I receive a csv file from a client that I have to massage in order to import into my system.
The issue is:
The file has a column with date of birth with a format of mmddyyyy. I need the format to be mm/dd/yyyy
I am trying to use the formula below (inserted via vba)
If month is 2 digits it works fine (see below)HTML Code:=LEFT(E2, 2)&" / "&MID(E2, 3, 2) & " / "&RIGHT(E2, 4)
10222017 returns 10 / 22 / 2017
If month is digit it does not work (see below)
9022017 returns 90 / 22 / 2017
My thought was to add a leading 0 to the cells where the month is 1 digit....Not sure how to do this either.
I have tried multiple formats with no success.
Is there an easier way to convert this?
How can I add a leading zero based on the number of characters?
Thanks in advance for your help.
