Results 1 to 10 of 21
Thread: Validating PAN (Indian Format)
    Hi All,
    Here is a method to validate PAN in Excel. The rules for validation are as follows:
    • Length should be 10
    • First 5 character should be text [A-Za-z]
    • Next 4 should be number
    • Last character should be text [A-Za-z]
    and the formula will be
    =AND(LEN(A1)=10,SUMPRODUCT(--(--(ISNUMBER(MID(A1,{1,2,3,4,5,6,7,8,9,10},1)+0))={0, 0,0,0,0,1,1,1,1,0}))+SUMPRODUCT(--(CODE(MID(UPPER(A1),{1,2,3,4,5,10},1))>64))=16)
    More solutions are welcome
    There is always a VB solution, a UDF (user defined function) in this case...
    Function IsPAN(S As String) As Boolean
      IsPAN = S Like "[A-Za-z][A-Za-z][A-Za-z][A-Za-z][A-Za-z]####[A-Za-z]"
    For those reading this who are unfamiliar with UDFs, they are easy to install and use. To install it, simply press ALT+F11 to go into the VB editor and, once there, click Insert/Module on its menu bar, then copy/paste the above code into the code window that just opened up. That's it.... you are done. You can now use IsPAN just like it was a built-in Excel function. For example,
    =IsPAN(A1)
    I just noticed that your formula will "false match" these characters...
    [\]^_`{|}~
    as well as almost all the characters with ASCII (technically, ANSI) values above 126 if they appear anywhere within the first 5 or the 10th character positions. I would note that the UDF that I posted earlier works correctly for these characters.
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=Ugxa2VYHMWJWXA6QI294AaABAg.9irLgSdeU3r9itU7zdnW Hw
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugw6UrV69zpeKvLOeOV4AaABAg.9ht16tzryC49htJ6TpIO XR
    https://www.youtube.com/watch?v=LuAipOW8BNQ&lc=Ugw6UrV69zpeKvLOeOV4AaABAg.9ht16tzryC49htOKs4jh 3M
    Oct 2012
    There is one more requirement, 4Th Character should be P for Individulas, C for Company & so on.
    So how can we check that & also whether we can give output with error instead of say True or False.
    EG. Length should be 10, First 5 character should be text, Next 6-9 character should be number, Last character should be text, 4th character should be either of P,H,F,A,T,B,L,J,G.
    Thanks & Regards
    Sep 2021
    Here is the Solution...
    =IF(AND(OR(MID(A1,4,1)={"P";"H";"B";"C";"L";"F";"A";"J";"G";"T"}),CODE(UPPER(MID(A1,{1,2,3,4,5},1)))>=65,CODE(UPPER(MID(A1,{1,2,3,4,5},1)))<=90,CODE(LOWER(MID(A1,{10},1)))>=97,CODE(LOWER(MID(A1,{10},1)))<=122,CODE(MID(A1,{6,7,8,9},1))>=49,CODE(MID(A1,{6,7,8,9},1))<=57,LEN(A1)=10),"VALID","INVALID")
    Sep 2021
    Quote Originally Posted by in.vaibhav View Post
    Thanks & Regards
    Try This...
    Oct 2012
    =IsPAN(A1)
    There is one more requirement in this UDF, 4Th Character should be P for Individulas, C for Company & so on.
    Thanks & Regards
    Thanks & Regards
    This should account for the requirement you posted about...
      IsPAN = S Like "[A-Za-z][A-Za-z][A-Za-z][ABFGHJLPTabfghjlpt][A-Za-z]####[A-Za-z]"
    Oct 2012
    I wanted to function like this..
