Results 1 to 7 of 7
Thread: Excel VBA/Macro Help required URGENT
    Sep 2016
    Dear All, I need to prepare an Excel file assigned to me on my new Job. I can't make it thoroughly , seeking your expertise help to get it done. Please help! The file on attached will be a DH based sheet where , when the Month is selected then it will be blank for input data and it saved accordingly on background. it will continues on every month. After that when i again select month then it will show the saved data of that month. Also there is a conmnecting background sheet where all the data will be solved. Can you plz check the file with comments and help me ASAP!!!! Please!!!
    Can;t upload the file here is the link of File:
    https://www.wetransfer.com/downloads...0101611/8a1e4c
    Sep 2016
    I moved your original thread (which you posted in my sub-forum) over to the Excel Help sub-forum, so this is a duplicate posting.
  1. Replies: 3
    Last Post: 04-03-2014, 01:51 PM
  2. Replies: 10
    Last Post: 11-21-2013, 04:41 PM
  3. Replies: 6
    Last Post: 09-24-2013, 04:13 PM
  4. VBA Program to Compare 4 Columns in Excel (Required)
    By vijaysram in forum Excel Help
    Last Post: 06-26-2013, 10:53 AM
  5. Replies: 12
    Last Post: 05-27-2012, 08:38 PM
