Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 75
Thread: vba Copy Paste Conditional to put remark 1 2 3 .. etc
    Jul 2019
    Sub STEP7() '
    Rem 1 Worksheets info
    Dim Wbm As Workbook, Ws1 As Worksheet, Ws2 As Worksheet, Ws3 As Worksheet
     Set Wbm = Workbooks.Open(ThisWorkbook.Path & "\Merge.xlsx")
     Set Ws1 = Wbm.Worksheets("Sheet1"): Set Ws2 = Wbm.Worksheets("Sheet2"): Set Ws3 = Wbm.Worksheets("Sheet3")
    Rem 2 data Input
    Dim arrS1() As Variant, arrS2() As Variant, arrS3() As Variant
     Let arrS1() = Ws1.Range("A1").CurrentRegion.Value: arrS2() = Ws2.Range("A1").CurrentRegion.Value
    '2b
     ReDim arrS3(1 To UBound(arrS1(), 1)) ' A 1 dimension array of arrays
    ''2b(i)
    ' Let arrS3(1) = Ws3.Range("A" & Ws3.Range("A1").CurrentRegion.Columns.Count & "") ' header row as a one dimensional array
    ''2b(ii) data rows array output
    Rem 3
    Dim cnt
        For cnt = 2 To UBound(arrS1(), 1) '  "row" count, cnt
        '2b)(ii)
        Dim Lc As Long: Let Lc = Ws3.Cells.Item(cnt, Ws3.Cells.Columns.Count).End(xlToLeft).Column ' last column in this row cnt
         Let arrS3(cnt) = Ws3.Range("A" & cnt & ":" & CL(Lc + 1) & cnt & "").Value ' - returns an array of 1 "row" into this element of the array of arrays
         Select Case arrS1(cnt, 9) ' column I
          Case "SELL" 'If column I is sell
            If arrS1(cnt, 11) > arrS2(cnt, 5) Then ' if column K is Greater than sheet2 of column E then
            Ws3.Range("B" & cnt & ":" & CL(Lc) & cnt & "").Cells.ClearContents
            Let arrS3(cnt)(1, UBound(arrS3(cnt), 2)) = UBound(arrS3(cnt), 2) - 1 ' Put in a value in last array "column"
          Case "BUY"  'If column I is buy
           If arrS1(cnt, 11) < arrS2(cnt, 6) Then  ' if column K is lower than sheet2 of column F then
        '3b) output "row"
         Let Ws3.Range("A" & cnt & "").Resize(1, Lc + 1).Value = arrS3(cnt)
        Next cnt
    Rem 4    ....and after putting the remark clear sheet 1 and sheet 2
     Ws1.Cells.ClearContents
     Ws2.Cells.ClearContents
     Wbm.Save
     Wbm.Close
    'then see the value of column K &
    'if column K is Greater than sheet2 of column E then put the remark in sheet3 in the stock name from column B
    'If column I is buy
    'see the value of column K &
    'if column K is lower than sheet2 of column F then put the remark in sheet3 in the stock name from column B
    'remark will be in series like 1,2,3,4,5,6 and so on
    'vba is palced in a separate file
    'all files are located in same place
    'and after putting the remark clear sheet 1 and sheet 2
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=Ugw3nF0C04AGt73H1BB4AaABAg.9h6VhNCM-DZ9h7EqbG23kg
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwGTEyefOX7msIh1wZ4AaABAg.9h4sd6Vs4qE9h7KvJXmK 8o
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=Ugw3nF0C04AGt73H1BB4AaABAg.9h6VhNCM-DZ9h7E1gwg4Aq
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgywFtBEpkHDuK55r214AaABAg
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwviLabd7r_3KpP6wh4AaABAg.9h5lFRmix1R9h79hNGvJ bu
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwviLabd7r_3KpP6wh4AaABAg.9h5lFRmix1R9h79YAfa2 4T
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwviLabd7r_3KpP6wh4AaABAg.9h5lFRmix1R9h79M1SYH 1E
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwviLabd7r_3KpP6wh4AaABAg.9h5lFRmix1R9h78SxhXT nR
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwviLabd7r_3KpP6wh4AaABAg.9h5lFRmix1R9h78GftO_ iE
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg.9h740K6COOA9h77HSGDH 4A
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg.9h740K6COOA9h76fafzc EJ
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg.9h740K6COOA9h759YIjl aG
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg.9h740K6COOA9h74pjGcb Eq
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgzJJUDVv2Mb6YGkPYh4AaABAg.9h5uPRbWIZl9h7165DZd jg
  2. #22
    The data is being cleared, But it is being put back in!
    To explain:-
    These two code lines clear the range when the condition is not met
    Ws3.Range("B" & cnt & ":" & CL(Lc) & cnt & "").ClearContents
    This next code line puts all the data in. It does this after the Select Case / End Select
    Because it does this after the Select Case / End Select, the code line will be done both when the condition is met and when the condition is not met.
