Thread: How to send emails from excel vba (with attachment) using outlook
    Jun 2016
    Hi there,
    I have not done any vba coding before and would like to shout out to the kind souls out there who are willing to share the VBA codes with me..
    Below are what I would like to see in the email automation:
    - Sheet 1: for me to enter all the email addresses i wanna Bcc to and their names in two columns
    * i just want to send to an email address and Bcc to the rest of the contacts..
    Sheet 2: for typing out the email subject line, body message and who i wanna send to/ cc/bcc etc.
    * as i type in the cells, the coding will be updated too
    - As i add in another new email contact, the coding will also be updated
    - i want to attach the same attachment for all the email contacts
    - a 'send email' button to be created in 'Sheet 2' and upon clicking, it opens up the outlook box and i can proceed to send via outlook
    Really hope someone could show me the codes for the above, greatly appreciate all help!
    Hi finding_dory,
    Welcome to ExcelFox
    Did you try using this
    Jun 2016
    Hi finding_dory,
    Welcome to ExcelFox
    Hey Excel Fox, thanks for the reply! I used the below codes but it doesnt attach any files to my email.. could you provide me with codes that command for file attachment and where in my codes should i insert them? Thank you once again!
    VBA Code I used:
    Private Sub CommandButton2_Click()
    Dim OutlookApp As Outlook.Application
    Dim MItem As Outlook.MailItem
    Dim cell As Range
    Dim Subj As String
    Dim EmailAddr As String
    Dim Recipient As String
    Dim Msg As String
    Dim objOutlookAttach As Outlook.Attachment
    'Create Outlook object
    Set OutlookApp = New Outlook.Application
    'Loop through the rows
    For Each cell In Columns("B").Cells.SpecialCells(xlCellTypeVisible)
    If cell.Value Like "*@*" Then
    EmailAddr1 = EmailAddr1 & ";" & cell.Value
    For Each cell In Columns("E").Cells.SpecialCells(xlCellTypeVisible)
    EmailAddr2 = EmailAddr2 & ";" & cell.Value
    For Each cell In Columns("H").Cells.SpecialCells(xlCellTypeVisible)
    EmailAddr3 = EmailAddr3 & ";" & cell.Value
    'Create Mail Item and view before sending
    Set MItem = OutlookApp.CreateItem(olMailItem)
    With MItem
    .To = EmailAddr2
    .BCC = EmailAddr1
    .CC = EmailAddr3
    .Subject = Sheet2.Cells(5, 2).Value
    .Body = Sheet2.Cells(7, 2).Value
    .Display
    Feb 2019
    i have tried diffrent codes for this in VBA . what if the attachement or attachements are located in a shared drive?
  1. Replies: 0
    Last Post: 08-04-2015, 11:08 PM
  2. Replies: 1
    Last Post: 06-28-2014, 11:31 AM
  3. Replies: 1
    Last Post: 12-23-2013, 10:09 PM
  4. Replies: 6
    Last Post: 06-05-2013, 11:33 PM
  5. Export outlook emails to Excel code Error
    By jamilm in forum Outlook Help
    Last Post: 02-22-2013, 03:48 PM
