Results 11 to 20 of 30
Thread: Tests and Notes for EMail Threads
  1. #11
    In support of this Forum Thread answers
    https://stackoverflow.com/questions/...-less-and-less
    https://stackoverflow.com/questions/...56971#59756971
    https://stackoverflow.com/questions/...longer-working
    CDO Message Email Sending accounts work less and less
    I don't have a full solution yet, but a workable fix. This post is sharing the fix that I am currently using. I expect the problem that I have had may become an increasing one as time goes on, so someone may benefit from this answer.
    There are two main parts to the solution, _1 and _2 , which I summarise below, along with some other notes, _3
    _1 Collect and list valid Email accounts
    _1 Collect and list valid Email accounts from various providers and note the various CDO Message Configuration/Settings. Do this by registering accounts and/or if possible ask people if they have any spare accounts they no longer need. It seems that older existing accounts have often a more likely chance to work. Add that data to a Calling program of the form of my Program_(i) …..
    _2 Program solution
    _2(i) Program_(ii)
    Rewrite a typical hard coded CDO Message sending program thus: The main Message sending program should be converted to a function, taking in the Username, Password and the various CDO Message Configuration/Settings that you need for a typical CDO Message send macro. It attempts to .Send an Email with those configuration parameters. It builds up a single long string, CunFikaNation, containing all the configuration parameters of any successful accounts
    _2(ii) Program_(i)
    The initial calling program might in the practice be very large containing all the accounts I have collected from time to time. For demo purposes here I have done a small representative sample of the providers I have tested so far. ( I have changed/ disguised only the passwords and usernames. All the configuration parameters are those that I am using. Also, I have left the provider bit after @ in the username as it really is, so as to make it easier to see to which provider the configuration parameters apply )
    In my actual work, I would add to that first macro and / or re run it from time to time to get an updated list on accounts that are likely to work successfully.
    _2(iv) Program_(iv)
    Finally a similar program to _2(ii) is set off by the calling program _2(iii).
    _2(iii) Program_(iii)
    This uses the recently obtained long string containing the CDO relevant details of all the successful working accounts, CunFikaNation , Calling Program_(vi) , each time with the next account details until a successful .Send is achieved.
    In the practice, Programs _(iii) and _(iv) would be my actual real life macros and would be doing what I finally want to do. This would be sending a message contain various things from text files and excel files , both in the Email main body, and attached to the mail. In this demo version, it just sends a simple message…..
    "Hi from xxxxxx@somemail.com,"
    " Testing automated EMail sending. Please ignoor this EMail"
    _3 Some further notes about Email Providers.
    This is just based on my recent limited experience.
    gmail : A few strange problems here, associated with the Less Secure Apps setting and related warnings thing.. This is reported in an answer to another recent Thread : https://stackoverflow.com/questions/...95299#59695299
    If using gmail you are going to have to get used to continually re setting manually the Less Secure Apps setting, and continually being contacted to check the validity of the account use. These problems seem to reduce if you are regularly using the account from the same location
    Yandex : Somewhat random results, blocked half the time. Will often work when the program is run from the location at which the account was registered.
    Yahoo : I cannot get any accounts to work
    Outlook : I cannot get any accounts from here to work. In addition, the accounts when used manually are prone to problems/bugs. This seems to be increasingly typical in Microsoft stuff
    AOL : I cannot get any accounts to work
    Gmx : These work well, but then the accounts are often blocked. Contacting their support usually clears this problem. So it is like an indirect longer way around version of the gmail "warning/ On / Off less secure App" thing.
    German Telekom : Currently consistently working the best, even with new accounts. As per Sod's Law an important function available by most providers, forwarding incoming mail, is not available, but a workaround to that works reliably. ( That is the subject of another Forum Thread answer http://www.excelfox.com/forum/showth...ll=1#post11554 )
    ( Note: German Telekom have a very quirky working .From accepted syntax. This can be exploited to make spam mails look genuine. I have done extensive test with this and reported it to German Telekom https://telekomhilft.telekom.de/t5/E...4229774#M72110 )
    Spammers are also using my results very effectively.
