Results 1 to 10 of 29
Thread: Code Required to calculate number of days worked, normal overtime and holiday overtime
  1. #15
    Further to the TWO codes you now have from US .......... :)
    Hi Nelson,
    Quote Originally Posted by nelsondavid View Post
    ..i need normal OT and Holiday OT to appear exactly in cell G34 and J34 ...
    I think you can see what part of the code determines where the output goes
    '3f) Paste out final Totals and days to current Worksheet
         Let wsStear.Range("G34").Value = NOHrsV2 * 24 'Normal Overtime is held in Array as fraction of a day
         Let wsStear.Range("J34").Value = HOHrsV2 * 24 'Holiday Overtime is held in Array as fraction of a day
         Let wsStear.Range("C34").Value = TDays ' The constant value of Total days is simply added to cell C34
    '3g) Normal   Hrs  ( Column I ) and Overtime Hrs ( Column J ) are  changed
    '3f) Paste out final Totals formulas and days to current Worksheet
         Let wsStear.Range("G35").Value = "=SUMIF(K1:K" & lr & ",""N"",J1:J" & lr & ")*24"
         Let wsStear.Range("J35").Value = "=SUMIF(K1:K" & lr & ",""H"",J1:J" & lr & ")*24"
    '3g) Normal   Hrs  ( Column I ) and Overtime Hrs ( Column J ) are  changed ' And can paste out help column if you like
    I am sure you can understand how to modify to change which cells are used for where the total appear
    _............................................
    .... Can i use the same code for every month ...
    Yes..
    . if yes what changes i need to do from my end..
    ..The code is not in any way dependant on any month information......There is no reason that I can see to need to change anything..
    ....what changes i need to do from my end..
    You should not need to change your end, leave it alone, at least as far as any effect on the Months are concerned
    _................................................. .......
    ...I have around 800 sheets ...will the code work on all sheets in one go...
    The code is designed to work on multiple worksheets.
    Obviously I only tested it with two.
    If I were you, I would test it first with a larger amount, 10, 30, 60, .100 .......etc.. then finally 800 etc.
    In my opinion, it is very important that you try to understand the code...
    Alan.
    P.s.
    ..The code seems to be working fine..
    We have given you 2 codes
    From Alan
    http://www.excelfox.com/forum/showth...age2#post10066
    From Alan and Admin
    http://www.excelfox.com/forum/showth...age2#post10072
  1. Replies: 33
    Last Post: 01-12-2015, 10:08 AM
  2. Replies: 1
    Last Post: 07-23-2013, 10:43 PM
  3. Replies: 0
    Last Post: 09-17-2012, 02:05 PM
  5. Number of Days In A Month
    Last Post: 05-14-2011, 08:00 PM
