Thread: Replacement for TreeView
    Apr 2011
    All
    I have been using both ListView & TreeView - but the 'MSComctlLib' or the common controls in the OCX is unstable - they are a real nightmare - especially if you develop on PCs with different OS.
    So I am now using a ListBox to replace my ListView - its ok.
    But I am wondering what is a good alternative for TreeView - I show the TreeView with Nodes. I do allow selection of multiple nodes - so I need like checkboxes or something to indicate what is selected.
    Any comments will be appreciated.
    I would prefer not to use a third party add-in or OCX - But I will if I have to.
    Rasm
    xl2007 - Windows 7
    xl hates the 255 number
    Oct 2011
    Attachment 158Hi,
    I only use Excel 2003, but may include:
    First I would try to add the references of the objects used in VBA.
    Then follow the instructions of the Annex and enables the two voices.
    Note: I first turn of this procedure using the Listview I had complete control (for example, lacked the sort column)
    Apr 2011
    PcMax
    I can get both ListView and Treeview working - the problem is their long term stability. Since they both are unstable - I have decided to replace them both. But I have not found a component that has the functionality I use in TreeView.
    So I am looking for a componet that will replace TreeView. Right now I will be using a combination of ListBox onjects - which is not pretty.
    Rasm
    xl2007 - Windows 7
  1. UDF (user defined function) replacement for Excel's DATEDIF function
    Last Post: 03-07-2015, 09:47 PM
  2. Replacement for the Flawed UsedRange Property
    Last Post: 12-04-2012, 08:09 PM
  3. TreeView Use With Database
    By Rasm in forum Download Center
    Last Post: 04-13-2011, 07:34 AM
