.Range("A" & Cnt & "").Resize(1, Lc + 1).Value = arr3(Cnt - 1) Next Cnt wb1.Close wb2.Save End Sub Public Function CL(ByVal lclm As Long) As String Do: Let CL = Chr(65 + (((lclm - 1) Mod 26))) & CL: Let lclm = (lclm - (1)) \ 26: Loop While lclm > 0 End Function
Actually i converted that Alert..csv file to Alert..xls
So I need the changes in the macro according to that
So Plz have a look and help me in solving this problem Sir
I am not quite sure what you are asking…
( Your macro above seems similar to some which I did for you ( https://excelfox.com/forum/showthrea...mark-1-2-3-etc ) )
Probably all you would need to do is use the File name of the File that you are using
Set wb1 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\Alert..xls")
But that is obvious. So possibly you are trying to ask something else.
( Of course, if you have been .Opening .csv text files with an Excel object, as in your macro above in post #1, ( https://excelfox.com/forum/showthrea...ll=1#post14144 ) then you may have got sometimes problems.
But I am not going to make any attempt to explain that to you, since I can see from your recent posts here and elsewhere that many people have tried very hard to explain that all to you, and you still don’t seem to have understood anything !!! )
Molly
Sorry let me explain once again Molly Mam
This macro is made for alert..csv file
But now alert..csv file is replaced with alert.xls
so the macro would be
Code:Sub STEP29() Dim wb1 As Workbook, wb2 As Workbook, Ws1 As Worksheet, Ws2 As Worksheet Set wb1 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\Alert.xls") Set wb2 = ThisWorkbook Set Ws1 = wb1.Worksheets.Item(1): Set Ws2 = wb2.Worksheets.Item(1) Dim arr1() As Variant, arr2() As Variant, arr3() As Variant Let arr1() = Ws1.Range("A1:K" & Ws1.Range("A1").CurrentRegion.Rows.Count & "").Value Let arr2() = Ws2.Range("A1").CurrentRegion.Value ReDim arr3(0 To UBound(arr2(), 1)) Dim Cnt For Cnt = 2 To UBound(arr2(), 1) Dim Lc As Long: Let Lc = Ws2.Cells.Item(Cnt, Ws2.Cells.Columns.Count).End(xlToLeft).Column Let arr3(Cnt - 1) = Ws2.Range("A" & Cnt & ":" & CL(Lc + 1) & Cnt & "").Value Let arr3(Cnt - 1)(1, UBound(arr3(Cnt - 1), 2)) = UBound(arr3(Cnt - 1), 2) - 2 Dim mtchRes As Variant Let mtchRes = Application.Match(arr2(Cnt, 2), Ws1.Range("B1:B" & UBound(arr1(), 1) & ""), 0) If IsError(mtchRes) Then ' a match was not found, so we do not need to remove the 1 2 3 etc... Else ' a match was found, so we need to remove the 1 2 3 etc... Dim Empt As Long For Empt = 3 To UBound(arr3(Cnt - 1), 2) Let arr3(Cnt - 1)(1, Empt) = "" Next Empt End If '3c) Paste out row Let Ws2.Range("A" & Cnt & "").Resize(1, Lc + 1).Value = arr3(Cnt - 1) Next Cnt wb1.Close wb2.Save End Sub Public Function CL(ByVal lclm As Long) As String Do: Let CL = Chr(65 + (((lclm - 1) Mod 26))) & CL: Let lclm = (lclm - (1)) \ 26: Loop While lclm > 0 End Function
Any more changes is required in this code then plz let me know Molly Mam
I think I understood already what you are asking.
I think you are still confused and mixed up because you have still not understood anything about the difference between Excel files and text files.
You sometimes tell us that you understand. But all your questions suggest to us that you still have not understood anything at all.
If I try to explain again, you will probably just get more confused or, more likely, you will not read or understand anything I tell you. So it will just waste all our time again.
Are you sure?
I do not think so.
Who made the macro for alert..csv file?
I did not make any macro for you to work on a text ( .csv ) file.
Who made this macro for you?
It looks very similar to macros which I made for you. But all the macros I made for you were for Excel files. I never made any macros for you to work with text files
If you are lucky,
may sometimes do the same as what you wantCode:Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\Alert.xls")
to do.Code:Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\Alert..csv")
So if you are lucky, that will be the only change that you need.
But it is very dangerous and stupid to ever do
( That code line is using the Excel object to .Open a text file. Excel is not really supposed to do that. Excel is mostly supposed to open Excel files. But Excel will allow you to try to open a text file. Excel will try to guess what to do. It may try to do what you want. Sometimes it may do different things. Many people have tried very hard to explain that in detail to you for 2 months already).
That code line may sometimes do what you want. But there will probably always be problems.
You seem to have decided not to want to know anything about such problems. So it may be impossible for anyone to really help you anymore.
Remember one last very important thing:
You are not the only person that understands nothing about the difference between Excel files and text files.
Lots of people understand nothing about the difference between Excel files and text files.
So if you continually cross post and ask the same question at different places, you will eventually find someone that will say to you.
…Yes, that is the only change needed .
So you will be happy then. But it is the wrong answer.
But that is your choice. You should do what you want to. You prefer a simple short answer, even if it is the wrong answer.
