Thread: Toggle Between RowSource Items And List Items In A ComboBox Based On Criteria
    Mar 2018
    Lightbulb Toggle Between RowSource Items And List Items In A ComboBox Based On Criteria
    Hi All,
    I have a small problem. Attached a small spreadsheet.
    I have a form with two combo boxes. The row sources are “Languages” and “Levels”
    Some of the languages have a “*” on the right of the string.
    When I select a language, the second column is also populated.
    When I select languages with “*” at the right of the string, I want only "Lower" is the only level can be selected.
    Dim eRow As Long
        eRow = Sheets("Sheet2").Cells(Rows.Count, 1).End(xlUp).Offset(1, 0).Row
        Sheets("Sheet2").Activate
        Cells(eRow, 1) = ComboBox1.Text
        Cells(eRow, 2) = ComboBox1.Column(1)
        If Right(ComboBox2.Text, 1) = "*" Then
            ComboBox2.RowSource = Sheets("Sheet2").Range("E2")
            ComboBox2.RowSource = "Levels"
        Cells(eRow, 3) = ComboBox2.Text
        ComboBox1.Text = ""
        ComboBox2.Text = "”
    Any help with editing the code will be helpful.
    Thank you
    Raghavendra
    One way to do that is given below. Just replace your existing code with it.
    Private Sub ComboBox1_Change()
        With ComboBox2
            If Right(ComboBox1.Text, 1) = "*" Then
                .RowSource = ""
                .List = Array("Lower")
                .Value = "Lower"
                .ListIndex = -1
        Dim eRow As Long
        With Sheets("Sheet2")
            eRow = .Cells(.Rows.Count, 1).End(xlUp).Offset(1, 0).Row
            .Cells(eRow, 1).Resize(, 3).Value = Array(ComboBox1.Text, ComboBox1.Column(1), ComboBox2.Text)
            .Activate
    Private Sub CommandButton2_Click()
        Application.Quit
  1. Replies: 3
    Last Post: 10-11-2013, 02:52 PM
  2. Replies: 10
    Last Post: 08-29-2013, 08:20 PM
  3. Replies: 8
    Last Post: 08-17-2013, 04:03 AM
  4. Replies: 25
    Last Post: 08-02-2013, 07:23 AM
  5. Replies: 14
    Last Post: 06-27-2013, 10:57 AM
