Results 1 to 10 of 49
Thread: Copy and Paste based on comparisons/Match and calculations of cells in two workbooks
  1. #26
    You almost had it right here: https://eileenslounge.com/viewtopic....6a1745#p271427
    You were close to correct.
    I try to explain again what Hans tried to explain ( I think you almost understood ):
    __With Ws1
    . Cells(i, "E") ……… .Cells(i, "E")
    __End With
    is almost =
    .....Ws1.Cells(i, "E") …… Ws1.Cells(i, "E")
    You want Ws2 ( for Alertcodes.xlsx ) , not Ws1
    Maybe like
               Wtih Ws1
                    If Ws2.Cells(r2, "D") = ">" Then 'calculate the data 1% with column E of AlertCodes.xlsx & add the calculated result with Column E of AlertCodes.xlsx
                        .Cells(i, "K").Value = Ws2.Cells(i, "E").Value - 0.01 * Ws2.Cells(i, "E").Value
                        .Cells(i, "K").Value = Ws2.Cells(i, "E").Value + 0.01 * Ws2.Cells(i, "E").Value
    This will also be the same
                        Ws1.Cells(i, "K").Value = Ws2.Cells(i, "E").Value - 0.01 * Ws2.Cells(i, "E").Value
                        Ws1.Cells(i, "K").Value = Ws2.Cells(i, "E").Value + 0.01 * Ws2.Cells(i, "E").Value
    If this does not work, then you must explain again exactly what you want the macro to do.
    is 'calculate the data 1% with column E of AlertCodes.xlsx & add the calculated result with Column E of AlertCodes.xlsx
    This was wrong:
    Ws2.Cells(i, "E").Value - 0.01 *.Cells(i, "E").Value
    Ws2.Cells(i, "E").Value + 0.01 * .Cells(i, "E").Value
    It is 'calculate the data 1% with column E of AlertCodes.xlsx & add the calculated result with Column E of 1.xls
    It is the same as
    Ws2.Cells(i, "E").Value - 0.01 *Ws1.Cells(i, "E").Value
    Ws2.Cells(i, "E").Value + 0.01 * Ws1.Cells(i, "E").Value
    ( I never use
    __ With
    __ End With
    because it confuses me.
    But lots of other people, like Hans do use it. Everyone writes codes a bit differently, because all VBA codes can be written in many ways. )
    Also
    Have you seen this ? : https://excelfox.com/forum/showthrea...4565#post14565
    Your macro , Sub STEP6() from here
    https://excelfox.com/forum/showthrea...ll=1#post14562
    and here
    https://eileenslounge.com/viewtopic....271385#p271385
    has the wrong Lr2
  1. Replies: 85
  2. Copy paste data based on criteria
  3. Replies: 4
    Last Post: 12-12-2013, 06:16 PM
  4. Replies: 8
    Last Post: 02-11-2013, 08:13 PM
