Results 1 to 6 of 6
Thread: Remove Hard Carriage Return And Leading And Trailing Spaces
David Montoya Remove Hard Carriage Return... 04-08-2019, 03:18 PM
Excel Fox Hi David Try this ... 04-08-2019, 10:29 PM
David Montoya It works very good, and... 04-09-2019, 06:43 AM
Excel Fox That seems to be a completely... 04-09-2019, 08:10 AM
David Montoya I have resolved the issue of... 04-13-2019, 04:41 PM
DocAElstein Hello David Montoya, I am... 04-15-2019, 01:40 AM
    Apr 2019
    Mr. Rick,
    Looking for a solution to my situation, I have found this 2013 post: https://www.mrexcel.com/forum/excel-...e-returns.html. I have tried to post my question here but it seems to be old and required to have a new post.
    Your solution works great from me to remove hard carriage returns. I would like to see if possible to incorporate this to an existing private sub I am using to trim spaces from start and end of entered text strings.
    My code is the following:
      Dim Cell As Range
      If Not Intersect(Target, Range("A4:A1004")) Is Nothing Then
        Application.EnableEvents = False
        For Each Cell In Intersect(Target, Range("A4:A1004"))
          If Len(Cell.Value) Then Cell.Value = Trim(Cell.Value)
        Application.EnableEvents = True
    I would like to include your solution to above mentioned, so that when entering information at the target range, the macro automatically removed the hard carriage returns as well
    Sub ReplaceAtSignWithLineFeed_v3()
      Selection = Evaluate("IF(ROW(),SUBSTITUTE(" & Selection.Address & ",CHAR(10),""""))")
    By the way, my first macro portion takes some time to execute, if you can suggest a more effective and expedited way to do it, please let me know.
    Thanks in advance for your assistance.
    Hi David
    Try this
      Dim Cell As Range
        With Intersect(Target, Range("A4:A1004"))
            .Value = Evaluate("IF(ROW(),TRIM(SUBSTITUTE(" & .Address & ",CHAR(10),"""")))")
    Apr 2019
    That seems to be a completely different requirement, unrelated to what you are doing above. Best to start a new thread with the code/sample workbook
    Apr 2019
    I have resolved the issue of the conditional formatting by modifying the target.
    Regarding the solution for the trim and carriage returns' removal, which work very efficiently, I am still running into a problem. My worksheet contains several other macros; one of the macros is to append the worked data to a different worksheet, and I am getting at the column "A" of the worksheet where I am applying your solution multiple rows with "#VALUE!" which when doing the append, it gives me incorrect results due to the contents of column "A".
    I am wondering if possible to have your solution, instead of hard coded for a range, to have it dynamically to be triggered by an input to a cell of the column "A", and within the range "A4:A1004"
    Thank you!
    I am finding it hard to understand what you are asking with this:
    Quote Originally Posted by David Montoya View Post
    As I understand it, the effect of this code line, .._
    _.. , is to trigger, if a cell or cells in the range "A4:A1004" have its or their value changed.
    ( Further, the effect of this, .._
    , _.. is to restrict action to the cell or cells which were changed. )
    That sounds close to what you are asking for.
    So I am confused about what you are actually wanting.
    It does not take much to coinfuse me. So I may have overlooked something, or missed the point
    It might be easier if you could give us a workbook with a reduced size sample, of desensitized data, to help explain what you want and / or what the problem is that you are having.
    P.s. Welcome to excelfox.com :-)
  1. Wrap Text On Spaces Up To A Maximum Number Of Characters Per Line
    Last Post: 12-20-2016, 09:47 AM
  2. hard question
    Last Post: 05-28-2013, 02:27 PM
  3. LTRIM() Function VBA: To Remove Spaces
  4. Macro to delete trailing X's
    Last Post: 03-29-2013, 12:43 PM
  5. VBA editor auto-deletes spaces at the ends of lines
    Last Post: 06-26-2012, 07:53 PM
