Results 1 to 10 of 49
Thread: Copy and Paste based on comparisons/Match and calculations of cells in two workbooks
  1. #36
    Jul 2019
    Macro Correction(iF Condition match then replace the data)
    Hi Experts,
    I am looking for a macro that will do the below things
    Plz see the sample file
    there are 3 files ap.xls & BasketOrder.xlsx & macro.xlsm (macro will be placed in macro.xlsm),both files are located in different places so the path will be hardcoded in the macro so that i can change it as per my needs
    sheet name can be anything
    If column J is BUY of BasketOrder.xlsx then add 1% of column O of ap.xls to column O of ap.xls and compare column O of ap.xls with column L of BasketOrder.xlsx and if column O of ap.xls is smaller than column L of BasketOrder then replace column L of BasketOrder data with column O of ap.xls data(with that added 1% of column O of ap.xls) else do nothing
    Or
    If column J is SELL of BasketOrder.xlsx then subtract 1% of column P of ap.xls to column P of ap.xls and compare column P of ap.xls with column L of BasketOrder.xlsx and if column P of ap.xls is Greater than column L of BasketOrder then replace column L of BasketOrder data with column P data of ap.xls (with that subtract 1% of column P of ap.xls) else do nothing
    Thnx for the Help
    macro will be placed in a seperate file
    This macro i have for this problem but some issue is there
    Sub STEP8()
        Dim wb1 As Workbook
        Dim wb2 As Workbook
        Dim ws1 As Worksheet
        Dim ws2 As Worksheet
        Dim TempValue As Double
        Dim RowCount1 As Integer
        Dim ColumnCount1 As Integer
        Dim RowCount2 As Integer
        Dim ColumnCount2 As Integer
        Dim BOmyArray() As Variant
        Dim APmyArray() As Variant
        BOExcellFilePath = "C:\Users\WolfieeeStyle\Desktop\WolfieeeStyle\9.15\Files\BasketOrder.xlsx"
        APExcellFilePath = "C:\Users\WolfieeeStyle\Desktop\ap.xls"
        Set wb1 = Workbooks.Open(Filename:=APExcellFilePath)
        Set ws1 = wb1.Sheets(1)
        RowCount1 = ws1.UsedRange.Rows.Count
        ColumnCount1 = ws1.UsedRange.Columns.Count
        APmyArray = ws1.Range("A1:U" & ColumnCount1).Value
        wb1.Close SaveChanges:=False
        Set wb1 = Nothing
        Set wb2 = Workbooks.Open(Filename:=BOExcellFilePath)
        Set ws2 = wb2.Sheets(1)
        RowCount2 = ws2.UsedRange.Rows.Count
        ColumnCount2 = ws2.UsedRange.Columns.Count
        BOmyArray = ws2.Range("A1:Y" & ColumnCount2).Value
        For i = 1 To RowCount2
        TempValue = 0
            For j = 2 To RowCount1
                If (APmyArray(j, 5) = BOmyArray(i, 3)) Then
                  If (BOmyArray(i, 10) = "BUY") Then
                      If (APmyArray(i + 1, 15) <> "") Then
                          TempValue = APmyArray(i + 1, 15) + APmyArray(i + 1, 15) * 0.01
                          If (TempValue < BOmyArray(i, 12)) Then
                              ws2.Activate
                              ws2.Cells(i, 12).Value = TempValue
                  ElseIf (BOmyArray(i, 10) = "SELL") Then
                          TempValue = APmyArray(i + 1, 15) - APmyArray(i + 1, 15) * 0.01
                          If (TempValue > BOmyArray(i, 12)) Then
                              ws2.Activate
        wb2.Save
        wb2.Close
  1. Replies: 85
  2. Copy paste data based on criteria
  3. Replies: 4
    Last Post: 12-12-2013, 06:16 PM
  4. Replies: 8
    Last Post: 02-11-2013, 08:13 PM