It is nice to have different people in this world. Stay as you want to be. (You will never achieve your aim, unless your aim is to fail and get the wrong results sometimes).
But you should stay as you want to be. The world would be very boring if we all were the same.
Good luck in your future failures!
Molly
I made a Mistake & I corrected My Mistake
I am not working with any .csv file
& In Future I will never Ask any question related to .csv file
Thnx Alot Molly Mam Doubts & Problem both are solved
Thnx Alot For Providing the Great Info Doc Sir & Molly Mam
Doc Sir Chill
Every Code is working Perfectly
I have no doubts in any Macro
Moderator Notice: This and the next 4 posts were posted here in the wrong place. I have left the copies here since the linked post has been referrenced already. I have also copied the posts to the correct place:
https://excelfox.com/forum/showthrea...ll=1#post14580
Code:Sub STEP6() Dim Ws1 As Worksheet, Ws2 As Worksheet Dim Wb1 As Workbook, Wb2 As Workbook Dim r2&, lr&, i& Set Wb1 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\1.xls") Set Ws1 = Wb1.Worksheets.Item(1) Set Wb2 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\Files\AlertCodes.xlsx") Set Ws2 = Wb2.Worksheets.Item(4) With Ws1 lr = .Cells(.Rows.Count, "I").End(xlUp).Row For i = 2 To lr ' Reset r2 r2 = 0 ' Avoid error messages On Error Resume Next ' Try to get r2 r2 = WorksheetFunction.Match(.Cells(i, "I"), Ws2.[B:B], 0) ' Restore error handling On Error GoTo 0 ' Only set column K if r2 is valid If r2 > 0 Then If Ws2.Cells(r2, "D") = ">" Then .Cells(i, "K").Value = .Cells(i, "D").Value - 0.01 * .Cells(i, "D").Value Else .Cells(i, "K").Value = .Cells(i, "D").Value + 0.01 * .Cells(i, "D").Value End If End If Next i End With Wb1.Save Wb1.Close Wb2.Close End Sub
This codes calculate 1% of column of column D of 1.xls
but what i wanted is instead of column D, it should calculate the data 1% with column E of AlertCodes.xlsx & add the calculated result with Column E of AlertCodes.xlsx and paste the result to same place where the current macro is putting,rest everything will be same
Kindly note AlertCodes.xlsx doesn't have headers so keep a eye on the same
Thnx for the Help
https://eileenslounge.com/viewtopic....271443#p271443
https://chandoo.org/forum/threads/vb...rection.44637/
Moderator Notice: This post was posted here in the wrong place. I have left the copy here since the linked post has been referrenced already. I have also copied this and the related reply posts to the correct place, starting here:
You almost had it right here: https://eileenslounge.com/viewtopic....6a1745#p271427
You were close to correct.
I try to explain again what Hans tried to explain ( I think you almost understood ):
__With Ws1
…………………. Cells(i, "E") ……… .Cells(i, "E")
__End With
is almost =
.....Ws1.Cells(i, "E") …… Ws1.Cells(i, "E")
You want Ws2 ( for Alertcodes.xlsx ) , not Ws1
Maybe like
This will also be the sameCode:Wtih Ws1 If Ws2.Cells(r2, "D") = ">" Then 'calculate the data 1% with column E of AlertCodes.xlsx & add the calculated result with Column E of AlertCodes.xlsx .Cells(i, "K").Value = Ws2.Cells(i, "E").Value - 0.01 * Ws2.Cells(i, "E").Value Else .Cells(i, "K").Value = Ws2.Cells(i, "E").Value + 0.01 * Ws2.Cells(i, "E").Value End If End With
If this does not work, then you must explain again exactly what you want the macro to do.Code:If Ws2.Cells(r2, "D") = ">" Then 'calculate the data 1% with column E of AlertCodes.xlsx & add the calculated result with Column E of AlertCodes.xlsx Ws1.Cells(i, "K").Value = Ws2.Cells(i, "E").Value - 0.01 * Ws2.Cells(i, "E").Value Else Ws1.Cells(i, "K").Value = Ws2.Cells(i, "E").Value + 0.01 * Ws2.Cells(i, "E").Value End If
is 'calculate the data 1% with column E of AlertCodes.xlsx & add the calculated result with Column E of AlertCodes.xlsx
This was wrong:
Ws2.Cells(i, "E").Value - 0.01 *.Cells(i, "E").Value
Ws2.Cells(i, "E").Value + 0.01 * .Cells(i, "E").Value
It is 'calculate the data 1% with column E of AlertCodes.xlsx & add the calculated result with Column E of 1.xls
It is the same as
Ws2.Cells(i, "E").Value - 0.01 *Ws1.Cells(i, "E").Value
Ws2.Cells(i, "E").Value + 0.01 * Ws1.Cells(i, "E").Value
( I never use
__ With
__ End With
because it confuses me.
But lots of other people, like Hans do use it. Everyone writes codes a bit differently, because all VBA codes can be written in many ways. )
Also
Have you seen this ? : https://excelfox.com/forum/showthrea...4565#post14565
Your macro , Sub STEP6() from here
https://excelfox.com/forum/showthrea...ll=1#post14562
and here
https://eileenslounge.com/viewtopic....271385#p271385
has the wrong Lr2