    Function ISPAN(inData As String)
    Dim i As Integer
    Dim Result As String
    If Len(inData) <> 10 Then
    ISPAN = "Total Character is " & Len(inData)
    Exit Function
    If Mid(UCase(inData), 1, 1) Like "[A-Z]" Then
    r1 = ""
    r1 = "Char1 is not Text,"
    If Mid(UCase(inData), 2, 1) Like "[A-Z]" Then
    r2 = ""
    r2 = "Char2 is not Text,"
    If Mid(UCase(inData), 3, 1) Like "[A-Z]" Then
    r3 = ""
    r3 = "Char3 is not Text,"
    If Mid(UCase(inData), 4, 1) Like "[P]" Then
    r4 = ""
    r4 = "Char4 Should be P"
    If Mid(UCase(inData), 5, 1) Like "[A-Z]" Then
    r5 = ""
    r5 = "Char5 is not Text,"
    If Mid(UCase(inData), 6, 1) Like "#" Then
    r6 = ""
    r6 = "Char6 is not Number,"
    If Mid(UCase(inData), 7, 1) Like "#" Then
    r7 = ""
    r7 = "Char7 is not Number,"
    If Mid(UCase(inData), 8, 1) Like "#" Then
    r8 = ""
    r8 = "Char8 is not Number,"
    If Mid(UCase(inData), 9, 1) Like "#" Then
    r9 = ""
    r9 = "Char9 is not Number,"
    If Mid(UCase(inData), 10, 1) Like "[A-Z]" Then
    r10 = ""
    r10 = "Char10 is not Text,"
    Result = r1 & r2 & r3 & r4 & r5 & r6 & r7 & r8 & r9 & r10
    If Right(Result, 1) = "," Then
        Result = Left(Result, Len(Result) - 1)
    If Result = "" Then
        ISPAN = "OK"
        ISPAN = Result
    This works fine but it is very lengthy can we shortn same by looping, I am not expert in VBA
    Thanks for all support.
    I don't know this is a lot shorter than you were hoping for, but given you wanted complete error reporting, looping does not really help that much. I noticed you only tested the 4th character to be the letter "P" in your code and, since you said your code works fine, I restricted the check of the 4th character to only that letter. Note that I also added a check to see if the argument is too short or too long to be a proper entry. Here is the non-looping code I came up with...
    Function IsPAN(S As String) As String
      If Len(S) < 10 Then
        IsPAN = "Too short!"
      ElseIf Len(S) > 10 Then
        IsPAN = "Too long!"
        If Mid(S, 1, 1) Like "[!A-Za-z]" Then IsPAN = IsPAN & vbLf & "Character 1 is not text."
        If Mid(S, 2, 1) Like "[!A-Za-z]" Then IsPAN = IsPAN & vbLf & "Character 2 is not text."
        If Mid(S, 3, 1) Like "[!A-Za-z]" Then IsPAN = IsPAN & vbLf & "Character 3 is not text."
        If Mid(S, 4, 1) Like "[!Pp]" Then IsPAN = IsPAN & vbLf & "Character 4 is not the letter 'P'."
        If Mid(S, 5, 1) Like "[!A-Za-z]" Then IsPAN = IsPAN & vbLf & "Character 5 is not text."
        If Mid(S, 6, 1) Like "[!0-9]" Then IsPAN = IsPAN & vbLf & "Character 6 is not a number."
        If Mid(S, 7, 1) Like "[!0-9]" Then IsPAN = IsPAN & vbLf & "Character 7 is not a number."
        If Mid(S, 8, 1) Like "[!0-9]" Then IsPAN = IsPAN & vbLf & "Character 8 is not a number."
        If Mid(S, 9, 1) Like "[!0-9]" Then IsPAN = IsPAN & vbLf & "Character 9 is not a number."
        If Mid(S, 10, 1) Like "[!A-Za-z]" Then IsPAN = IsPAN & vbLf & "Character 10 is not text."
        If Len(IsPAN) Then
          IsPAN = Mid(IsPAN, 2)
          IsPAN = "OK"
    In case you are interested, here is the same function using loops (among other things)...
      Dim X As Long, PatternChar As String, Test As New Collection
      Const Pattern As String = "AAAPANNNNA"
      If Len(S) < 10 Then
        IsPAN = "Too long!"
      ElseIf Len(IsPAN) = 0 Then
        Test.Add "[A-Za-z]", "A"
        Test.Add "[Pp]", "P"
        Test.Add "#", "N"
        For X = 1 To Len(S)
          PatternChar = Test(Mid(Pattern, X, 1))
          If Not Mid(S, X, 1) Like PatternChar Then
            IsPAN = IsPAN & vbLf & "Character " & X & " is not " & Choose(InStr("APN", _
                    Mid(Pattern, X, 1)), "text.", "the letter ""P"".", "a number.")
        If Len(IsPAN) Then
          IsPAN = "OK"
  1. Validating PAN (Indian Format)
    By Admin in forum Test Area
    Last Post: 03-22-2023, 06:14 PM
  2. Validating PAN (Indian Format)
  3. Validating PAN NUMBER Indian Format
    By mani780 in forum Excel Help
    Last Post: 03-10-2015, 01:19 PM
  4. Excel Number Format: Indian Style Comma Separation
    Last Post: 09-18-2013, 11:38 AM
