Results 1 to 10 of 30
  1. #18
    Simplified Walkthrough coding explanations
    This is now post 21
    It was a Second copy from New post #16, 31 Oct 2024, all done on 31 Oct 2024
    #post24890
    Page 3 Simplified explanation
    https://www.excelfox.com/forum/showt...Function/page3
    https://www.excelfox.com/forum/showthread.php/2227-VBA-Input-Pop-up-Boxes-Application-InputBox-Method-versus-VBA-InputBox-Function/page3
    Post 21 ( Forum Post #post24890 )
    https://www.excelfox.com/forum/showt...ll=1#post24890
    https://www.excelfox.com/forum/showthread.php/2227-VBA-Input-Pop-up-Boxes-Application-InputBox-Method-versus-VBA-InputBox-Function?p=24890&viewfull=1#post24890
    https://www.excelfox.com/forum/showt...age3#post24890
    https://www.excelfox.com/forum/showthread.php/2227-VBA-Input-Pop-up-Boxes-Application-InputBox-Method-versus-VBA-InputBox-Function/page3#post24890
    The detailed explanations in the last two pages ( https://www.excelfox.com/forum/showt...utBox-Function
    https://www.excelfox.com/forum/showt...Function/page2 ]
    ) are rather rich and intense, such that they need a lot of time and consideration and its easy to get bogged down and miss seeing the wood for the trees
    This page 3 ( https://www.excelfox.com/forum/showt...Function/page3 ) will be shorter simplified explanations based : step debug mode *step through the code lines; a brief simple run ; or general short explanation
    ( * F8 keyboard key from the VBEditor, (after selecting anywhere in the coding you want to step through, which in our case is the main Sub. That will let you step line by line through the coding. In this node a number of other useful tools are available, just one of which is that hovering over a variable, or some simple expressions, may cause a small pop up to appear telling you of the contents. - https://i.postimg.cc/tCf4krzW/Step-d...n-main-Sub.jpg )
    Post 22
    A debug F8 step mode full walkthrough the codings so far discussed in detail
    Post 23
    A simple run of the codings so far discussed in detail
    Post 24
    The issue of ByRef or ByVal is discussed, in terms of changing the typically needed and used ByRef to ByVal
    Post 25
    A simple run of the codings with the change to ByVal