    _._______________________________
    Demo macros
    ( In all the coding I have replaced the real EMail addresses and passwords with made up ones)
    Here below is a version of the sort of thing I am talking about. In this particular demo example I am using a global variable, CunFikaNation , to store account info. (I am just doing that so as to make the demo version a bit more flexible for anyone wanting to try it. In my own work in Excel. I prefer to store things like that in a spare worksheet range, usually in a single cell
    CunFikaNation is a simple string, but it has the account CDO configuration parameters separated by a space, and that information for multiple accounts is separated by a vbCr & vbLf, so you end up with a CunFikaNation string, for example for a gmail account and a German telekom account looking like this
        "xxxx@t-online.de 123456789 True 1 securesmtp.t-online.de 2 465 30 xxxx@t-online.de
    	yyyyyy@gmail.com 12345678 True 1 smtp.gmail.com 2 465 30 yyyyyy@gmail.com"
    Or in other words like:
        "xxxx@t-online.de" & " " & "123456789" & " " & "True" & " " & "1" & " " & "securesmtp.t-online.de" & " " & "2" & " " & "465" & " " & "30", xxxx@t-online.de & vbCr & vbLf & "yyyyy@gmail.com" & " " & "12345678" & " " & "True" & " " & "1" & " " & "smtp.gmail.com" & " " & "2" & " " & "25" & " " & "30" & " " & "yyyyy@gmail.com"
    By the way, that final form above can also be obtained from my coding. That final form can then be hard coded into a final macro. (This is one of the final solutions that I use in my final CDO message .Sending coding).
    Another practical way to store that string is in a worksheet cell. In my demo coding , both the above forms are pasted out, one in cell A1 and the other in Cell B1
    Just to clarify that, we are talking about like, in the case of the gmail account details, this is the configuration parameter details:
        ……."smtpusessl" = "True" '
         ……. "smtpauthenticate" = 1
        '  ' Sever info
         ……………  "smtpserver" = "smtp.gmail.com" '
        '  The mechanism to use to send messages.
        …………"sendusing") = 2
         ……….."smtpserverport" = 465 ' 25 ' 587
         ………. "sendusername" = "yyyyy@gmail.com"    '
         ………."sendpassword" = "12345678"
        ' Optional - How long to try
         .Configuration(LCD_CW & "smtpconnectiontimeout") = 30
    and the extra last parameter I use in the string is the .From , which for simplicity I am taking in the demo coding as just the Email address
        .From = "yyyyy@gmail.com"
    The practical use idea of my fix
    The VBA strings collection Split function can be used within the third macro, firstly to split by the vbCr & vbLf to get all the accounts, and then it can be used again to split by the spaces , " " , to get the CDO message send configuration parameters for each account.
    The first couple of macros, are what I would use to test out a lot of different Email accounts. I would probably add a spare account as the receiver , in other words, like in the second macro, pseudo :
    	.To = "AnySpareAccount@anyprovider.com"
    The first few times I run the first macro , I would probably see if I can get any non working sendusername/sendpassword accounts to work. For example I would check manually the security settings of any non working accounts from gmail or Gmx to see if the first attempts have resulted in the accounts being blocked.
    The final run of the first macro, will cause my full long string, CunFikaNation , to be filled with the configuration parameters of what are likely to be working accounts. ( CunFikaNation is set to "" each time the first macro is run, and also a text file with that string is made, or if already present, then overwritten with this string as its content
    In my actual final files I have then
    Either
    a string stored in a worksheet with the configuration parameters of a lot of what are likely to be working accounts ,
    alternatively , anther pair of macros, referenced at the end of my coding can be used to convert the entire text string from the text file into a code line which I hard code into my main CDO sending macro.
