Page 7 of 19 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 190
Thread: Appendix Thread 2. ( Codes for other Threads, HTML Tables, etc.)
  1. #61
    First test code for solution to this thread:
    http://www.excelfox.com/forum/showth...le-or-two-tabs
    ( Run code Sub TestieCalls() )
    Sub TestieCalls()
     Call Testie(Worksheets("Sheet1"), Worksheets("Sheet2"))
    Sub Testie(Ws1 As Worksheet, Ws2 As Worksheet)
    Rem 1 Worksheet data info
    '1a capture data
    '1a(i) last data rows
    Dim lr1_1 As Long, Lr1_2 As Long, Lr2_1 As Long, Lr2_2 As Long, Lr1 As Long, lr2 As Long
     Let lr1_1 = Ws1.Cells(Rows.Count, 1).End(xlUp).row
     Let Lr1_2 = Ws1.Cells(Rows.Count, 2).End(xlUp).row: Lr2_1 = Ws2.Cells(Rows.Count, 1).End(xlUp).row: Lr2_2 = Ws2.Cells(Rows.Count, 2).End(xlUp).row
        If lr1_1 > Lr1_2 Then
         Let Lr1 = lr1_1
         Let Lr1 = Lr1_2
     Let lr2 = Lr2_2: If Lr2_1 > Lr2_2 Then Let lr2 = Lr2_1
    '1a(ii) capture data into arrays in one go
    Dim arrSht1() As Variant, arrSht2() As Variant
     Let arrSht1() = Ws1.Range("A1:B" & Lr1 & "").Value
     Let arrSht2() = Ws2.Range("A1:B" & lr2 & "").Value
    Rem 2 arrays for check and output
    Dim arrSht1b() As String, arrOut() As String
    '2a size arrays to that of sheet 2 data
     ReDim arrSht1b(1 To UBound(arrSht2(), 1), 1 To UBound(arrSht2(), 2))
     ReDim arrOut(1 To UBound(arrSht2(), 1), 1 To UBound(arrSht2(), 2))
    '2b fill modified sheet 1 array, arrSht1b() , initially with sheet 1 data
        For Cnt = 1 To UBound(arrSht1(), 1) Step 1
         Let arrSht1b(Cnt, 1) = arrSht1(Cnt, 1): Let arrSht1b(Cnt, 2) = arrSht1(Cnt, 2)
    Rem 3 main loop   ' == Start main loop ==========
        For Cnt = 1 To UBound(arrSht2(), 1) - 1 Step 1 ' Counting at each row
        Dim DifCnt As Long 'Count of different cells
            ' Condition check
            If (arrSht2(Cnt, 1) <> arrSht1b(Cnt, 1) Or arrSht2(Cnt, 2) <> arrSht1b(Cnt, 2)) And (arrSht2(Cnt + 1, 1) = arrSht1b(Cnt + 1, 1) And arrSht2(Cnt + 1, 2) = arrSht1b(Cnt + 1, 2)) Then  ' condition for changed row but next row is as previous : row had data changed, but a row was not inserted
             Let arrSht1b(Cnt, 1) = arrSht2(Cnt, 1): arrSht1b(Cnt, 2) = arrSht2(Cnt, 2) 'change any changed cell
                If arrSht1b(Cnt, 1) <> arrSht1(Cnt, 1) Then
                 Let arrOut(Cnt, 1) = arrSht1b(Cnt, 1) & "  <>  " & arrSht1(Cnt, 1)
                 Let DifCnt = DifCnt + 1
                Else: End If
                If arrSht1b(Cnt, 2) <> arrSht1(Cnt, 2) Then
                 Let arrOut(Cnt, 2) = arrSht1b(Cnt, 2) & "  <>  " & arrSht1(Cnt, 2)
                Else: End If
            ' Condition check
            ElseIf ((arrSht2(Cnt, 1) <> arrSht1b(Cnt, 1) Or arrSht2(Cnt, 2) <> arrSht1b(Cnt, 2)) And (arrSht2(Cnt + 1, 1) <> arrSht1b(Cnt + 1, 1) Or arrSht2(Cnt + 1, 2) <> arrSht1b(Cnt + 1, 2))) Then   ' main condition suggesting added new row
            Dim AdedRows As Long: Let AdedRows = AdedRows + 1
            '3b we need to shift all data down to allow space for new row in arrSht2()
            Dim CntIn As Long
                For CntIn = (UBound(arrSht2(), 1) - 1) To Cnt Step -1 'loop for all but last from this row
                 Let arrSht1b(CntIn + 1, 1) = arrSht1b(CntIn, 1): arrSht1b(CntIn + 1, 2) = arrSht1b(CntIn, 2) ' This effectively pulls up each row by one
                Next CntIn
