Thread: Extract Data From Text File Using VBA
    May 2019
    I am stuck and looking for assistant. I am importing only certain data from a text file, but because the number of lines changes with the dealers, I am getting overlapping data (incorrect). The code I am using has a 'For i = 1 to 30' statement and this is causing (I think) my problem. I would like to replace it, or a section of code, to stop when the word 'TOTAL' appears and then go to the next dealer. Below is my current code, and thank you in advance.
    Option Base 1
    Dim TextLine As String
    Dim FileToOpen, A(11) As Variant
    Dim c, R As Long
    Dim xLast_Row As Long, xLast_Col As Long, I As Integer
    Reset 'Close any open text files
      ' Display the File*Open dialog box
        FileToOpen = Application.GetOpenFilename( _
            fileFilter:="Text Files (*.txt), *.txt", _
            Title:="Open the FCAN6245-R1 DEALER MODEL LINE ANALYSIS text file")
        If FileToOpen = False Then End
        xLast_Row = ActiveSheet.Range("A1").SpecialCells(xlLastCell).Row
        xLast_Col = ActiveSheet.Range("A1").SpecialCells(xlLastCell).Column
        If xLast_Row = 1 Then xLast_Row = 2
        Range("A2:K55000").ClearContents 'Clear old data
        Open FileToOpen For Input As #1 'Open the text file
        'Set-up row count.
        R = 1
        Do While Not EOF(1)
            Line Input #1, TextLine 'Get next line from text file
            'Skip until Page 2.
            If InStr(1, TextLine, "REPORT NO. FCAN6245-R1", vbTextCompare) > 0 Then
                'Get Dealer info...
               ' Line Input #1, TextLine
                    A(1) = Mid(TextLine, 11, 14) 'Region
                    A(2) = Mid(TextLine, 32, 2) 'District
                    A(3) = Trim(Mid(TextLine, 8, 5)) 'Dealer Code
                    A(4) = Mid(TextLine, 15, 25) 'Dealer Name
                For I = 1 To 30
                    A(5) = Mid(TextLine, 1, 3) 'Model Line
                    A(6) = Trim(Mid(TextLine, 8, 4)) 'Model Line VINS
                    A(7) = Trim(Mid(TextLine, 16, 4)) 'Model Line Claims
                    A(8) = Mid(TextLine, 24, 6) 'Model Line Labor Hours
                    A(9) = Trim(Mid(TextLine, 32, 10)) 'Model Line Parts $
                    A(10) = Mid(TextLine, 46, 6) 'Model Line Sublet/Freight $
                    A(11) = Mid(TextLine, 58, 10) 'Model Line Total Warranty $
                    Call Write_Row
                    R = R + 1
        Loop
        Close #1
        MsgBox "Finally, the records have been imported"
    Sub Write_Row()
    Range("A1").Offset(R, 0).Value = A(1)
    Range("A1").Offset(R, 1).Value = A(2)
    Range("A1").Offset(R, 2).Value = A(3)
    Range("A1").Offset(R, 3).Value = A(4)
    Range("A1").Offset(R, 4).Value = A(5)
    Range("A1").Offset(R, 5).Value = A(6)
    Range("A1").Offset(R, 6).Value = A(7)
    Range("A1").Offset(R, 7).Value = A(8)
    Range("A1").Offset(R, 8).Value = A(9)
    Range("A1").Offset(R, 9).Value = A(10)
    Range("A1").Offset(R, 10).Value = A(11)
    Last edited by DocAElstein; 05-24-2019 at 06:51 PM. Reason: when posting code you can do this... [CODE]Your Code inside code tags like this[/CODE] ... looks a bit neater in final post
    Hello rcasaletta,
    Welcome to excelfox
    At first glance, it looks as though you are already using and doing the sort of things like you need in this coding
    In your current coding, you have a main Outer Loop which keeps going, ( it keeps looping), until you reach the End Of the text File. (I think EOF becomes True when you reach the End Of the text File ). In other words , it keeps Looping While you are Not at the End Of the text File...… This is the simplified form of it
      Do While Not EOF(1)' Outer Loop =======
      Loop' Outer Loop ======================
    If I understand correctly, the current problem is that inside that loop, you have an Inner Loop which you are currently looping 30 times, which might not always be the number of lines until "Total" appears.
    So this is the sort of thing you have currently in your existing coding, simplified
    __Do While Not EOF(1) ' Outer Loop =======
    _____For I = 1 To 30 ' Inner Loop ---
    _____Next I ' Inner Loop ------------
    __Loop' Outer Loop ======================
    So what you need to do is change that inner loop so that it keeps going ( keeps Looping ) While you have Not got the word 'TOTAL' in the inputed text line.
    So one way to do what you want would be something of this form, in other words,
    replace
    __the fixed number of loops _ For / Next _ loop ,
    with a
    __Do While / Loop _ loop
    So this is the sort of thing you could do , simplified
    __Do While Not EOF(1) ' Outer Loop ===================================================
    _____Do While Not InStr(1, TextLine, "TOTAL", vbTextCompare) > 0 ' Inner Loop ----
    _____Loop ' Inner Loop ------------------------------------------------------------
    __Loop ' Outer Loop =================================================================
    If you need more help, then best would be to give me..
    _ A reduced size test data text file, ( change or make up any sensitive data like names , addresses etc). Just give enough data to demonstrate the typical scenarios
    _ Give me an excel file with two worksheets. One worksheet is the Before, which I guess in your case will probably be almost empty. Then on the other worksheet, the After, fill it in by hand from the test text file data so that it looks exactly as you want the coding to do.
    I will take a look then at it tomorrow, .. or Sunday :)
    May 2019
    Your suggestion worked GREAT!! Thank you so much; really appreciated the help.
    https://eileenslounge.com/viewtopic.php?p=317609#p317609
    https://eileenslounge.com/viewtopic.php?p=317606#p317606
    You are welcome and thanks for the feedback,
    ( P.s. Possibly you are aware of this, but just in case you don't know this, I thought I would mention it in passing...
    You have a couple of lines like this
    Dim c, R As Long
    What you have there is actually this, ( since variant is the default when you do not explicitly do it )
    Dim FileToOpen As Variant, A(11) As Variant
    Dim c As Variant, R As Long
    It does make sense to have FileToOpen as Variant, because you may get a String type returned to it or a Boolean False. So a Variant is required to hold either of those two types.
    But I am not sure what c is supposed to be in your coding. I may have missed something. If you wanted c to be dimensioned a Long type, then you would need to do this:
    Dim c As Long, R As Long
    If you do , as you did, this .._
    Dim c, R As Long
    _.. then c will then be dimensioned as a Variant)
  1. VBA Macro to open a file and extract data
    By jeremiah_j2k in forum Excel Help
    Last Post: 05-22-2017, 03:17 PM
    Last Post: 12-11-2014, 09:30 AM
  3. VBA To Extract Certain Rows From A Text File
    By Bogdan in forum Excel Help
    Last Post: 08-31-2013, 06:57 PM
  4. How to extract all text from a word file?
    By vsrawat in forum Word Help
    Last Post: 09-25-2012, 10:24 PM
  5. How to extract all text from a ppt file
    By vsrawat in forum Powerpoint Help
    Last Post: 09-25-2012, 10:23 PM
