Results 1 to 6 of 6
Thread: Remove Hard Carriage Return And Leading And Trailing Spaces
    Hi David
    Try this
      Dim Cell As Range
      If Not Intersect(Target, Range("A4:A1004")) Is Nothing Then
        Application.EnableEvents = False
        With Intersect(Target, Range("A4:A1004"))
            .Value = Evaluate("IF(ROW(),TRIM(SUBSTITUTE(" & .Address & ",CHAR(10),"""")))")
        Application.EnableEvents = True
    Apr 2019
  1. Wrap Text On Spaces Up To A Maximum Number Of Characters Per Line
    Last Post: 12-20-2016, 09:47 AM
  2. hard question
    Last Post: 05-28-2013, 02:27 PM
  3. LTRIM() Function VBA: To Remove Spaces
  4. Macro to delete trailing X's
    Last Post: 03-29-2013, 12:43 PM
  5. VBA editor auto-deletes spaces at the ends of lines
    Last Post: 06-26-2012, 07:53 PM