    The third and forth macros are of the form of my final coding used in my final files. When attempting to send an Email , it goes through the list while a Boolean variable , VlagaMir, remains at the value of 0. That variable is Referred to in the CDO Mail send macro and is set to True as soon as a mail .Send has been successful
    In the sample coding I have masked the real Email Username and Email Passwords , but the other configuration parameters are what I use. Usually in the test I did, The German Telekom accounts always work. Mostly the gmail , GMX and Yandex I could get to work , but I often need to fiddle around with them to get them to work, as mentioned in _3
    There is nothing new or special in this solution , its all fairly simple coding, but it may be useful to someone in the future using the CDO Message type sending coding. My guess is that providers may have to tighten up their security and account blocking software , so relying on a single address and provider may not be a reliable solution
    The coding is in the next 4 posts, ( and also here, if some wierdo their has not deleted it, https://stackoverflow.com/questions/...56971#59756971 )
  2. #12
    kxXKal
    https://www.youtube.com/watch?v=bRd4mJglWiM&lc=UgxRmh2gFhpmHNnPemR4AaABAg.A0opm95t2XEA0q3Kshmu uY
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314619#p314619
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314600#p314600
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314599#p314599
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314274#p314274
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314229#p314229
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314195#p314195
    https://www.eileenslounge.com/viewtopic.php?f=36&t=39706&p=314110#p314110
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40597&p=314081#p314081
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40597&p=314078#p314078
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=314062#p314062
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40597&p=314054#p314054
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313971#p313971
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313909#p313909
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40574&p=313879#p313879
  3. #13
    ( I have changed the EMail Addresses and Passwords to fake ones. But the configuration parameters are those which I am using )
    [code][color=black]Option Explicit
    ''_-(ii) "sendusername" , "sendpassword" , "smtpusessl" , "smtpauthenticate" , "smtpserver" , "sendusing" , "smtpserverport" , "smtpconnectiontimeout"
    'Sub ScrudOverFlowDemolition(ByVal UsrNme As String, ByVal PssWrd As String, ByVal SlutPussly As String, ByVal PatheticCake As String, ByVal ServiceChef As String, ByVal WayntkerUsed As String, ByVal ConnectingDoor As String, ByVal WaitSecs As String, ByVal Snd_Frm As String)
    Dim CunFik() As String ' CDO Account configuration
    Dim CunFikaNation As String ' CDO Account configurations, CunFik(x)s seperated by vbCr & vbLf is "sendusername" "sendpassword" "smtpusessl" "smtpauthenticate" "smtpserver" "sendusing" "smtpserverport" "smtpconnectiontimeout"
    '_- Program_(i)
    ' ( '_-(ii) ScrudOverFlow..("sendusername","sendpassword","smtpusessl","smtpauthenticate","smtpserver","sendusing","smtpserverport","smtpconnectiontimeout", .From )
    Sub TestCall_ScrudOverFlowDemolition()
    Let CunFikaNation = ""
    Rem 1 Collect of accounts and their configuration parameters
    ' gmail
    Call ScrudOverFlowDemolition("12345678901@gmail.com", "hkjhddhdkjdhakj", "True", "1", "smtp.gmail.com", "2", "465", "30", "ExcelVBAExp@gmail.com")
    Call ScrudOverFlowDemolition("1234567890@gmail.com", "oqowzriqwzrizorz", "True", "1", "smtp.gmail.com", "2", "465", "30", "mail2taste@gmail.com")
