Results 1 to 6 of 6
Thread: How to name Excel worksheet based on min-max in column
    Aug 2017
    I have a workbook with several worksheets. Col C (in all sheets) contains various dates (mm-dd-yyyy). I would like to name the various worksheets using the last 2 digits in the year portion of the min & max dates.
    sheet 01-05, sheet 02-11, sheet 17-17, etc
    Can that be done?
    Welcome to board !!!
    give this a try. In a standard module
    Sub kTest()
        Dim WkSht       As Worksheet
        Dim lngMin      As Long
        Dim lngMax      As Long
        For Each WkSht In ThisWorkbook.Worksheets
            With WkSht
                lngMin = Application.WorksheetFunction.Min(WkSht.UsedRange.Columns(3))
                lngMax = Application.WorksheetFunction.Max(WkSht.UsedRange.Columns(3))
                If lngMin * lngMax Then
                    .Name = Format(lngMin, "yy") & "-" & Format(lngMax, "yy")
    Aug 2017
    Thanks. That does exactly what I ask for. But . . . I asked for the wrong thing.
    I apologize for not stating the situation more clearly.
    This workbook contains worksheets for various "categories" (Apples, Oranges, Bananas, etc) as well as worksheets for historical info for these categories. So I need the names to be "Apples 11-15", "Apples 16-17", "Oranges 01-05", "Bananas 09-16", etc. That is, yy-yy appended as a suffix to the existing names.
    It also will be useful at times to be able to change only 1 sheet name, instead of all the names. In fact, after the initial mass renaming, this will probably be most useful.
    try
    Sub kTest()
        Dim lngMin      As Long
        Dim lngMax      As Long
        With ActiveSheet
            lngMin = Application.WorksheetFunction.Min(.UsedRange.Columns(3))
            lngMax = Application.WorksheetFunction.Max(.UsedRange.Columns(3))
                .Name = Split(.Name)(0) & " " & Format(lngMin, "yy") & "-" & Format(lngMax, "yy")
    Sub M_snb()
       ActiveSheet.Name = "snb " & Format(Application.Min(Columns(3)), "yy-") & Format(Application.Max(Columns(3)), "yy")
    Aug 2017
    Sorry, I've been away & haven't been able check & use this. Thanks a million. It will be very useful.
  1. Replies: 2
    Last Post: 03-08-2014, 04:22 PM
  2. Replies: 1
    Last Post: 09-18-2013, 10:17 PM
  3. Min, Max, Average Vba for Situation
    By afm1985 in forum Excel Help
    Last Post: 09-14-2013, 07:16 PM
  4. Find Value Based On MAX Value
    By Beaker Rex in forum Excel Help
    Last Post: 09-13-2011, 06:22 AM
  5. Replies: 4
    Last Post: 04-07-2011, 07:09 AM
