Results 1 to 10 of 27
Thread: "What’s in a String"- VBA break down Loop through character contents of a string
  1. #26
    Here a quick modified coding to look at the string seen in a highlighted word text (I had to chop a lot out to get it in the post size limit, the uploaded file has a fuller version)
    '        https://www.excelfox.com/forum/showthread.php/2302-quot-What%E2%80%99s-in-a-String-quot-VBA-break-down-Loop-through-character-contents-of-a-string?p=21221&viewfull=1#post21221           https://www.excelfox.com/forum/showthread.php/2348-String-text-in-Word-html-Passing-info-between-Word-and-Excel?p=21222#post21222
    '        https://www.excelfox.com/forum/showthread.php/2302-quot-What%E2%80%99s-in-a-String-quot-VBA-break-down-Loop-through-character-contents-of-a-string?p=21221&viewfull=1#post21221        String text in Word html.doc
    Sub WhatsInIt()
    Dim Str As String ' To hold the selected text in word
     Let Str = Selection.Text
    Call WatchaGotWord(Str)
    '  Modified a bit from here  https://www.excelfox.com/forum/showthread.php/2302-quot-What%E2%80%99s-in-a-String-quot-VBA-break-down-Loop-through-character-contents-of-a-string?p=15524&viewfull=1#post15524
    '  Modified to remove Excel Output bits and change  ThisWorkbook.Path   to   ThisDocument.Path   for the generated text files
    Sub WatchaGotWord(ByVal strIn As String, Optional ByVal FlNme As String) '
    'Rem 1  ' Output "sheet hardcopies"
    '1b) Array
    Dim myLenf As Long: Let myLenf = Len(strIn)  '            ' Long is very simple to handle, - final memory "size" type is known (123.456 and 000.001 have same "size" computer memory ) , and so a Address suggestion can be given for the next line when the variable is filled in.  '( Long is a Big whole Number limit (-2,147,483,648 to 2,147,483,647) If you need some sort of validation the value should only be within the range of a Byte/Integer otherwise there's no point using anything but Long.--upon/after 32-bit, Integers (Short) need converted internally anyways, so a Long is actually faster. )       https://www.mrexcel.com/forum/excel-questions/803662-byte-backward-loop-4.html
    Dim arrWotchaGot() As String: ReDim arrWotchaGot(1 To myLenf + 1, 1 To 2) ' +1 for header  Array for the output 2 column list.  The type is known and the size,  but I must use this ReDim  method simply because the dim statement  Dim( , )  is complie time thing and will only take actual numbers
     Let arrWotchaGot(1, 1) = FlNme & vbLf & Format(Now, "DD MMM YYYY") & vbLf & "Lenf is   " & myLenf: Let arrWotchaGot(1, 2) = Left(strIn, 40)
    Rem 2  String anylaysis
    'Dim myLenf As Long: Let myLenf = Len(strIn)
        For Cnt = 1 To myLenf ' ===Main Loop========================================================================
        ' Character analysis: Get at each character
        Dim Caracter As Variant ' String is probably OK.
        Let Caracter = Mid(strIn, Cnt, 1) ' '    the character in strIn at position from the left of length 1
        '2a) The character added to a single  WotchaGot  long character string to look at and possibly use in coding
        Dim WotchaGot As String ' This will be used to make a string that I can easilly see and also is in a form that I can copy and paste in a code line  required to build the full string of the complete character string
            '2a)(i) Most common characters and numbers to be displayed as "seen normally" ' -------2a)(i)--
            If Caracter Like "[A-Z]" Or Caracter Like "[0-9]" Or Caracter Like "[a-z]" Or Caracter = " " Then ' Check for normal characters
                'SirNirios
                If Not Cnt = 1 Then ' I am only intersted in next line comparing the character before, and if i did not do this the next line would error if first character was a  "normal"  character
                    If Not Cnt = myLenf And (Mid(strIn, Cnt - 1, 1) Like "[A-Z]" Or Mid(strIn, Cnt - 1, 1) Like "[0-9]" Or Mid(strIn, Cnt - 1, 1) Like "[a-z]" Or Mid(strIn, Cnt - 1, 1) Like " ") Then   ' And (Mid(strIn, Cnt + 1, 1) Like "[A-Z]" Or Mid(strIn, Cnt + 1, 1) Like "[0-9]" Or Mid(strIn, Cnt + 1, 1) Like "[a-z]") Then
                     Let WotchaGot = WotchaGot & "|LinkTwoNormals|"
            Let WotchaGot = WotchaGot & """" & Caracter & """" & " & " ' This will give the sort of output that I need to write in a code line, so for example if I have a123 , this code line will be used 4 times and give like a final string for me to copy of   "a" & "1" & "2" & "3" &      I would phsically need to write in code  like  strVar = "a" & "1" & "2" & "3"   -  i could of course also write  = "a123"   but the point of this routine is to help me pick out each individual element
            Else ' Some other things that I would like to "see" normally - not "normal simple character" - or by a VBA constant, like vbCr vbLf  vbTab
             Select Case Caracter ' 2a)(ii)_1
              Case " "
               Let WotchaGot = WotchaGot & """" & " " & """" & " & "
              Case "!"