    Call ScrudOverFlowDemolition("1234567890@gmail.com", "sjshfskjhkjhkjh", "True", "1", "smtp.gmail.com", "2", "25", "30", "mail2taste@gmail.com")
    Call ScrudOverFlowDemolition("123456789012345@gmail.com", "kjhKJDHkjdhAKJDHAD", "True", "1", "smtp.gmail.com", "2", "465", "30", "excellearning12@gmail.com")
    Call ScrudOverFlowDemolition("123456789012345@gmail.com", "lKAHDKAKDHdkh", "True", "1", "smtp.gmail.com", "2", "465", "30", "JaneAmbrose1958@gmail.com")
    Call ScrudOverFlowDemolition("123456789@gmail.com", "hfashsafhskjhah", "True", "1", "smtp.gmail.com", "2", "465", "30", "CDOMsgExp@gmail.com")
    Call ScrudOverFlowDemolition("123456789@gmail.com", "lkasfjlkasjfalksjfaslkfj", "True", "1", "smtp.gmail.com", "2", "25", "30", "CDOMsgExp@gmail.com")
    ' Yandex
    Call ScrudOverFlowDemolition("1234567890123456@yandex.com", "goiowxrhposfulfq", "True", "1", "smtp.yandex.com", "2", "465", "30", "developmentstest@yandex.com")
    Call ScrudOverFlowDemolition("1234567890123456@yandex.com", "ahetlyqkymthpglq", "True", "1", "smtp.yandex.com", "2", "465", "30", "developmentstest@yandex.com")
    Call ScrudOverFlowDemolition("12345678901@yandex.com", "9664989931a", "True", "1", "smtp.yandex.com", "2", "465", "30", "CDOMsgScrot@yandex.com")
    ' Yahoo
    Call ScrudOverFlowDemolition("123456789@yahoo.com", "ashfasklhasha", "True", "1", "smtp.mail.yahoo.com", "2", "465", "30", "yangsfool@yahoo.com")
    ' Outlook
    Call ScrudOverFlowDemolition("12345678901234@Outlook.com", "saslkfaslkfaslkfflksafjh*", "True", "1", "smtp-mail.outlook.com", "2", "587", "30", "MollyBrennholz@Outlook.com")
    Call ScrudOverFlowDemolition("1234567890123@Outlook.com", "slshfkshfshfhs", "True", "1", "smtp-mail.outlook.com", "2", "587", "30", "excellearning@Outlook.com")
    'Call ScrudOverFlowDemolition("1234567890123@Outlook.com", "lKHDhdlkdhhddh", "True", "1", "smtp-mail.outlook.com", "2", "465", "30", "1234567890123@Outlook.com") ' This line takes a long time
    ' GMX
    Call ScrudOverFlowDemolition("1234567890@gmx.net", "asfhasklfhkfhsklfh", "True", "1", "mail.gmx.net", "2", "465", "30", "GiMiCDOMsg@gmx.net")
    Call ScrudOverFlowDemolition("123456789012@gmx.net", "assjhasjkdhdkhasdh", "True", "1", "mail.gmx.net", "2", "465", "30", "Doc.AElstein@gmx.net")
    Call ScrudOverFlowDemolition("12345@gmx.com", "ssshfhfasf", "True", "1", "mail.gmx.com", "2", "465", "30", "Vixer@gmx.com")
    ' AOL
    Call ScrudOverFlowDemolition("123456789@aol.com", "kjshkjashfkjsahf", "True", "1", "smtp.aol.com", "2", "587", "30", "aliarseol@aol.com")
    ' German Telekom
    Call ScrudOverFlowDemolition("12345@t-online.de", "khflksflksfhashffskfh", "True", "1", "securesmtp.t-online.de", "2", "465", "30", "Jayae@t-online.de")
    Call ScrudOverFlowDemolition("1234567890@t-online.de", "lkklshflhffhsfh", "True", "1", "securesmtp.t-online.de", "2", "465", "30", "CDOMsgTest@t-online.de")
    Call ScrudOverFlowDemolition("1234567890123@t-online.de", "kADHadhkhadhakjdh", "True", "1", "securesmtp.t-online.de", "2", "465", "30", "CDOMsgScrotum@t-online.de")
    If CunFikaNation <> "" Then Let CunFikaNation = Left(CunFikaNation, Len(CunFikaNation) - 2) ' I do not need the last vbCr & vbLf
    Rem 2 Store the final string Configuration parameters
    ' 2a) In the Immediate window
    Debug.Print CunFikaNation
    ' 2b) Send CunFikaNation to a text file, ( the file will be made if it does not exist, or it will be overwritten if it does exist
    Dim Highway2 As Long: Let Highway2 = FreeFile(0) [color=darkgreen]'range 1
    lkjxALKDLKJ
    https://eileenslounge.com/viewtopic.php?p=317050&sid=d7e077e50e904a138c794e1f2115da95#p317050
    [code][color=black]' https://stackoverflow.com/questions/58525487/excel-vba-cdo-message-email-sending-accounts-work-less-and-less?noredirect=1#comment103375857_58525487