            '3c add the new data to the modified array, Let arrSht1b()
                If arrSht1b(Cnt, 1) = "" Then arrSht1b(Cnt, 1) = "           " ' Just to make final output more neat
                If arrSht1b(Cnt, 2) = "" Then arrSht1b(Cnt, 2) = "           "
            '3d add info to the output array
                If Cnt > UBound(arrSht1(), 1) Then ' case of new lines
                 Let arrOut(Cnt, 1) = "An new extra line contains  " & arrSht1b(Cnt, 1): arrOut(Cnt, 2) = "An new extra line contains  " & arrSht1b(Cnt, 2)
                   Else: End If
                   Else: End If
             Let Cnt = Cnt + 1 ' we need to skip the next row as that was just effectively added so we are done with it
            Else ' row has not been added here
        Next Cnt ' ========= End main loop ==========
    Rem 4 last row may be new
        If arrSht2(lr2, 1) <> arrSht1(Lr1, 1) Or arrSht2(lr2, 2) <> arrSht1(Lr1, 2) Then ' either cell in last row is different
            If arrSht2(lr2, 1) <> arrSht1(Lr1, 1) Then
             Let arrOut(lr2, 1) = arrSht2(lr2, 1) & "  on last row is new"
            Else: End If
            If arrSht2(lr2, 2) <> arrSht1(Lr1, 2) Then
             Let arrOut(lr2, 2) = arrSht2(lr2, 2) & "  on last row is new"
            Else: End If
        Else 'last row on sheet2 is as on sheet1
    Rem 5 Output in new file For testing purposes, I give the output in a third worksheet, Tabelle3
    Dim Ws3 As Worksheet: Set Ws3 = ThisWorkbook.Worksheets("Tabelle3")
     Ws3.Cells.ClearContents
     Let Ws3.Range("A1:B1").Value = "Sheet1": Ws3.Range("C1:D1").Value = "Test Output": Ws3.Range("E1:F1").Value = "Sheet2"
     Let Ws3.Range("A2").Resize(UBound(arrSht1(), 1), UBound(arrSht1(), 2)).Value = arrSht1()
     Let Ws3.Range("C2").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2)).Value = arrOut()
     Let Ws3.Range("E2").Resize(UBound(arrSht2(), 1), UBound(arrSht2(), 2)).Value = arrSht2()
     Ws3.Columns.AutoFit
    Rem 6 MsgBoox output
     MsgBox Prompt:="inserted lines is   " & AdedRows & vbCrLf & "Changed cells is  " & DifCnt
  2. #62
    Test runs from code
    Sub TestyCalls() ' http://www.excelfox.com/forum/showthread.php/2277-Vba-button-Comparison-data-between-two-file-or-two-tabs?p=10741#post10741
    ' Call Testie(Worksheets("Sheet1"), Worksheets("Sheet2"))
     Call Testy(Worksheets("Sheet1"), Worksheets("Sheet2"))
    For support of this excelfox Thread:
    http://www.excelfox.com/forum/showth...0741#post10741
    Using Excel 2007 32 bit
    Sheet1 Sheet1 Test Output Test Output Sheet2 Sheet2
    Customer Assembly Customer Assembly
    Nu Torque
    13456
    Nu Torque
    13456
    Blu Origin Spaceship Blu Origin Spaceship
    Jet Blue21 ABC
    Alaska
    789
    Toyota Supra
    Emirate ABC12345
    Jet Blue21 ABC
    Alaska
    789
    Toyota Supra
    Emirate ABC12345
    Dup 2 of Toyota Dup 2 of Supra Toyota Supra
    Dup 2 of Emirate Dup 2 of ABC12345 Emirate ABC12345
    Spaceship 12 Spaceship
    Worksheet: Tabelle3
    Nu Torque
    13456
    Nu Torque
    13456
    Blu Origin Spaceship Alaska
    789
    Jet Blue21 ABC Excel123 HiThai Excel123 HiThai
    Alaska
    789
    Toyota Supra Emirate ABC12345
    Emirate ABC12345 Jet Blue21 ABC
    Toyota Supra
    Worksheet: Tabelle3
  3. #63
    Code in support of this Post
    Sub Testy(Ws1 As Worksheet, Ws2 As Worksheet)
