Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: Copy and Paste based on comparisons/Match and calculations of cells in two workbooks
  1. #31
    Moderator Notice...
    Here we go again cycle number 3 , slightly different strategy, posting almost the same question in a few cross posts, then juggling around , passing given macros from one place to the other to give the impression of having done something himself.....
    https://chandoo.org/forum/threads/if...9/#post-266341
    https://eileenslounge.com/viewtopic.php?f=30&t=34937
    https://eileenslounge.com/viewtopic.php?f=30&t=34936
    https://www.excelforum.com/excel-pro...o-nothing.html https://excelfox.com/forum/showthrea...ll=1#post13495
    I am not sure if I understand exactly what you want.
    If Application.Match does not find a match, then the code line does not error, instead it returns an error string.
    We can use IsError( ) to tell us if an error string has been returned. This will be True if an error string is detected in the ( )
    Possibly you want this
         Let MtchRes = Application.Match(arrWs1(Cnt, 9), ClmB(), 0)
            If IsError(MtchRes) Then ' No match was found
             Let arrS1(Cnt, 10) = "delete word"
            Else ' A match was found
                If arrWsA4(MtchRes, 4) = ">" Then
                 Let arrS1(Cnt, 10) = "SHORT"
                ElseIf arrWsA4(MtchRes, 4) = "<" Then
                 Let arrS1(Cnt, 10) = "BUY"
    If that is not what you want, then provide a file or files to show me what you want
    P.S:
    IsError( ) does not tell you if a code line has eroded. If a code line errors, then the macro will stop and you will get an error pop up to tell you about the error.
    Application.Match will return either
    _ a number telling you the position along where it finds in the second argument what you have in the first argument ( Application.Match( First argument , second argument , 0 ) In other words it returns you the position along of the match
    _ an error string if it does not find a match
    Note also:
    WorksheetFunction.Match works a bit differently. If it does not find a match then it will error. I expect your next 50 duplicated cross posted questions will come when a macro you have with that in does not work….
    .... Edit: For example didn't take long... https://eileenslounge.com/viewtopic....271335#p271335
    Last edited by DocAElstein; 07-09-2020 at 10:56 PM. Reason: Didnt take him long to start duplicate cross posting chaos again.https://eileenslounge.com/viewtopic.php?p=271335#p271335
    Jul 2019
    Thnx Alot Doc Sir for helping me in solving this problem
    Problem Solved
    Have a Great Day
  3. #33
    Jul 2019
    Macro Correction
    Sub STEP6()
        Dim Ws1 As Worksheet, Ws2 As Worksheet
        Dim Wb1 As Workbook, Wb2 As Workbook
        Dim r2&, lr&, i&
        Set Wb1 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\1.xls")
        Set Ws1 = Wb1.Worksheets.Item(1)
        Set Wb2 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\Files\AlertCodes.xlsx")
        Set Ws2 = Wb2.Worksheets.Item(4)
        With Ws1
            lr = .Cells(.Rows.Count, "I").End(xlUp).Row
            For i = 2 To lr
                ' Reset r2
                r2 = 0
                ' Avoid error messages
                ' Try to get r2
                r2 = WorksheetFunction.Match(.Cells(i, "I"), Ws2.[B:B], 0)
                ' Restore error handling
                ' Only set column K if r2 is valid
                If r2 > 0 Then
                    If Ws2.Cells(r2, "D") = ">" Then
                        .Cells(i, "K").Value = .Cells(i, "D").Value - 0.01 * .Cells(i, "D").Value
                        .Cells(i, "K").Value = .Cells(i, "D").Value + 0.01 * .Cells(i, "D").Value
            Next i
        Wb1.Save
        Wb1.Close
        Wb2.Close
    This codes calculate 1% of column of column D of 1.xls
    but what i wanted is instead of column D, it should calculate the data 1% with column E of AlertCodes.xlsx & add the calculated result with Column E of AlertCodes.xlsx and paste the result to same place where the current macro is putting,rest everything will be same
    Kindly note AlertCodes.xlsx doesn't have headers so keep a eye on the same
    Thnx for the Help
    https://eileenslounge.com/viewtopic....271443#p271443
    https://chandoo.org/forum/threads/vb...rection.44637/
  4. #34
    You almost had it right here: https://eileenslounge.com/viewtopic....6a1745#p271427
    You were close to correct.
