Thread: Remove a particular legend from a Chart using VBA
    Dec 2018
    Hi thanks a lot for this. Excel does not maintain the same ordering for series and legend, if the chart has got a mixed type of series e.g. line, column etc and also primary and secondary vertical axis. So, using the color property to delete the legend entry of a particular series is a very good idea as long as colors do not repeat. However, I found the ForeColor property was not working (using Excel 2013). So, I modified the code in order to use Border color instead and it works.
    Function delete_legend_entry(ByRef chartObject As chartObject, ByVal seriesName As String)
    ' Got the idea from http://www.excelfox.com/forum/showthread.php/2075-Remove-a-particular-legend-from-a-Chart-using-VBA
    ' But the reference used Interior colour which is not unique for all series, so I used border colour
        Dim chtChart        As chart
        Dim srsSeries       As Series
        Dim lngSrsColor     As Long
        Dim lngLoop         As Long
        Set chtChart = chartObject.chart
        lngColor = chtChart.PlotArea.Format.Fill.ForeColor.RGB
        For Each srsSeries In chtChart.SeriesCollection
            If LCase(srsSeries.Name) = LCase(seriesName) Then
                lngSrsColor = srsSeries.Border.Color
                Exit For
        For lngLoop = chtChart.Legend.LegendEntries.Count To 1 Step -1
            If chtChart.Legend.LegendEntries(lngLoop).LegendKey.Border.Color = lngSrsColor Then
                chtChart.Legend.LegendEntries(lngLoop).Select
                chtChart.Legend.LegendEntries(lngLoop).Delete
                Exit For
    https://www.youtube.com/watch?v=bRd4mJglWiM&lc=UgxRmh2gFhpmHNnPemR4AaABAg
  1. Replies: 2
    Last Post: 01-13-2014, 07:13 PM
  2. Remove Special Characters From Text Or Remove Numbers From Text
  3. LTRIM() Function VBA: To Remove Spaces
  4. Delete Remove Rows By Criteria VBA Excel
    Last Post: 12-20-2012, 05:56 PM
  5. Remove Unused Custom Styles VBA
    Last Post: 08-23-2012, 02:32 PM
