PcMax
I can get both ListView and Treeview working - the problem is their long term stability. Since they both are unstable - I have decided to replace them both. But I have not found a component that has the functionality I use in TreeView.
So I am looking for a componet that will replace TreeView. Right now I will be using a combination of ListBox onjects - which is not pretty.
Rasm
