Results 1 to 6 of 6
Thread: If condition: help needed
    Jul 2013
    Hi everyone,
    I am a voluntary treasurer of a local charity and I am building an excel model to capture members subscriptions and their additional donation.
    The model I have has three tabs; Payments, Subscriptions and donations. Members who are singles contribute £5 a month and couples contribute £10, but sometimes members contribute less than their monthly subscriptions. However, sometimes members pay their subscriptions together with donations. I want a formula in the subscriptions tab that is able to split the subscription amount from donation and ensure that the amount for a couple or single is entered even if the amount paid is less than the required subscription.
    E.g. a member who is single paid £35 in a month. This is entered against the member in the payments tab. I want a formula in the subscriptions tab to take only £5 as subscriptions against that member and the donations tab to take the rest. Where a member pays less than the required subscription, the full amount is entered as subscriptions.
    I have tried and cannot figure out what formula I need. Below is the formula I put in Subscriptions tab but is giving me £5 even if the subscription is paid by a couple.
    =IF(AND(E6="Single",'2018 Payments'!G6<=5),'2018 Payments'!G6,IF('2018 Payments'!G6>5,5,IF(AND(E6="",'2018 Payments'!G6<=5),'2018 Payments'!G6,IF('2018 Payments'!G6>5,5,IF(AND(E6="couple",'2018 Payments'!G6<=10),'2018 Payments'!G6,IF('2018 Payments'!G6>10,5,0))))))
    Where column E identifies the member as being single or couple
    Your help in this will be greatly appreciated.
    Regards
    Lome
    Hi lome,
    I am not sure if I have the logic correct of what you want.
    I find it helpful to put theses things clearly into words
    This is what I understand…
    A formula is wanted in a cell subscriptions worksheet
    A payment is made in cell G6 worksheet payment from a "single" or "couple" member, ( - 35 for a Month was your example - cell G6 in worksheet payment has 35 put in it ). It could come from a single or couple Member.
    If single or couple is shown:
    In subscriptions worksheet column E - ( E6 in the example ) I may have “single” or “couple” .
    Then your logic.. The model I have has three tabs; Payments, Subscriptions and donations. Members who are singles contribute £5 a month and couples contribute £10, but sometimes members contribute less than their monthly subscriptions. However, sometimes members pay their subscriptions together with donations. I want a formula in the subscriptions tab that is able to split the subscription amount from donation and ensure that the amount for a couple or single is entered even if the amount paid is less than the required subscription.
    I only need to check for single: If I do not have single then I assume I have couple.
    So my logic:
    If ( Single then ; ____ ; Else _____ )
    ____ will be case single
    _____ will be case couple
    ____ and _____ will be very similar according to your logic, differing only by
    ____ having a 5 in it
    _____ having a 10 in it
    =IF(E6="single",IF(Payments!G6<=5,Payments!G6,5),IF(Payments!G6<=10,Payments!G6,10))
    Worksheet: Subscriptions
    If I have not got it right, then can you upload two workbooks, with just a small amount of data. Desensitise the data ( make names up etc.. but pick the data carefully so that it demonstrates typical scenarios. )
    One file should be the “Before” - so what you have before you enter any payment.
    The “after” should be hand filled in by you to show what you want the formula to do, that is to say what results you want to have. And say what you will be wanting to be doing to get those results.
    Jul 2013
    Hi lome,
    A formula is wanted in subscriptions
    In subscriptions column E I may have “single” or “couple” .
    So my logic:
    If Single then ____ ; Else _____
    ____ and _____ will be very similar, differing only by
    Alan,
    Thanks for looking at this post. I forgot to mention that when a member's status is not know, column E is left blank and the assumption in subscriptions is that the member is single. So you can have single, couple or blank in column E, but when blank, the formula in subscriptions assumes single and allocate £5. Sample Model.xlsx
    I used insert Image as I cannot see an option to upload file
    In the file:
    Row4 where there was no payment
    Row5 where member is a couple and paid subs with donation
    Row6 where member is single and paid less than required subs
    Thanks once again
    To cover the situation of Single or blank meaning the same then the formula would be
    =IF(OR(E6="single",E6=""),IF(Payments!G6<=5,Payments!G6,5),If(Payments!G6<=10,Payments!G6,10))
    I think the following adaptation of that formula to your supplied data seems to give the result you wanted in the January column in Subs.