    '1a capture data
         Let Lr1 = lr1_1
         Let Lr1 = Lr1_2
    Dim arrSht1b() As String, arrOut() As String, arrSht1Chk() As String, arrSht2Chk() As String
    ' ReDim arrSht1b(1 To UBound(arrSht2(), 1), 1 To UBound(arrSht2(), 2))
     ReDim arrSht1Chk(1 To UBound(arrSht1(), 1)): ReDim arrSht2Chk(1 To UBound(arrSht2(), 1)) ' Arrays for concatenated data
    '2b make check arrays        fill modified sheet 1 array, arrSht1b() , initially with sheet 1 data
    '     Let arrSht1b(Cnt, 1) = arrSht1(Cnt, 1): Let arrSht1b(Cnt, 2) = arrSht1(Cnt, 2)
         Let arrSht1Chk(Cnt) = arrSht1(Cnt, 1) & "|" & arrSht1(Cnt, 2)
        For Cnt = 1 To UBound(arrSht2(), 1) Step 1
         Let arrSht2Chk(Cnt) = arrSht2(Cnt, 1) & "|" & arrSht2(Cnt, 2)
    '2c make contents of array for output initially all dat from Sheet2
         Let arrOut(Cnt, 1) = CStr(arrSht2(Cnt, 1)): arrOut(Cnt, 2) = CStr(arrSht2(Cnt, 2))
    Rem 3 main loop   ' == Start Main loop ================
        For Cnt = 1 To UBound(arrSht1(), 1) Step 1 ' Counting at each row of Sheet2
        Dim MtchRes As Variant
         Let MtchRes = Application.Match(arrSht1Chk(Cnt), arrSht2Chk(), 0)
        '3a action whilst match is found --Inner Loop------
            Do While Not IsError(MtchRes) ' The 3a Loop
            Dim DupyCnt As Long: Let DupyCnt = DupyCnt + 1
                If DupyCnt > 1 Then
                 Let arrOut(MtchRes, 1) = "Dup " & DupyCnt & " of " & arrOut(MtchRes, 1): arrOut(MtchRes, 2) = "Dup " & DupyCnt & " of " & arrOut(MtchRes, 2)
                 Let arrOut(MtchRes, 1) = "": arrOut(MtchRes, 2) = "" ' remove the found data from array for output so that next line can look again for a possible duplicate
                 Let arrSht2Chk(MtchRes) = "" ' remove entry in check array so that next line can look for possible duplicate
            Loop ' ----------------------------------------
         Let DupyCnt = 0 ' reset the Duplicated data count for next row of data in Sheet1
        Next Cnt ' ========= End main loop ================= effectively we go to next row of data in Sheet1 with this line
     Ws3.Columns.AutoFit
    Rem 6 MsgBox output
    ' MsgBox Prompt:="Inserted lines is   " & AdedRows & vbCrLf & "Changed cells is  " & DifCnt
  4. #64
    http://www.excelfox.com/forum/showth...0745#post10745
    Sub TestyCalls() ' http://www.excelfox.com/forum/showth...0741#post10741
    '1a capture data
         Let Lr1 = lr1_1
         Let Lr1 = Lr1_2
    Dim arrSht1b() As String, arrOut() As String, arrSht1Chk() As String, arrSht2Chk() As String, arrSht2ChkKopie() As String
     ReDim arrSht2ChkKopie(1 To UBound(arrSht2(), 1))
     Let arrSht2ChkKopie() = arrSht2Chk() ' Arrays of same size and type can be assiigned too eachother
    '        If IsError(MtchRes) Then ' case data is missing Sheet2 ( deleted ) ' This straight forward modification to the existing code will not work. This is because the code modifies the check array , arrSht2Chk() , when  checking for the data from sheet1 in sheet2
    '         Let arrOut(Cnt, 1) = "Missing: " & arrSht1(Cnt, 1): arrOut(Cnt, 2) = "Missing: " & arrSht1(Cnt, 2)
    '        Else:
            '3a(ii) action whilst match is found --Inner Loop------
                    If DupyCnt > 1 Then
    '        End If '
        Next Cnt ' ========= End Main loop ================= effectively we go to next row of data in Sheet1 with this line