    ' ' Allow access to deep down cods wollops from Microsoft to collaborating in particular in the form of messaging. An available library of ddl library functions and associated things is available on request, the Microsoft CDO for Windows 2000. We require some of these ' CDO is an object library that exposes the interfaces of the Messaging Application Programming Interface (MAPI). API: interfaces that are fairly easy to use from a fairly higher level from within a higher level programming language. In other words this allows you to get at and use some of the stuff to do with the COM OLE Bollocks from within a programming language such as VBA API is often referring loosely to do with using certain shipped with Windows software in Folders often having the extension dll. This extension , or rather the dll stands for direct link libraries. These are special sort of executable files of functions shared by many other (Windows based usually) software's.
    '_- Program_(ii) "sendusername" , "sendpassword" , "smtpusessl" , "smtpauthenticate" , "smtpserver" , "sendusing" , "smtpserverport" , "smtpconnectiontimeout"
    'Rem1 The deep down fundamental stuff , which includes stuff been there the longest goes by the name of Component Object Model. Stuff which is often, but not always, later stuff, or at a slightly higher level of the computer workings, or slightly more to a specific application ( an actual running "runtime" usage / at an instance in time , "instance of" ) orientated goes to the name of Object Linking and Embedding. At this lower level, there are protocols for communicating between things, and things relate are grouped into the to Office application available Library, CDO. An important object there goes by the name of Message.
    'Rem 1) Library made available ====================#
    With CreateObject("CDO.Message") ' Folders mostly but not always are in some way referenced using dll, either as noted with the extension or maybe refered to as dll Files or dll API files.
    'Rem 2 ' Intraction protocols are given requird infomation and then set
    '2a) 'With --------------------* my Created LCDCW Library, (LCD 1.0 Library ) (Linking Configuration Data_Cods Wollups) which are used and items configured for the Exchange at Microsoft's protocol thereof; http://schemas.microsoft.com/cdo/configuration/ ......This section provides the configuration information for the remote SMTP server
    Dim LCD_CW As String: Let LCD_CW = "http://schemas.microsoft.com/cdo/configuration/" ' Linking Configuration Data : defines the majority of fields used to set configurations for various Linking Collaboration (LCD) Objects Cods Wollops: These configuration fields are set using an implementation of the IConfiguration.Fields collection. https://msdn.microsoft.com/en-us/library/ms872853(v=exchg.65).aspx
    .Configuration(LCD_CW & "smtpusessl") = SlutPussly ' ' ' HTTPS (Hyper Text Transfer Protocol Secure) appears in the URL when a website is secured by an SSL certificate. The details of the certificate, including the issuing authority and the corporate name of the website owner, can be viewed by clicking on the lock symbol on the browser bar. in short, it's the standard technology for keeping an internet connection secure and safeguarding any sensitive data that is being sent between two systems, preventing criminals from reading and modifying any information transferred, including potential personal details. ' SSL protocol has always been used to encrypt and secure transmitted data
    .Configuration(LCD_CW & "smtpauthenticate") = PatheticCake ' ... possibly this also needed .. When you also get the Authentication Required Error you can add this three lines.
