Results 1 to 7 of 7
Thread: Click Run cycle
    Oct 2011
    Click Run cycle
    Hallo
    Taking a cue from the file attached wonder if there is a solution to place the wheel in contact with the workpiece.
    The object rotates in the direction you should move even higher down from the current position
    Now I ask if you have some suggestions and methods to propose.
    Possibly easier to implement.
    following attachment:
    http://www.sendspace.com/file/7bd2rd
    Not able to download the file. Can you post a link from boxnet.com
    Oct 2011
    update File
    Hallo
    Here is the attachment:
    http://www.box.net/shared/maph78x3c8auqcfbze4n
    Something wrong with the shapes. Unable to find the shape Rettangolo 61
    OK, It is working now. Had to rename all Rettangolo to Rectangle, and grupo to group.
    Anyway, can you tell me what is the work piece and what is the wheel? What do you want to contact?
    Oct 2011
    Hallo
    I had already happened to find the names of various objects renamed, may wonder if you know how to handle a common language between different installations ...
    Precise, however, that will then run on a maximum of 1 or 2 PC, this should simulate the processing of cotton, a brush of moving parts.
    This is to improve the movement and processing times, but always to be evaluated on the field if correct.
    I tried various ways to obtain a precise method but the combination have not been able to find it.
    I attach some images to simulate the movie that I would get.
    http://www.box.net/shared/ablb6t92449yp8emb44h
    Thank you in advance for any suggestions
    Apr 2011
    Check these settings - also be aware of decimal separators and so on - if you plan on using your code across countries - then this become very important. You can use 'System' or application settings - generally speaking.
    Application.LanguageSettings
    xl2007 - Windows 7
    xl hates the 255 number
  1. Replies: 7
    Last Post: 05-09-2013, 11:16 PM
  2. Run Time error '9': Subscript out of range
    By antonio in forum Excel Help
    Last Post: 03-26-2013, 01:53 AM
  3. step cycle sum
    By PcMax in forum Excel Help
    Last Post: 10-23-2012, 04:08 PM
  4. Selecting workbook to run macro
    Last Post: 08-24-2012, 08:21 PM
  5. VB code to Run formula untill blank cell
    Last Post: 05-20-2012, 11:08 AM