    Rem 3b Second Loop   ' ##### Start Second  loop #####
        'Dim MtchRes As Variant
         Let MtchRes = Application.Match(arrSht1Chk(Cnt), arrSht2ChkKopie, 0)
            End If '
        Next Cnt ' ##### End Second Loop #################       effectively we go to next row of data in Sheet1 with this line
     Ws3.Columns.AutoFit
    Rem 6 MsgBox output
  5. #65
    Nu Torque
    13456
    Nu Torque
    13456
    789
    Alaska
    789
    Toyota Supra Missing: Toyota Missing: Supra Emirate ABC12345
    Worksheet: Tabelle3
  6. #66
    Results in support of answer to this post
    http://www.excelfox.com/forum/showth...0749#post10749
    ( note a typo in your data for row 9 ( correspondingly output row 10 in these screenshots) : Angle is not Angel . hence this is taken by my code as Missing data row )
    J
    K
    L
    M
    N
    O
    P
    Q
    Original Original Original Original Original Original Test Output Test Output Test Output Test Output Test Output NEW NEW NEW NEW NEW NEW
    Assembly #: Assembly Name: Assembly Name: Assembly #: Assembly Name:
    Qty Per Ref/Designator Description Customer PN Internal PN Manufacture PN Customer PN Internal PN Manufacture PN Qty Per Ref/Designator Description Customer PN Internal PN Manufacture PN
    Nu Torque
    13456
    456
    456
    13456 456 456
    Nu Torque
    13456
    456
    456
    457
    457
    Spaceship 457 457
    457
    457
    Jet Blue21 ABC
    458
    458
    ABC 458 458
    Jet Blue21 ABC
    458
    458
    EXCELL123
    123
    ABC ABC MISSING: 3 MISSING: EXCELL123 MISSING: 123 MISSING: ABC MISSING: ABC
    Alaska
    789
    459
    459
    Toyota Supra
    460
    460
    Supra 460 460
    Toyota Supra
    460
    460
    Emirate ABC12345
    461
    461
    ABC12345 461 461
    Emirate ABC12345
    461
    461
    Angel ABC12346
    462
    462
    MISSING: 1 MISSING: Angel MISSING: ABC12346 MISSING: 462 MISSING: 462
    Angle ABC12346
    462
    462
    Worksheet: Result
    Nu Torque
    13456
    456
    456
    13456 456 456
    Nu Torque
    13456
    456
    456
    457
    457
    Spaceship 457 457
    457
    457
    Jet Blue21 ABC
    458
    458
    ABC 458 458
    Jet Blue21 ABC
    458
    458
    EXCELL123
    123
    Alaska
    789
    459
    459
    Toyota Supra
    460
    460
    Supra 460 460
    Toyota Supra
    460
    460
    Emirate ABC12345
    461
    461
    ABC12345 461 461
    Emirate ABC12345
    461
    461
    Angel ABC12346
    462
    462
    Angle ABC12346
    462
    462
    Worksheet: Result
  7. #67
    Code corresponding to last post, in support of answer to this post
    ' Call Testie(Worksheets("Original"), Worksheets("NEW"))
    ' Call Testy(Worksheets("Original"), Worksheets("NEW"))
     Call Testies(Worksheets("Original"), Worksheets("NEW"))
    Sub Testies(Ws1 As Worksheet, Ws2 As Worksheet)
    '1a capture data
         Let Lr1 = lr1_1
         Let Lr1 = Lr1_2
     Let arrSht1() = Ws1.Range("B1:G" & Lr1 & "").Value
     Let arrSht2() = Ws2.Range("B1:G" & Lr1 & "").Value
     ReDim arrOut(1 To UBound(arrSht2(), 1), 1 To UBound(arrSht2(), 2) - 1) ' -1 as one column , D is not required
    '     Let arrSht1Chk(Cnt) = arrSht1(Cnt, 1) & "|" & arrSht1(Cnt, 2)
         Let arrSht1Chk(Cnt) = arrSht1(Cnt, 1) & "|" & arrSht1(Cnt, 2) & "|" & arrSht1(Cnt, 4) & "|" & arrSht1(Cnt, 5) & "|" & arrSht1(Cnt, 6)