               Let WotchaGot = WotchaGot & """" & "!" & """" & " & "
              Case "$"
               Let WotchaGot = WotchaGot & """" & "$" & """" & " & "
              Case "%"
               Let WotchaGot = WotchaGot & """" & "%" & """" & " & "
              Case "~"
               Let WotchaGot = WotchaGot & """" & "~" & """" & " & "
              Case "&"
               Let WotchaGot = WotchaGot & """" & "&" & """" & " & "
              Case "("
               Let WotchaGot = WotchaGot & """" & "(" & """" & " & "
              Case ")"
               Let WotchaGot = WotchaGot & """" & ")" & """" & " & "
              Case "/"
               Let WotchaGot = WotchaGot & """" & "/" & """" & " & "
              Case "\"
               Let WotchaGot = WotchaGot & """" & "\" & """" & " & "
              Case "="
               Let WotchaGot = WotchaGot & """" & "=" & """" & " & "
              Case "?"
               Let WotchaGot = WotchaGot & """" & "?" & """" & " & "
              Case "'"
               Let WotchaGot = WotchaGot & """" & "'" & """" & " & "
              Case "+"
               Let WotchaGot = WotchaGot & """" & "+" & """" & " & "
              Case "-"
               Let WotchaGot = WotchaGot & """" & "-" & """" & " & "
              Case "_"
               Let WotchaGot = WotchaGot & """" & "_" & """" & " & "
              Case "."
               Let WotchaGot = WotchaGot & """" & "." & """" & " & "
              Case ","
               Let WotchaGot = WotchaGot & """" & "," & """" & " & "
              Case ";"
               Let WotchaGot = WotchaGot & """" & ";" & """" & " & "
              Case ":"
               Let WotchaGot = WotchaGot & """" & ":" & """" & " & "
              Case "#"
               Let WotchaGot = WotchaGot & """" & "#" & """" & " & "
              Case "@"
               Let WotchaGot = WotchaGot & """" & "@" & """" & " & "
    '          Case " "
    '           Let WotchaGot = WotchaGot & """" & " " & """" & " & "
              Case vbCr
               Let WotchaGot = WotchaGot & "vbCr & "  ' I actuall would write manually in this case like     vbCr &
              Case vbLf
               Let WotchaGot = WotchaGot & "vbLf & "
              Case vbCrLf
               Let WotchaGot = WotchaGot & "vbCrLf & "
              Case vbNewLine
               Let WotchaGot = WotchaGot & "vbNewLine & "
              Case """"   ' This is how to get a single   "    No one is quite sure how this works.  My theory that,  is as good as any other,  is that  syntaxly   """"    or  "  """  or    """    "   are accepted.   But  in that the  """  bit is somewhat strange for VBA.   It seems to match  the first and Third " together as a  valid pair   but  the other  " in the middle of the  3 "s is also syntax OK, and does not error as    """     would  because  of the final 4th " which it syntaxly sees as a valid pair matched simultaneously as it does some similar check on the  first  and Third    as a concluding  string pair.  All is well except that  the second  "  is captured   within a   accepted  enclosing pair made up of the first and third  "   At the same time the 4th  "  is accepted as a final concluding   "   paired with the   second which it is  using but at the same time now isolated from.
               Let WotchaGot = WotchaGot & """" & """" & """" & """" & " & "                                ' The reason why  ""  ""   would not work is that    at the end of the  "" the next empty  character signalises the end of a  string pair, and only if  it saw a " would it keep checking the syntax rules which  then lead in the previous case to  the situation described above.
