Results 1 to 6 of 6
Thread: Visible range from UDF having filtered Listobject columns as argument
    May 2012
    hi,
    i am filtering a listobject and passing some of its columns to a UDF called from a cell. the function is supposed to return only the filtered visible cells from those listcolumns. However it returns the whole range.
    i have posted the details here:
    excel - selecting SpecialCells(xlCellTypeVisible) from specific columns of ListObject table - Stack Overflow
    can anyone help urgently?
    https://www.youtube.com/watch?v=bRd4mJglWiM&lc=UgxRmh2gFhpmHNnPemR4AaABAg
        Dim r   As Range
        With ActiveSheet.ListObjects(1)
            Set r = Intersect(.DataBodyRange, .DataBodyRange.Offset(, 1)).SpecialCells(12)
        MsgBox r.Address
    would return whole bodyrange except the first column (visible cells)
    May 2012
    hi,
    Strange as it may seem, a UDF function doesn't seem to return the visible range, but if you convert it to a Sub procedure, it will return the visible range.
    PHP Code:
    Sub Subit(tabdata As ListObject)
    Dim r   As Range
    With tabdata
        Set r
    End With
    MsgBox r
    .Address
    End Sub
    whereas a function called from a worksheet cell will return #Value
    PHP Code:
    Function Funcit(tabdata As ListObject) As Range
    Dim r
    As Range
    With tabdata
        Set r
    End With
    MsgBox r
    .Address
    End
    Function
    I can definitely call this function from another procedure passing the listobject to it and it works.
    PHP Code:
    Sub Runit()
    Call Funcit(ActiveSheet.ListObjects(1))
    End Sub
    But this doesnt solve my query as i want to pass a listobject range to a UDF in a cell and in turn get its visible range from the function.
    Quote Originally Posted by Junoon View Post
    PHP Code:
        Set r Intersect(.DataBodyRange, .DataBodyRange.Offset(, 1)).SpecialCells(12
    SpecialCells does not work when called from a UDF.
    Not strange to me BTW, what's your aim to bring the range in the cell ?
    May 2012
    [PHP]yes, i agree.
    this works if i call it from a cell like this:
    PHP Code:
    =filteredRange(tab_data[[Brands]:[Index]])
    PHP Code:
    Function filteredRange(theRange As Range) As String
        Dim rng
    As Range
        Dim r
    As Range
    For Each r In theRange.Rows
    If Not r.Hidden Then
    If rng Is Nothing Then
                    Set rng
    r
    Set rng Union(rngr)
    End If
    End If
    If Not rng Is Nothing Then filteredRange rng.Address
    End
    Function
    as it is returning a String.
    this works if i am returning a Count:
    PHP Code:
    Function filteredRange(theRange As Range) As Long
        Dim rng
    As Range
        Dim r
    As Range
        Dim Cnt
    As Long
                    Set rng
    r
                    Cnt
    Set rng Union(rngr)
    Cnt Cnt 1
                End
    If
    End If
    If Not rng Is Nothing Then filteredRange Cnt  //do something with filteredRange
    End Function
    This works if function doesnt return a Range type but does find the visible range inside it:
    PHP Code:
    Dim rng As Range
        Dim r
    As Range
                    Set rng
    r
    Set rng Union(rngr)
    End If
    End If
    If Not rng Is Nothing Then filteredRange rng     //do something with filteredRange
    End Function
    Cheers mate.
  1. Replies: 5
    Last Post: 07-30-2014, 07:51 PM
  2. Q: VBA - using a range of strings as an argument
    By mwdking in forum Excel Help
    Last Post: 11-11-2013, 10:45 PM
  3. Forcing an Argument to be Passed by Value
    Last Post: 05-21-2013, 11:28 AM
  4. Worksheet Protection Method with UserInterfaceOnly Argument
    By technicalupload in forum Download Center
    Last Post: 09-02-2011, 04:17 PM
  5. Unique Count on a Filtered Range
    Last Post: 08-14-2011, 04:29 AM
