Results 1 to 9 of 9
Thread: Multiple IF's Formula Help!!
    Hi All,
    Is it possible to retrieve 3-4 different inputs based on 3-4 different data in another cell.
    For example,
    I have various 3-4 types of expenses in Column F (Salik Charges, Hire Charges, Vehicle Fine & Fuel Charges). These 4 expenses have 4 different codes under which it needs to be categorized.
    I require the codes to be retrieved in column L from a formula based on the data (expenses) in Column F.
    Codes to be retrieved by formula:
    Salik Charges 170.110.000.415030.0000.0000.000.000
    Hire Charges 170.110.000.415025.0000.0000.000.000
    Vehicle Fine 170.110.000.143015.0000.0000.000.000
    Fuel Charges 170.110.000.415015.0000.0000.000.000
    The question is not clear at least for me Can you please elaborate in detail ?
    If Column F contains the expense data (for ex. "Salik Charges"), I need a formula where it will bring up the respective code (i.e., 170.110.000.415030.0000.0000.000.000) in column L.
    and so on for the 3 other codes & expenses.
    Hi msiyab,
    _ I wasted a lot of time at the start of my “Excel carrier” doing multiple Ifs. If you really do want to do it that way then you simply do nested If’s
    Pseudo Code:
    = If ( x , 1 , ~~~ if ( y , 2 , …………… and so on ) ~~~ )
    In XL up to 2003 that will work for up to 7 If’s. For XL 2007 + that will work for 64 Ifs
    This is then what you want for your example:
    Using Excel 2007
    L
    =IF(F1="Salik Charges","170.110.000.415030.0000.0000.000.000",IF (F1="Hire Charges","170.110.000.415025.0000.0000.000.000",IF (F1="Vehicle Fine","170.110.000.143015.0000.0000.000.000",IF(F1 ="Fuel Charges","170.110.000.415015.0000.0000.000.000","" ))))
    =IF(F2="Salik Charges","170.110.000.415030.0000.0000.000.000",IF (F2="Hire Charges","170.110.000.415025.0000.0000.000.000",IF (F2="Vehicle Fine","170.110.000.143015.0000.0000.000.000",IF(F2 ="Fuel Charges","170.110.000.415015.0000.0000.000.000","" ))))
    =IF(F3="Salik Charges","170.110.000.415030.0000.0000.000.000",IF (F3="Hire Charges","170.110.000.415025.0000.0000.000.000",IF (F3="Vehicle Fine","170.110.000.143015.0000.0000.000.000",IF(F3 ="Fuel Charges","170.110.000.415015.0000.0000.000.000","" ))))
    =IF(F4="Salik Charges","170.110.000.415030.0000.0000.000.000",IF (F4="Hire Charges","170.110.000.415025.0000.0000.000.000",IF (F4="Vehicle Fine","170.110.000.143015.0000.0000.000.000",IF(F4 ="Fuel Charges","170.110.000.415015.0000.0000.000.000","" ))))
    _.....................
    Here are the results
    J
    K
    L
    _.......................
    Of course you only need to put the formula in L1 in and then drag down
    But: I learnt the hard way it was well worth learning how to use VLookUp, which is much more flexible and neater..
    I will show that in the next post ( as those long formulas use up most of the Post space!!!.. )
    _...So this way is better..
    _ You make a table anywhere convenient that looks like the what you gave in Post #1
    Salik Charges~~~~~~170.110.000.415030.0000.0000.000.000
    Hire Charges~~~~~~~170.110.000.415025.0000.0000.000.000
    Vehicle Fine~~~~~~~~170.110.000.143015.0000.0000.000.000
    Fuel Charges~~~~~~~170.110.000.415015.0000.0000.000.000
    _.. then you use the VLookUp, pseudo code
    ~~~~=~~~(~~~~~Look in column F~~~~,~~~see where that is in your table~~~,~~~~~give out the value in column 2 of that table~~~~~,~~~~~and look for an exact match~~~~~)
    Here would be one way to do that.
    Your table somewhere:
    _.........................................
    Your Formulas
    L
    =VLOOKUP(F1,$C$6:$D$9,2,FALSE)
    =VLOOKUP(F2,$C$6:$D$9,2,FALSE)
    =VLOOKUP(F3,$C$6:$D$9,2,FALSE)
    =VLOOKUP(F4,$C$6:$D$9,2,FALSE)
    ( Once again you only need to put the formula in L1 in and drag that down.