              Case vbTab
               Let WotchaGot = WotchaGot & "vbTab & "
              ' 2a)(iii)
                Case Else
                    If AscW(Caracter) < 256 Then
                     Let WotchaGot = WotchaGot & "Chr(" & AscW(Caracter) & ")" & " & "
                     Let WotchaGot = WotchaGot & "ChrW(" & AscW(Caracter) & ")" & " & "
                'Let CaseElse = Caracter
            End If ' End of the "normal simple character" or not ' -------2a)------Ended-----------
        '2b)  A 2 column Array for convenience of a list
         Let arrWotchaGot(Cnt + 1, 1) = Cnt & "           " & Caracter: Let arrWotchaGot(Cnt + 1, 2) = AscW(Caracter) ' +1 for header
        Next Cnt ' ========Main Loop=================================================================================
        '2c) Some tidying up
        If WotchaGot <> "" Then
         Let WotchaGot = Left(WotchaGot, Len(WotchaGot) - 3) ' take off last " & "    ( 2 spaces one either side of a  & )
         Let WotchaGot = Replace(WotchaGot, """ & |LinkTwoNormals|""", "", 1, -1, vbBinaryCompare)
            If Len(strIn) = 1 Then
                ' The next bit changes like this  "Lapto" & "p"  to  "Laptop"   You might want to leave it out ti speed things up a bit
                   If Len(WotchaGot) > 5 And (Mid(WotchaGot, Len(WotchaGot) - 1, 1) Like "[A-Z]" Or Mid(WotchaGot, Len(WotchaGot) - 1, 1) Like "[0-9]" Or Mid(WotchaGot, Len(WotchaGot) - 1, 1) Like "[a-z]") And (Mid(WotchaGot, Len(WotchaGot) - 7, 1) Like "[A-Z]" Or Mid(WotchaGot, Len(WotchaGot) - 7, 1) Like "[0-9]" Or Mid(WotchaGot, Len(WotchaGot) - 7, 1) Like "[a-z]") And Mid(WotchaGot, Len(WotchaGot) - 6, 5) = """" & " & " & """" Then
                    Let WotchaGot = Left$(WotchaGot, Len(WotchaGot) - 7) & Mid(WotchaGot, Len(WotchaGot) - 1, 2) '  Changes like this  "Lapto" & "p"  to  "Laptop"
    Rem 3 Output
    '3a) String
    '3a)(i)
    MsgBox prompt:=WotchaGot: Debug.Print WotchaGot ' Hit Ctrl+g from the VB Editor to get a copyable version of the entire string
    '3c) Output  WotchaGot  string to a text file
    '3c)(i) Simple string
    Dim FileNum2 As Long: Let FileNum2 = FreeFile(0)                                  ' https://msdn.microsoft.com/en-us/vba/language-reference-vba/articles/freefile-function
    Dim PathAndFileName2 As String
    ' Let PathAndFileName2 = ThisWorkbook.Path & "\" & "WotchaGot_in_" & Replace(FlNme, ".txt", "", 1, 1, vbBinaryCompare) & ".txt" ' CHANGE path TO SUIT
     Let PathAndFileName2 = ThisDocument.Path & "\" & "WotchaGot_in_" & Replace(FlNme, ".txt", "", 1, 1, vbBinaryCompare) & ".txt" ' CHANGE path TO SUIT
     Open PathAndFileName2 For Output As #FileNum2 ' CHANGE TO SUIT  ' Will be made if not there
     Print #FileNum2, WotchaGot ' write out entire text file
     Close #FileNum2
    '3c)(ii) Introduce an  "invisible"  vbCr & vbLf  pair after each  seen pair within  the string. this will give actual lines in the text file
     Let WotchaGot = Replace(WotchaGot, "vbCr & vbLf & ", "vbCr & vbLf" & vbCr & vbLf, 1, -1, vbBinaryCompare)
    ' Let PathAndFileName2 = ThisWorkbook.Path & "\" & "WotchaGot_in_" & Replace(FlNme, ".txt", "", 1, 1, vbBinaryCompare) & "_inLines.txt" ' CHANGE path TO SUIT
     Let PathAndFileName2 = ThisDocument.Path & "\" & "WotchaGot_in_" & Replace(FlNme, ".txt", "", 1, 1, vbBinaryCompare) & "_inLines.txt" ' CHANGE path TO SUIT
     Close #FileNum2
     '3c(iii) Number the new introduced actual Liners in the text file
    Dim arrIt() As String: Let arrIt() = Split(WotchaGot, vbCr & vbLf, -1, vbBinaryCompare)
     Let WotchaGot = ""
        For Cnt = 0 To UBound(arrIt())
         Let WotchaGot = WotchaGot & Cnt & " " & arrIt(Cnt) & vbCr & vbLf
    ' Let PathAndFileName2 = ThisWorkbook.Path & "\" & "WotchaGot_in_" & Replace(FlNme, ".txt", "", 1, 1, vbBinaryCompare) & "_inNumberedLines.txt" ' CHANGE path TO SUIT
     Let PathAndFileName2 = ThisDocument.Path & "\" & "WotchaGot_in_" & Replace(FlNme, ".txt", "", 1, 1, vbBinaryCompare) & "_inNumberedLines.txt" ' CHANGE path TO SUIT
     Close #FileNum2
  1. VBA Versions of my "Get Field" and "Get Reverse Field" formulas
  2. Get "Reversed" Field from Delimited Text String
    Last Post: 02-22-2015, 09:01 AM
  3. Replies: 1
    Last Post: 02-10-2015, 09:41 AM
  4. Replies: 4
    Last Post: 09-09-2013, 05:13 PM
  5. Ordinal Suffix (i.e., "st", "nd", "rd" and "th")
