Thread: Selection range
    Oct 2011
    Selection range
    Here is the code OK, are there any critical issues?
    Range(Cells(4, 5), Cells(Rows.Count, 5).End(3)).Select
    What do you recommend?
    Works only on ActiveSheet
    may be..
        With Sheet1
            MsgBox .Range(.Cells(4, 5), .Cells(.Rows.Count, 5).End(3)).Address
    Oct 2011
    Thanks to the suggestion, I thought the undocumented format I used: .Cells(.Rows.Count, 5).End(3)).Address
    could create areas selection problems
    Refering to range objects for to Select - PcMaxRangeProperties
    Quote Originally Posted by PcMax View Post
    ...I thought the undocumented format
    ..could create areas selection problems
    This I can perhaps explain.
    All documentation on Cells and Range____ selecting is bad. Microsoft documentation do make many mistakes. They do not even understand their own software sometimes!!
    I do try here:
    http://www.excelfox.com/forum/showth...eadsheet-cells
    Ways to refer to a range ( for to Select for example )
    This:
    Cells(row, column) does not exist. It works by coincidence only, due to Excel VBA defaults – VBA guesses ("thinks")### here that you meant to write something else.
    Cells(row, column) is not a proper way to refer to cells.
    We have three ways to refer to cells, all use range things
    _' (i) Application.Range("=StrRefToRangeObject") ( Method ? ) ' One or more Areas
    _' (ii) Rng.Item(Item Number or co ordinate) Property ' One Cell
    _' (i i i) Range(RngCorner, RngOtherCorner) Property ' One Area
    Way to get a range object of all cells in an object ( for example from a Worksheet )
    We cannot refer to cells using Cells( )
    Cells( ) does not exist.
    Cells does exist.
    Cells is a Property which returns a range object, Rng
    Rng = Ws.Cells
    Dim Ws As Worksheet: Set Ws = ThisWorkbook.Worksheets("Sheet") '     Set Ws = Workbooks("PcMaxRangeProperties.xls").Worksheets("Sheet1")    '      Set Ws = Workbooks("PcMaxRangeProperties.xls").Worksheets.Item("Sheet1")    '     Set Ws = Workbooks("PcMaxRangeProperties.xls").Worksheets.Item(1)
     Dim Rng As Range:   Set Rng = Ws.Cells                        '     Cells returns range object of all cells of object to which it is applied. here it returns all the cells of a worksheet as a single Areas range object of contiguous cells
    _.______
    This:_..
    _.. is not using Cells(r, c). This is not documented because it does not exist. Cells(r, c) is not a Property
    You are using
    (ii) twice
    (i i i) once
    You are doing this:
    (ii)a)
    Rng=Ws.Cells
    RngCorner = Rng.Item(4, 5)
    (ii)b)
    Rng=Ws.Cells
    RngItem= Rng.Item(Rows.Count, 5)
    RngOtherCorner = RngItem.End(3)
    (i i i)
    This can only return one Area: So no areas selection problems
    _.__________________-
    VBA "thinks" for you ###
    If you write
    Cells
    VBA "thinks" Ws.Cells or ActiveSheet.Cells
    If you write
    (r, c)
    VBA "thinks" Item(r, c)
    The Item Property is the default Property for a range object
    If you write
    Rng(r, c)
    VBA "thinks" Rng.Item(r, c)
    If you write Cells(r, c)
    VBA "thinks"
    First:
    Rng = Ws.Cells ' Code in Worksheet Code Module
    Rng = ActiveSheet.Cells ' Code in Normal Code Module or Code in ThisWorkbook Code Module
    Second:
    Rng(r, c)
    Rng.Item(r, c)
    ( If you write Range
    VBA "thinks"
    Application.Range ' Code in Normal Code Module or Code in ThisWorkbook Code Module
    Ws.Range' Code in Normal Code Module or Code in ThisWorkbook Code Module
    Note: Application.Range is usually, but not always, ActiveSheet.Range http://excelmatters.com/referring-to...comment-197138
    _.___________
    For more than one Area, use
    For example: _ Range("E1:E4,C2,G2:G3").Select
    This: _ E1:E4,C2,G2:G3 _ is only approximately correct, - VBA will try to "geuss" what you want
    This: _ Range _ is only approximately correct, - VBA will try to "geuss" what you want
    Worksheet: Tabelle1
    If you write
    VBA "thinks and then guesses" :
    Application.Range("=StrRefToRangeObject") _ or _ Ws.Range("=StrRefToRangeObject") _ or _ Ws.Range("Address In Ws")
    ( StrRefToRangeObject = Full string link to range object
    Like:
    StrRefToRangeObject = "='C:\Users\Elston\Desktop\[PcMaxRangeProperties.xls]Tabelle1'!$E$1:$E$4,C2,G2:G3"
    Rem For multiple areas use  _(i) Application.Range("=StrRefToRangeObject")       '       http://excelmatters.com/referring-to-ranges-in-vba/
     Application.Range("='C:\Users\Elston\Desktop\[PcMaxRangeProperties.xls]Tabelle1'!$E$1:$E$4,C2,G2:G3").Select
     Application.Range("='" & ThisWorkbook.Path & Application.PathSeparator & "[PcMaxRangeProperties.xls]Tabelle1'!$E$1:$E$4,C2,G2:G3").Select
     Application.Range("='[PcMaxRangeProperties.xls]Tabelle1'!$E$1:$E$4,C2,G2:G3").Select
     Application.Range("='Tabelle1'!$E$1:$E$4,C2,G2:G3").Select
     Application.Range("=$E$1:$E$4,C2,G2:G3").Select
     Application.Range("$E$1:$E$4,C2,G2:G3").Select
    Ciao
    Ref:
    http://www.eileenslounge.com/viewtop...=28616#p222840
    Sub PcMax() ' Range(Cells(4, 5), Cells(Rows.Count, 5).End(3)).Select ' http://www.excelfox.com/forum/showthread.php/2207-Selection-range
    Rem
    Dim Ws As Worksheet: Set Ws = ThisWorkbook.Worksheets.Item(1)
    Rem ' Cells Property only returns a range onject of all cells of the object to which it is applied
    Dim Rng As Range
     Set Rng = Ws.Cells
                                    'Rng = Cells   '_- This works also
    ' (ii)
    Rem _(ii)a) A corner cell of a single Area
    Dim RngCorner As Range
     Set RngCorner = Rng.Item(4, 5)
                                    'Set RngCorner = Rng(4, 5) '_- This works also
    Rem _(ii)b) The other corner cell of our single Area
    Dim RngItem As Range, RngOtherCorner As Range
     Set RngItem = Rng.Item(Rows.Count, 5)
     Set RngOtherCorner = RngItem.End(3)
    ' (iii)
    Rem For a single Area we can use _(iii) Property   Range(RngCorner, RngOtherCorner)
     Application.Range(RngCorner, RngOtherCorner).Select
    ' (i)
  1. Extend the macro to a selection of cells...
    By MrBlackd in forum Excel Help
    Last Post: 09-10-2013, 01:39 PM
  2. Replies: 4
    Last Post: 11-20-2012, 05:11 PM
  3. Replies: 3
    Last Post: 04-08-2012, 08:05 AM
  4. Using Selection.Address
    Last Post: 11-28-2011, 05:20 AM
  5. Mail Range or Selection using VBA
    Last Post: 11-03-2011, 09:00 AM