    And Change the dimensions of the table $C$6:$D$9 if you want more stuff in that Table. For example $C$6:$D$10 if you want to add a row to the table.
    Some results:
    J
    K
    L
    _...............................................
    Or you might do some analysing/thinking first:
    in cell L1:
    PHP Code:
    ="170.110.000." choose(search(left($F1,1),"FHSV"),"415015","415025","415030","143015")&".0000.0000.000.000"
    Hi snb
    in cell L1:
    PHP Code:
    Thanks for that alternative.
    That “analysing/thinking first” still would not have helped me here, as I do not have the Knowledge and experience of those Choose and Search Functions.
    Thanks for giving the benefit of your extra knowledge and experience.
    P.s. I think I get what is going on.......
    Using Excel 2007
    J
    K
    L
    Salik Charges
    415030 170.110.000.415030.0000.0000.000.000
    Vehicle Fine
    143015 170.110.000.143015.0000.0000.000.000
    Hire Charges
    415025 170.110.000.415025.0000.0000.000.000
    Fuel Charges
    415015 170.110.000.415015.0000.0000.000.000
    Tabelle3
    J
    K
    L
    Salik Charges
    =SEARCH(LEFT($F1,1),"FHSV")
    =CHOOSE(J1,"415015","415025","415030","143015") ="170.110.000." & CHOOSE(SEARCH(LEFT($F1,1),"FHSV"),"415015","415025","415030","143015")&".0000.0000.000.000"
    Sub snbFormula() '   http://www.excelfox.com/forum/f2/multiple-ifs-formula-help-2089/#post9699
    Let Range("L1").Value = "=" & """170.110.000."" & choose(search(left($F1,1),""FHSV""),""415015"",""415025"",""415030"",""143015"")&"".0000.0000.000.000"""
    '   ="170.110.000." & choose(search(left($F1,1),"FHSV"),"415015","415025","415030","143015")&".0000.0000.000.000"
    '   ="170.110.000." & WAHL(SUCHEN(LINKS($F1;1);"FHSV");"415015";"415025";"415030";"143015")&".0000.0000.000.000"
    ' Explanation Maybe:
    ' = search(left($F1,1),"FHSV") ---- Searching for first letter in FHSV  and returning position along
    ' =SUCHEN(LINKS($F1;1);"FHSV")
    ' = choose(2,"415015","415025","415030","143015") ---- as example, choose at positon 2 - so here return "415025"
    ' =WAHL(J1;"415015";"415025";"415030";"143015")
    @DocE
    Why do you use 'Let' ??
    sub M_snb()
      cells(1,12)="170.110.000."& choose(instr("FHSV",left(cells(1,6),1)),"415015","415025","415030","143015")& ".0000.0000.000.000"
    end sub
    PS.
    - most of the time multiple ifs can be replaced by an algorithm that reflects an underlying pattern.
    in this case e.g. "4150" & 5*instr(" F HSV",left(cells(1,6),1))
    - It might be worthwhile to study systematically every function in Excel, starting with text, information, etc.
    Hi snb
    sub M_snb()
    end sub
    _ Another one ! !! The ways to do stuff in VBA is never ending!!!
    @DocE
    http://www.excelfox.com/forum/showth...page2#post9459
    http://www.excelfox.com/forum/f2/spe....html#post9459
    PS.
    _- Thanks for that. Worth bearing in mind.
    _ I hope i get time to check it all out. But it is a rather a lot!!!.... _
    _ In the meantime it is great to get help from other, more experienced people.
    P.s. I expect for real ( lots of ) data the VLookUp would still be the best, especially if data may be added later.... although you could write a program to produce the formula string.... But as said... the ways to do stuff in VBA is never ending!
  1. Replies: 6
    Last Post: 12-23-2013, 04:07 PM
  2. Nested If Formula With Multiple Conditions
    By lprc in forum Excel Help
    Last Post: 04-22-2013, 07:27 PM
  3. Vlookup Multiple Values By Adding Formula With Loop In VBA
    Last Post: 04-22-2013, 04:49 PM
  4. Replies: 2
    Last Post: 03-21-2013, 10:38 PM
  5. Replies: 3
    Last Post: 03-12-2013, 12:54 PM