    ' ' Sever info
    .Configuration(LCD_CW & "smtpserver") = ServiceChef ' "smtp.gmail.com" ' "securesmtp.t-online.de" '"smtp.gmail.com" "smtp.mail.yahoo.com" "smtp.live.com" "pod51017.outlook.com" "smtp-mail.outlook.com" "smtp.live.com" "securesmtp.t-online.de" 465 SMTP is just used to mean the common stuff..... Simple Mail Transport Protocol (SMTP) server is used to send outgoing e-mails. The SMTP server receives emails from your Mail program and sends them over the Internet to their destination.
    .Configuration(LCD_CW & "sendusing") = WayntkerUsed ' Based on the LCD_OLE Data Base of type DBTYPE_I4 , 2 will use the default account
    .Configuration(LCD_CW & "smtpserverport") = ConnectingDoor ' 465 or 25 for t-online.de ' 465 'or 587 'or 25 ' The port of type somehow refered to by the last line
    .Configuration(LCD_CW & "sendusername") = UsrNme ' .... "server rejected your response". AFAIK : This will happen if you haven't setup an account in Outlook Express or Windows Mail .... Runtime error '-2147220975 (800440211)': The message could not be sent to the SMTP server. The transport error code is 0x80040217. The server response is not available
    .Configuration(LCD_CW & "sendpassword") = PssWrd
    ' Optional - How long to try ( End remote SMTP server configuration section )
    .Configuration(LCD_CW & "smtpconnectiontimeout") = 30 ' Or there Abouts
    ' Intraction protocol is Set/ Updated
    .Configuration.fields.Update ' 'Not all infomation is given, some will have defaults. - possibly this might be needed initially .. .Configuration.Load -1 ' CDO Source Defaults
    'End With ' -------------------* my Created LCDCW Library ( Linking Configuration Data Cods Wollups) which are used and items configured for the Exchange at Microsoft's protocol therof;
    '2b) ' Data to be sent
    .to = "123456789012@t-online.de"
    .CC = "" ' 1234567890@gmail.com"
    .BCC = ""
    .From = Snd_Frm '
    .Subject = "Hello from " & UsrNme & "" '
    .TextBody = "Hi" & vbCr & vbLf & "Testing automated EMail sending. Please ignoor this EMail"
    ' add header for this Account in log text file.
    Dim Highway1 As Long: Let Highway1 = FreeFile(0) [color=darkgreen]'range 1
    LCJÖSJSÖJ
    [code][color=black]' NOTE: This is an extra macro that can be used to fill the global variable, CunFikaNation . This can be useful in development since the global variable is often emptied. It is also useful for checking error handling in the next coding, since you can modify the text file, then refil the global variable , CunFikaNation from it
    Sub GetthelastCunFikaNation()
    DJJDASO
    [code][color=black]
    ' '_- Program_(iv)
    Sub CDOSendMailAttempt(ByRef FlagerMe As Boolean, ByVal UsrNme As String, ByVal PssWrd As String, ByVal SlutPussly As String, ByVal PatheticCake As String, ByVal ServiceChef As String, ByVal WayntkerUsed As String, ByVal ConnectingDoor As String, ByVal WaitSecs As String, ByVal Snd_Frm As String)
    ' ' Sever info
    .BCC = ""
    .From = Snd_Frm ' """Avinash_gMail_Send"" <" & UsrNme & ">"
    .Subject = "Hello from " & UsrNme & "" ' "Pro für " & DieseArbeitsmappe1.LisWbProWb.Name
    '.HTMLBody = MyLengthyStreaming
    '.htmlbody = ProTble
    ' Add text file attachments
    ' make file if it does not exist, or add to it
    CJKÖLSC
  3. Table Tests. And Thread Copy Tests No Reply needed
  4. Replies: 9
    Last Post: 07-02-2013, 06:59 PM
  5. Send Lotus Notes Email Using VBA
    Last Post: 09-08-2011, 09:00 AM
