Try this
Code:Option Explicit Public Sub DuplicateSheetMultipleTimes() Dim wsUsrs As Worksheet: Set wsUsrs = ThisWorkbook.Worksheets("List of User") Dim wsMstr As Worksheet: Set wsMstr = ThisWorkbook.Worksheets("Master") Dim rngStr As Range, rngUsrs As Range Set rngUsrs = wsUsrs.Range("A1:A" & wsUsrs.Cells.Item(wsUsrs.Rows.Count, 1).End(xlUp).Row & "") For Each rngStr In rngUsrs wsMstr.Copy After:=ThisWorkbook.Worksheets.Item(ThisWorkbook.Worksheets.Count) Let ActiveSheet.Name = rngStr.Value Next rngStr ' Dim n As Integer ' On Error Resume Next ' n = InputBox("How many copies of the active sheet do you want to make?") ' ' If n >= 1 Then ' For numtimes = 1 To n ' ActiveSheet.Copy After:=ActiveWorkbook.Sheets(Worksheets.Count) ' Next ' End If End Sub