    I try to explain again what Hans tried to explain ( I think you almost understood ):
    __With Ws1
    . Cells(i, "E") ……… .Cells(i, "E")
    __End With
    is almost =
    .....Ws1.Cells(i, "E") …… Ws1.Cells(i, "E")
    You want Ws2 ( for Alertcodes.xlsx ) , not Ws1
    Maybe like
               Wtih Ws1
                    If Ws2.Cells(r2, "D") = ">" Then 'calculate the data 1% with column E of AlertCodes.xlsx & add the calculated result with Column E of AlertCodes.xlsx
                        .Cells(i, "K").Value = Ws2.Cells(i, "E").Value - 0.01 * Ws2.Cells(i, "E").Value
                        .Cells(i, "K").Value = Ws2.Cells(i, "E").Value + 0.01 * Ws2.Cells(i, "E").Value
    This will also be the same
                        Ws1.Cells(i, "K").Value = Ws2.Cells(i, "E").Value - 0.01 * Ws2.Cells(i, "E").Value
                        Ws1.Cells(i, "K").Value = Ws2.Cells(i, "E").Value + 0.01 * Ws2.Cells(i, "E").Value
    If this does not work, then you must explain again exactly what you want the macro to do.
    is 'calculate the data 1% with column E of AlertCodes.xlsx & add the calculated result with Column E of AlertCodes.xlsx
    This was wrong:
    Ws2.Cells(i, "E").Value - 0.01 *.Cells(i, "E").Value
    Ws2.Cells(i, "E").Value + 0.01 * .Cells(i, "E").Value
    It is 'calculate the data 1% with column E of AlertCodes.xlsx & add the calculated result with Column E of 1.xls
    It is the same as
    Ws2.Cells(i, "E").Value - 0.01 *Ws1.Cells(i, "E").Value
    Ws2.Cells(i, "E").Value + 0.01 * Ws1.Cells(i, "E").Value
    ( I never use
    __ With
    __ End With
    because it confuses me.
    But lots of other people, like Hans do use it. Everyone writes codes a bit differently, because all VBA codes can be written in many ways. )
    Also
    Have you seen this ? : https://excelfox.com/forum/showthrea...4565#post14565
    Your macro , Sub STEP6() from here
    https://excelfox.com/forum/showthrea...ll=1#post14562
    and here
    https://eileenslounge.com/viewtopic....271385#p271385
    has the wrong Lr2
    Jul 2019
    Thnx Alot Soc Sir for helping me in solving this problem Sir
    Problem Solved
    Have a Great Day
    No Doc Sir this problem is not solved yet
    i am sending the sample file with output in next 10 min
  6. #36
    Jul 2019
    Plz run the macro and see the output Doc Sir
    I was at job at that time & so that's y mistake happened
    macro will be placed in a seperate file
    _1) What macro are you using? ( I got confused with all your similar duplicated cross postings )
    _2) Remind me again. What exactly should the macro do? ( I see the output in file, but please also explain again in words what is going on, because I got confused with all your similar duplicated cross postings )
    ( I have time first tomorrow to look again. So take your time and make sure you have correct files, and all infomation correct!! )
    Jul 2019
    If column I of 1.xls matches with column B of Alertcodes.xlsx & column D has < this then calculate the 1% of of column E & add that 1% to column E & the result which will come it will be pasted to column K of 1.xls
    If column I of 1.xls matches with column B of Alertcodes.xlsx & column D has > this then calculate the 1% of of column E & subtract that 1% to column E & the result which will come it will be pasted to column K of 1.xls
    sheet name can be anything
    macro will be placed in macro.xlsm
  9. #39
    You didn't answer one of my questions...
    _1) What macro are you using?....)
    post the macro you are using....
    Quote Originally Posted by fixer View Post
    Plz run the macro and see the output....
    what macro shall I run??
    Jul 2019
    Sub STEP6()
        Dim r2&, lr&, i&
        With Ws1
            For i = 2 To lr
                ' Reset r2
                r2 = 0
                ' Try to get r2
                If r2 > 0 Then
            Next i
        Wb1.Save
        Wb1.Close
        Wb2.Close
  1. Replies: 85
  2. Copy paste data based on criteria
  3. Replies: 4
    Last Post: 12-12-2013, 06:16 PM
  4. Replies: 8
    Last Post: 02-11-2013, 08:13 PM