    '     Let arrSht2Chk(Cnt) = arrSht2(Cnt, 1) & "|" & arrSht2(Cnt, 2)
          Let arrSht2Chk(Cnt) = arrSht2(Cnt, 1) & "|" & arrSht2(Cnt, 2) & "|" & arrSht2(Cnt, 4) & "|" & arrSht2(Cnt, 5) & "|" & arrSht2(Cnt, 6)
    '2c make contents of array for output initially all dat from NEW
         Let arrOut(Cnt, 1) = CStr(arrSht2(Cnt, 1)): arrOut(Cnt, 2) = CStr(arrSht2(Cnt, 2)): arrOut(Cnt, 3) = CStr(arrSht2(Cnt, 4)):: arrOut(Cnt, 4) = CStr(arrSht2(Cnt, 5)):: arrOut(Cnt, 5) = CStr(arrSht2(Cnt, 6))
        For Cnt = 1 To UBound(arrSht1(), 1) Step 1 ' Counting at each row of NEW
    '        If IsError(MtchRes) Then ' case data is MISSING: NEW ( MISSING: ) ' This straight forward modification to the existing code will not work. This is because the code modifies the check array , arrSht2Chk() , when  checking for the data from Original in NEW
    '         Let arrOut(Cnt, 1) = "Missing: " & arrSht1(Cnt, 1): arrOut(Cnt, 2) = "MISSING:: " & arrSht1(Cnt, 2)
    '        Else:
                    If DupyCnt > 1 Then
    '        End If '
         Let DupyCnt = 0 ' reset the Duplicated data count for next row of data in Original
        Next Cnt ' ========= End Main loop ================= effectively we go to next row of data in Original with this line
            If IsError(MtchRes) Then ' case data is missing NEW ( MISSING: )
             Let arrOut(Cnt, 1) = "MISSING: " & arrSht1(Cnt, 1): arrOut(Cnt, 2) = "MISSING: " & arrSht1(Cnt, 2): arrOut(Cnt, 3) = "MISSING: " & arrSht1(Cnt, 4): arrOut(Cnt, 4) = "MISSING: " & arrSht1(Cnt, 5): arrOut(Cnt, 5) = "MISSING: " & arrSht1(Cnt, 6)
            End If '
        Next Cnt ' ##### End Second Loop #################       effectively we go to next row of data in Original with this line
    Dim Ws3 As Worksheet: Set Ws3 = ThisWorkbook.Worksheets("Result")
     Let Ws3.Range("A1:F1").Value = "Original": Ws3.Range("G1:K1").Value = "Test Output": Ws3.Range("L1:Q1").Value = "NEW"
     Let Ws3.Range("G2").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2)).Value = arrOut()
     Let Ws3.Range("L2").Resize(UBound(arrSht2(), 1), UBound(arrSht2(), 2)).Value = arrSht2()
     Ws3.Columns.AutoFit
    Rem 6 MsgBox output
  8. #68
    Suggested test data to answer this post: http://www.excelfox.com/forum/showth...0754#post10754
    Customer: Assembly #: Assembly Name:
    # Qty Per Ref/Designator Description Customer PN Internal PN Manufacture PN
    Nu Torque
    13456
    456
    456
    Blu Origin
    Spaceship
    457
    457
    Jet Blue21
    ABC
    458
    458
    EXCELL123
    123
    ABC
    ABC
    Toyota
    Supra
    460
    460
    Emirate
    ABC12345
    461
    461
    Angel
    ABC12346
    462
    462
    Worksheet: Original
    Nu Torque
    13456
    456
    456
    Blu Origin
    Spaceship
    457
    457
    Jet Blue23
    ABC
    DEF
    DEF
    EXCELL123
    123
    ABC
    ABC
    Toyota
    Supra
    460
    460
    Emirate
    ABC12345
    461
    461
    Jet Blue21
    ABC
    458
    458
    Worksheet: NEW
  9. #69
    In the last code , ( Sub Testies ), the following output is obtained when using the suggested test data above ( http://www.excelfox.com/forum/showth...0756#post10756 ) :
    J
    K
    L
    M
    N
    O
    P
    Q
    Assembly #: Assembly Name: Assembly #: Assembly Name:
    Qty Per Ref/Designator Description Customer PN Internal PN Manufacture PN Qty Per Ref/Designator Description Customer PN Internal PN Manufacture PN
