Results 1 to 10 of 49
Thread: Copy and Paste based on comparisons/Match and calculations of cells in two workbooks
  1. #11
    This is a similar , shortened version of the question here: ( http://www.excelfox.com/forum/showth...centage-by-vba )
    Quote Originally Posted by fixer View Post
    file name is sample1.xlsx
    compare column O is greater or column P is greater
    if column O is greater then calculate the 0.50% of column O and after getting the 0.50% of column O multiply the same with column L and paste the result in column Y
    and if column P is greater then calculate the 0.50% of column P and after getting the 0.50% of column P multiply the same with column L and paste the result in column Y
    save the changes and close the file
    Example
    Before:
    _____ Workbook: sample1.xlsx ( Using Excel 2007 32 bit )
    K
    L
    M
    N
    O
    P
    Q
    R
    S
    T
    U
    V
    W
    X
    Y
    Z
    Column L Column O Column P Column Y
    Worksheet: Tabelle1
    After running routine, Sub Vixer2()
    K
    L
    M
    N
    O
    P
    Q
    R
    S
    T
    U
    V
    W
    X
    Y
    Z
    Worksheet: Tabelle1
    ' Option Explicit
    ' file name is sample1.xlsx
    ' compare column O is greater or column P is greater
    ' if column O is greater then calculate the 0.50% of column O and after getting the 0.50% of column O multiply the same with column L and paste the result in column Y
    ' if column P is greater then calculate the 0.50% of column P and after getting the 0.50% of column P multiply the same with column L and paste the result in column Y
    ' save the changes and close the file
    Sub Vixer2() ' http://www.excelfox.com/forum/showthread.php/2352-calculation-and-multiply-by-vba
    Rem 1 Workbook and worksheets info
    Dim Wb1 As Workbook: Set Wb1 = Workbooks("sample1.xlsx") ' Set using workbooks collection object of open files
    Dim Ws1 As Worksheet: Set Ws1 = Wb1.Worksheets.Item(1) ' First worksheet, (as worksheet object) in open file "sample1.xlsx"
    Dim Lr1 As Long, Lr2 As Long
     Let Lr1 = 4: Lr2 = 4 ' For this example I am using just three rows of data, and a header
    Rem 3 Main Loop for all data rows
    Dim Cnt As Long ' Main Loop for all data rows ================================================
        ' 3a)(i) ' compare column O is greater or column P is greater
        For Cnt = 2 To Lr1
        Dim Bigger As Double
            If Ws1.Range("O" & Cnt & "").Value > Ws1.Range("P" & Cnt & "").Value Then ' if column O is greater
             Let Bigger = Ws1.Range("O" & Cnt & "").Value
             Let Bigger = Ws1.Range("P" & Cnt & "").Value ' if column P is greater
        '3a)(ii) calculate the 0.50% of that and multiply the same with column L
        Dim Rslt As Double '
         Let Rslt = Bigger * (0.5 / 100) * Ws1.Range("L" & Cnt & "").Value ' calculate the 0.50% of that and multiply the same with column L
        '3b) paste the result to sample1.xlsx column Y
         Let Ws1.Range("Y" & Cnt & "").Value = Rslt
        Next Cnt '     Main Loop for all rows =====================================================
    Rem 4 save the changes and close the file
     Wb1.Close savechanges:=True
  1. Replies: 85
  2. Copy paste data based on criteria
  3. Replies: 4
    Last Post: 12-12-2013, 06:16 PM
  4. Replies: 8
    Last Post: 02-11-2013, 08:13 PM
