Thread: hi need a code for vb to transfer excel live data to notepad daily
    Feb 2017
    Hi everyone thanks in advance i need a code to transfer my excel live moving data to notepad live data on daily bases can anyone help me with the code
    thanks again vipul j gonsalves
    Hi vipul
    Welcome to Excel Fox
    Writing data from Excel to a text file is a fairly commonly done thing.
    There are many ways to do that.
    If you do a quick Google search using some search words such as_..
    VBA Excel to text file
    _.. then you will get many many given examples explained in detail.
    I do not thing it is possible for anyone to give you a code that will do what you want unless you give much more detailed information of
    _what you have in your Excel File
    _what you want in the text file.
    _...
    I suggest you research and read what an internet search gives you.
    See if you can adapt that to your needs.
    If then you still need some help, you must give us a lot more detail:
    _ Explain in as much detail exactly what you want.
    _ An example Excel data File with reduced data ( desensitized if necessary) showing what you have, the “Before
    _ a hand filled in text file showing exactly how the text file should look after the code has transferred the data from your example Excel data file, the “After
    P.s. I am not quite sure what you mean by “live moving” data ??
  1. Replies: 1
    Last Post: 01-19-2014, 04:45 PM
  2. Replies: 0
    Last Post: 01-19-2014, 02:38 AM
  3. data transfer does not match up
    By jeff in forum Excel Help
    Last Post: 01-15-2014, 06:36 AM
  4. How To Move Transfer Or Copy Data To A Protected Sheet
    Last Post: 07-13-2013, 06:52 PM
  5. Excel to Excel Data transfer without opening any of the files(source or target)
    By Transformer in forum Excel and VBA Tips and Tricks
    Last Post: 08-22-2012, 10:57 AM