    Nu Torque
    13456
    456
    456
    Nu Torque
    13456
    456
    456
    457
    457
    457
    457
    Jet Blue21 ABC
    458
    458
    2 Jet Blue23 ABC DEF DEF
    EXCELL123
    123
    ABC ABC
    EXCELL123
    123
    ABC ABC
    Toyota Supra
    460
    460
    Toyota Supra
    460
    460
    Emirate ABC12345
    461
    461
    Emirate ABC12345
    461
    461
    Angel ABC12346
    462
    462
    Jet Blue21 ABC
    458
    458
    Worksheet: Result
    J
    K
    Worksheet: Result
    J
    K
    L
    M
    N
    O
    P
    Q
    Jet Blue21 ABC
    458
    458
    Worksheet: Result
    _._____________________________________-
    We have currently output like this:
    But We want this to look more similar to screenshot output from post #15 ( http://www.excelfox.com/forum/showth...0754#post10754 )
  10. #70
    Code to answer this post: http://www.excelfox.com/forum/showth...0754#post10754
    ' Call Testies(Worksheets("Original"), Worksheets("NEW"))
     Call Tests28July(Worksheets("Original"), Worksheets("NEW"))
    Sub Tests28July(Ws1 As Worksheet, Ws2 As Worksheet)
    '1a capture data
         Let Lr1 = lr1_1
         Let Lr1 = Lr1_2
     Let arrSht2ChkKopie() = arrSht2Chk() ' Arrays of same size and type can be assiigned to eachother
    '        Else:
                    If DupyCnt > 1 Then
                     Let arrOut(MtchRes, 1) = "": arrOut(MtchRes, 2) = "": arrOut(MtchRes, 3) = "": arrOut(MtchRes, 4) = "": arrOut(MtchRes, 5) = "" ' remove the found data from array for output so that next line can look again for a possible duplicate
    '        End If '
            End If '
    Rem 3c(i) Third Loop  ' @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
        For Cnt = 1 To UBound(arrOut(), 1) Step 1 ' Counting at each row of output arrray
            If InStr(1, arrOut(Cnt, 1), "MISSING:", vbBinaryCompare) <> 1 Then
            Dim Cntx As Long ' for loop across "columns"
            '3c(ii) Loop across columns in output array
                For Cntx = 1 To 2 ' .....we need to break up into two loops, as we have columns in Output array of 1 2 3 4 5 but in Input array for sheet 1 we have B C D E F G .. D is ignored,
                    If arrOut(Cnt, Cntx) <> "" And arrOut(Cnt, Cntx) <> CStr(arrSht1(Cnt, Cntx)) Then ' condition for changed data
                     Let arrOut(Cnt, Cntx) = CStr(arrSht1(Cnt, Cntx)) & " < > " & arrOut(Cnt, Cntx)
                Next Cntx
                For Cntx = 3 To UBound(arrOut(), 2) ' we need to do break up into two loops......
                    If arrOut(Cnt, Cntx) <> "" And arrOut(Cnt, Cntx) <> CStr(arrSht1(Cnt, Cntx + 1)) Then ' condition for changed data
                     Let arrOut(Cnt, Cntx) = CStr(arrSht1(Cnt, Cntx + 1)) & " < > " & arrOut(Cnt, Cntx)
                Next Cntx
            Else ' case we have a Missing row, so no action in Third Loop 3c
        Next Cnt ' @@@@@ End Third Loop  ' @@@@@@@@@@@@@@@@@
     Ws3.Columns.AutoFit
    Rem 6 MsgBox output
  1. VBA to Reply All To Latest Email Thread
    By pkearney10 in forum Outlook Help
    Last Post: 12-22-2020, 11:15 PM
  2. Appendix Thread. Diet Protokol Coding Adaptions
  3. Replies: 19
    Last Post: 04-20-2019, 02:38 PM
  4. Search List of my codes
    By PcMax in forum Excel Help
    Last Post: 08-03-2014, 08:38 AM