    So this is your Payments
    £29
    £0
    Status
    Subs Due
    Jan
    Feb
    Single
    £60
    Couple
    £120
    £25
    Single
    £60
    £4
    Worksheet: 2018 Payments
    Here is the Subs worksheet:
    £14
    £0
    Status
    Subs Due
    Jan
    Feb
    Single
    £60
    £0
    Couple
    £120
    £10
    Single
    £60
    £4
    Worksheet: 2018 Subs
    =IF(OR(E4="single",E4=""),IF('2018 Payments'!G4<=5,'2018 Payments'!G4,5),IF('2018 Payments'!G4<=10,'2018 Payments'!G4,10))
    =IF(OR(E5="single",E5=""),IF('2018 Payments'!G5<=5,'2018 Payments'!G5,5),IF('2018 Payments'!G5<=10,'2018 Payments'!G5,10))
    =IF(OR(E6="single",E6=""),IF('2018 Payments'!G6<=5,'2018 Payments'!G6,5),IF('2018 Payments'!G6<=10,'2018 Payments'!G6,10))
    Jul 2013
    =IF(OR(E6="single",E6=""),IF(Payments!G6<=5,Payments!G6,5),IF(Payments!G6<=10,Payments!G6,10))
    £29
    £0
    Status
    Subs Due
    Jan
    Feb
    Single
    £60
    Couple
    £120
    £25
    Single
    £60
    £4
    £14
    £0
    Status
    Subs Due
    Jan
    Feb
    Single
    £60
    £0
    Couple
    £120
    £10
    Single
    £60
    £4
    Thanks ever so much Alan, this works perfectly fine. I will let the trustees know about your invaluable contribution to the charity record keeping.
    Thanks once again
    You are welcome,
    I am not a formula man myself, I mostly do coding.
    This turned out a lot easier than I expected
    ( Edit: P.s. When you Reply with Quote if you could edit some bits out that helps to make the Thread a bit easier to read. Just include relavant bits, or use just Reply sometimes. Thanks )
    Edit P.s.2 Uploading files is not obvious…
    _1) You may need to “Go Advanced
    The normal Start point is with the Paper Clip icon at the top of the Editor Window. That icon will be present in the initial Post Editor, but it may not always be available for further Replys. You may need first to “Go Advanced
    GoAdvancedReplyWindow.JPG : GoAdvanced1.JPG
    https://imgur.com/1A9qWQM : https://imgur.com/UXBZ4oJ
    _2) _3) Hit Paper Clip and Add Files
    https://imgur.com/vbPQvTr
    _4) Select Files
    https://imgur.com/aqtVTPa
    _5) Upload Files
    https://imgur.com/pUfmZc7
    _6) Hit Done
    https://imgur.com/kQAwzao
    _-.----
    You can also get thereabouts with the Manage Attachments option which you will see when youscroll down after hitting “Go Advanced
    https://imgur.com/KxTxRoC
    _.------
    To delete Files:
    https://imgur.com/STzpq9E
    _..
    Best is to practice posting here:
    http://www.excelfox.com/forum/forumd...p/17-Test-Area
    Start a new Thread, with a title such as “Just testing and practicing posting, no reply needed
    You can do anything you want, post anything, Edit, and try again etc… etc..
    https://www.youtube.com/@alanelston2330/featured
    Last edited by DocAElstein; 09-13-2023 at 11:18 AM. Reason: Added Adding attatchment info...
  1. Replies: 19
    Last Post: 04-20-2019, 02:38 PM
  2. Vlookup help needed
    By AbuReem in forum Excel Help
    Last Post: 11-12-2013, 11:32 AM
  3. formulas needed please
    Last Post: 03-21-2013, 04:43 PM
  4. Indirect Address Column Formula help needed
    By trankim in forum Excel Help
    Last Post: 10-13-2012, 02:15 PM
  5. Replies: 12
    Last Post: 05-27-2012, 08:38 PM
