Results 1 to 9 of 9
Thread: Divide Rest of the Columns using Column A values
    Aug 2011
    Hi All,
    I have a complex query.
    In the excel sheet column A values to be divided with rest of the columns.
    Example Cell A1 value to be used to dived rest of the visible rows like B1, C1 D1,etc
    Columns and row are not fixed and it is dynamic.
    for the ready reference i have attached sample workbook which has sheet1 which has input value and sheet 2 which has result.
    Request to help if this can be done VBA code.
    Regards,
    Prabhu
    try
    Sub kTest()
        Dim r   As Long, c  As Long
        Dim ColA, d, Dest As Range
        With Worksheets("Sheet1")
            r = .Range("a" & .Rows.Count).End(xlUp).Row
            c = .Cells(1, .Columns.Count).End(xlToLeft).Column
            ColA = .Range("a2:a" & r).Value2
            d = .Range("b2", .Cells(r, c)).Value2
            Set Dest = .Range("b2")
        If IsArray(ColA) Then
            If IsArray(d) Then
                For r = 1 To UBound(ColA, 1)
                    For c = 1 To UBound(d, 2)
                        If ColA(r, 1) = 0 Then
                            d(r, c) = "=iferror(" & d(r, c) & "/" & ColA(r, 1) & ",0)"
                            d(r, c) = "=" & d(r, c) & "/" & ColA(r, 1)
                Dest.Resize(UBound(d, 1), UBound(d, 2)).Value2 = d
    Aug 2011
    Thanks!
    I could not run the macro,below code shows as run time error '1004' Application-defined or object -defined error.
    I have edited the above code.
    Sub M_snb()
       Sheet2.Cells(20, 1).Resize(9, 4) = [index(if(column(A2:D2)=1,sheet1!A2:A10,round(sheet1!A2:D10/sheet1!A2:A10,0)),)]
    Aug 2011
    Hi Admin,
    Still i am getting same error
    Aug 2011
    Quote Originally Posted by Prabhu View Post
    Hi Admin,
    request your help to resolve the error.
    Did you overlook #5 ?
    Aug 2011
    Yes,
    with the same format of Sheet 1 along with the formulas in cell( instead of value format) like "=149/6" will solve the purpose.
    also the row and column are flexible number of row used to change every time.
    the solution provide by the admin is working for the 1st line only and then "Dest.Resize(UBound(d, 1), UBound(d, 2)).Value2 = d" code highlighted as error.
    if you help to resolve the error also fine for me.
    Thanks for the support.
  1. Concatenating your Balls
  2. Replies: 10
    Last Post: 02-18-2014, 01:34 PM
  3. Replies: 6
    Last Post: 07-26-2013, 11:42 AM
  4. Replies: 10
  5. Replies: 4
    Last Post: 04-05-2013, 12:08 PM
