Thread: Help in SUMIF Formula
    Sep 2012
    Hi to All,
    I need your help on how to create a SUMIF Formula in Column I, please find attached Excel File. The result should look like in Column J:
    Many thanks.
    Regards,
    Aryan
    If you layout the data in a structured format, then a Pivot table would do the trick for you.
    Sep 2012
    Hi Admin,
    I need to keep the format of the table for reporting purposes. However, if that will be possible for the Pivot Table to keep the same format, will you be able to help and assist me on how to do it using Pivot Table.
    Many thanks in advance!
    Regards,
    Aryan
    Unfortunately, the current format doesn't help to create the pivot.
  1. SUMIF with dates
    By aysam in forum Excel Help
    Last Post: 06-12-2017, 08:24 AM
  2. SUMIF COUNTIF To Look For More Than One Keyword
    By william516 in forum Excel Help
    Last Post: 08-06-2013, 12:03 AM
  3. Replies: 5
    Last Post: 04-07-2013, 05:11 PM
  4. Help with a Vlookup and SUMIF
    By Lucero in forum Excel Help
    Last Post: 07-24-2012, 05:03 AM
  5. Update data from closed workbook with sumif formula
    Last Post: 11-02-2011, 02:58 AM