    So , the range is being cleared if the condition is not met. But it is then being re filled.
    The ranges are filled from the array, arrS3(Cnt)
    There are two possibilities to overcome this problem.
    _1 empty the array , ( instead of clearing the range )
    Dim Cnt As Long, Clms As Long
        For Cnt = 2 To UBound(arrS1(), 1) '  "row" count, cnt
        '2b)(ii)
        Dim Lc As Long: Let Lc = Ws3.Cells.Item(Cnt, Ws3.Cells.Columns.Count).End(xlToLeft).Column ' last column in this row cnt
         Let arrS3(Cnt) = Ws3.Range("A" & Cnt & ":" & CL(Lc + 1) & Cnt & "").Value ' - returns an array of 1 "row" into this element of the array of arrays
         Select Case arrS1(Cnt, 9) ' column I
          Case "SELL" 'If column I is  SELL
            If arrS1(Cnt, 11) > arrS2(Cnt, 5) Then ' if column K is Greater than column E of sheet2 Then
            ' Condition not met ... clear the data from cloumn B till the end of the data in that entire row
            ' Ws3.Range("B" & Cnt & ":" & CL(Lc) & Cnt & "").ClearContents
                For Clms = 2 To Lc
                 Let arrS3(Cnt)(1, Clms) = ""
                Next Clms
            ' Condition is met
            Let arrS3(Cnt)(1, UBound(arrS3(Cnt), 2)) = UBound(arrS3(Cnt), 2) - 1 ' Put in a value in last array "column"
          Case "BUY"  'If column I is  BUY
           If arrS1(Cnt, 11) < arrS2(Cnt, 6) Then  ' if column K is lower than column F of sheet2 Then
           ' Condition is not met ....clear the data from cloumn B till the end of the data in that entire row
                For Clms = 2 To Lc
                Next Clms
           ' Condition is met
    '    '3b) output "row"
         Let Ws3.Range("A" & Cnt & "").Resize(1, Lc + 1).Value = arrS3(Cnt)
    OR:-
    _ 2 Use the code line which puts in all the data for the met condition within the Select Case / End Select
    Rem 3
        '2b)(ii)
            ' Condition is met
           ' Condition is met
    ''    '3b) output "row"
    '     Let Ws3.Range("A" & Cnt & "").Resize(1, Lc + 1).Value = arrS3(Cnt)
    Jul 2019
    Thnx Alot Doc Sir and Molly Sir
    Thnx for ur Great Support sir
  4. #24
    You are welcome.
    ( Molly is a Lady ( Woman ) - She is not a Sir, She is a Ma'am or Madam )
    Thank you Molly, Ma'am
    Sir - Man
    Ma'am - Woman
    Jul 2019
    Thnx Doc Sir & Molly Mam For the Great Help
  6. #26
    Glad you got the answer eventually
  7. #27
    Jul 2019
    copy paste conditional
    If column B of 2.xlsm match with column B of 1.xls then paste the data from column C of 2.xls as 1,2,3,4,5 and so on....
    If column B of 2.xlsm doesn't match with column B of 1.xls then delete all the data from column C of that row
    macro will be placed in 2.xlsm
    all files re located in different path
    sheet name can be anything
    plz see the sample file
    Hello Vixer.
    This is similar to what I did for you before, I think.
    Here I have some new explanations for you Here
    http://www.excelfox.com/forum/showth...ll=1#post13165
    http://www.excelfox.com/forum/showth...ll=1#post13164
    Before:
    _____ Workbook: 1.xlsx ( Using Excel 2007 32 bit )
    NSE
    25
    50000
    NSE
    22
    10000
    NSE
    15083
    70000
    NSE
    17388
    20000
    NSE
    100
    170000
    Worksheet: Sheet1 (4)
    _____ Workbook: 2.xlsm ( Using Excel 2007 32 bit )
    Symbol
    ACC
    22
    ADANIENT
    25
    ADANIPORTS
    15083
    ADANIPOWER
    17388
    AMARAJABAT
    100
    ASIANPAINT
    236
    Worksheet: Sheet1
    now, run macro from here:
    http://www.excelfox.com/forum/showth...ll=1#post13166
    After results
    Symbol
    ACC
    22
    ADANIENT
    25
    ADANIPORTS
    15083
    ADANIPOWER
    17388
    AMARAJABAT
    100
    ASIANPAINT
    236
    Worksheet: Sheet1
    Molly
    Jul 2019
    Yes Molly Mam Actually it requires the modification to increase the output
    Sorry for the same Mam But in future there will not be any question similar to this
  10. #30
    No need to apologise, I was just making a passing remark, that’s all
    It was easy for me to do , because of the simularities to the previous Thread, that's all
  1. Replies: 26
    Last Post: 09-26-2020, 05:56 PM
  2. VBA -- Copy/Paste across sheets
    Last Post: 09-21-2012, 02:07 PM
