Results 1 to 1 of 1
Thread: Top N Value using Slicer
Prabhu Top N Value using Slicer 01-27-2019, 04:47 PM
    Aug 2011
    Hi All,
    I the attached which is helping to filter top 5,10,15 numbers of PivotTable11 in sheet2.
    now i would like to filter both PivotTable11 and PivotTable2 in the Sheet2.
    Is this possible when i select slicer both the Pivot table in the sheet should show the Top N value?
    Also if you can explain how this code works would help.
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40597&p=314054#p314054
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313971#p313971
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313909#p313909
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40574&p=313879#p313879
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313859#p313859
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313855#p313855
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313848#p313848
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313843#p313843
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313792#p313792
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313771#p313771
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313767#p313767
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313746#p313746
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313744#p313744
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313741#p313741
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313622#p313622
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313575#p313575
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313573#p313573
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313563#p313563
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313555#p313555
    https://www.eileenslounge.com/viewtopic.php?f=39&t=40265&p=313468#p313468
    https://www.eileenslounge.com/viewtopic.php?f=42&t=40505&p=313411#p313411
    https://www.eileenslounge.com/viewtopic.php?f=32&t=40473&p=313384#p313384
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40501&p=313382#p313382
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40501&p=313380#p313380
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40501&p=313378#p313378
    https://www.eileenslounge.com/viewtopic.php?f=32&t=40473&p=313305#p313305
    https://www.eileenslounge.com/viewtopic.php?f=44&t=40455&p=313035#p313035
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312889#p312889
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312886#p312886
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312752#p312752
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312734#p312734
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312727#p312727
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312724#p312724
    https://www.eileenslounge.com/viewtopic.php?f=44&t=40374&p=312535#p312535
    https://www.eileenslounge.com/viewtopic.php?p=312533#p312533
    https://www.eileenslounge.com/viewtopic.php?f=44&t=40373&p=312499#p312499
    https://www.youtube.com/channel/UCnxwq2aGJRbjOo_MO54oaHA https://www.youtube.com/channel/UCnxwq2aGJRbjOo_MO54oaHA
  1. LARGE function / Bringing top 5s from Data
    By nomanfiroz in forum Excel Help
    Last Post: 10-31-2013, 04:05 PM
    Last Post: 07-16-2013, 07:37 AM
  3. Delte a specific column and does not delete the top row
    By jffryjsphbyn in forum Excel Help
    Last Post: 06-13-2013, 02:00 PM
  4. Sort Data Using Formula To Find Top X
    Last Post: 06-02-2013, 10:13 PM
  5. Set Adjust A Button Top Left Position Programmatically
    By jeffrey159 in forum Access Help
    Last Post: 02-02-2013, 06:24 PM
