Thread: Jump to Last Used Cell in a Column?
    Aug 2017
    How do I jump to the last populated cell in a column?
    Assuming you want to jump to the last populated cell in a column using VBA
    Worksheets("Name of sheet").Cells(Rows.Count, 1).End(xlUp).Select
    will do; where 1 is the column index (1=A, 2=B etc)
    Aug 2017
    Thanks for your reply. However, I need to move the cursor to that cell for data entry. I should have stated that.
    I've discovered how to do just what I want (& more).
    To move to the last cell in a contiguous block of blank or non-blank cells, simply double-click on the current cell's border. The border chosen will determine the direction of the move. If you're in the middle of a large block of data and you want to move to the top cell within that block of data, simply double-click the top border of the current cell. You'll know you're in the right place to double-click because the cursor will change to a four-headed arrow. If you want to move to the last cell to the right within that same block of data, double-click the current cell's right border. The same is true when moving to the left or down.
    In my situation, selecting the column & then double-clicking the cell's bottom border will take me to the desired cell.
  1. Replies: 9
    Last Post: 02-01-2017, 06:04 PM
  2. Replies: 1
    Last Post: 12-21-2014, 09:29 PM
  3. Conversion Of Data In Column To One Cell
    By macak in forum Excel Help
    Last Post: 08-19-2013, 01:40 PM
  4. Highlight Active Cell’s Row and Column
  5. Lookup From Cell Range By Matching Row and Column
    Last Post: 03-07-2013, 02:02 PM
