Results 1 to 10 of 12
Thread: How To Avoid Using Too Many OR and AND Functions In VBA
    Nov 2017
    dear Administrator,
    how can i change this code that instead of hard coded values of "|2001|2002|2003|2011|2012|2017|" i used cell reference
    for example. my 2001 will be in cell A2 and 2002 will be in A3 and 2003 will be in cell A4 and so on.
    i tried this and it did not work If Instr(1,"A2:A7", "|" & ShD.Cells(C.Row, intYearCol).Value & "|") >0
    screenshot A
    also how to i change the code if the values are in one cell separated by comma like screenshot B
    for the screenshot below i used If Instr(1,"A1", "|" & ShD.Cells(C.Row, intYearCol).Value & "|") >0 and it did not work.
    Also, wherever you are using code, can you please wrap it with the CODE tags. It increases readability.
    Nov 2017
    thank you very much Administrator.
    this excelfox is really the best.
  1. Color Functions In Excel
    Last Post: 10-24-2013, 11:44 AM
  2. VBA Trick of the Week :: Avoid Loop for Range Calculations - Evaluate
    Last Post: 06-18-2013, 11:42 PM
  3. Declaring API Functions In 64 Bit
    Last Post: 02-11-2013, 03:18 AM
  4. VBA to avoid - "indirect" Formula
    Last Post: 10-23-2012, 05:01 PM
  5. Avoid flickering in excel
    By Excelfun in forum Excel Help
    Last Post: 05-17-2012, 09:37 AM
